Greetings gentlemen, I need your help for programming my project, which I have the problem with the movements
servo main (4 engines) and another servo that moves a ping sensor. The problem is that I have to move forward and turn left or right, the robot stops only move a few degrees with the mini joystick and this happened to me right and reverse. I have two joystick YX Model (KEYES sjoys), the which need the robot to move by degrees and not stop to move in any direction.
Please could help me on how to solve this problem or how I can add additional code to test? accompanying the
codes of transmitter and receiver, which in turn helps them to expect any project need.
I do not know which of the two codes I make changes. Both codes are working but as noted above, it is not possible that the movements are constant when moving from one place to another. Thanks for responding.
