I am using this to raise and lower a tv lift, it is working as it should through app. When I use voice for Alexa by say Turn On Screen it carries out the command and operates the lift but then Alexa tells me that Screen is not responding. Is it looking for some type of feedback signal? Thanks Michael
#ifdef ENABLE_DEBUG
#define DEBUG_ESP_PORT Serial
#define NODEBUG_WEBSOCKETS
#define NDEBUG
#endif
#include <Arduino.h>
#if defined(ESP8266)
#include <ESP8266WiFi.h>
#elif defined(ESP32) || defined(ARDUINO_ARCH_RP2040)
#include <WiFi.h>
#endif
#include "SinricPro.h"
#include "SinricProSwitch.h"
#define WIFI_SSID "SSID"
#define WIFI_PASS "PASSWORD"
#define APP_KEY "Appkey"
#define APP_SECRET "Appsecret"
#define SWITCH_ID_1 "Switchid"
#define RELAY_1_PIN 16 // Relay 1 pin
#define RELAY_2_PIN 17 // Relay 2 pin
#define BAUD_RATE 115200
bool onPowerState1(const String &deviceId, bool &state) {
Serial.printf("Device 1 turned %s\n", state ? "on" : "off");
if (state) {
// Turn ON relay 1 for 1000ms
Serial.println("Relay 1 ON");
digitalWrite(RELAY_1_PIN, HIGH);
Serial.println("Relay 1 OFF");
digitalWrite(RELAY_1_PIN, LOW);
// Turn ON relay 2 for 1000ms
Serial.println("Relay 2 ON");
digitalWrite(RELAY_2_PIN, HIGH);
Serial.println("Relay 2 OFF");
digitalWrite(RELAY_2_PIN, LOW);
return true;
void setupWiFi() {
Serial.printf("\r\n[Wifi]: Connecting");
WiFi.setSleepMode(WIFI_NONE_SLEEP);
WiFi.setAutoReconnect(true);
WiFi.setSleep(false);
#endif
WiFi.begin(WIFI_SSID, WIFI_PASS);
Serial.print(".");
delay(250);
Serial.printf("connected!\r\n[WiFi]: IP-Address is %s\r\n", WiFi.localIP().toString().c_str());
void setupSinricPro() {
pinMode(RELAY_1_PIN, OUTPUT);
pinMode(RELAY_2_PIN, OUTPUT);
SinricProSwitch& mySwitch1 = SinricPro[SWITCH_ID_1];
mySwitch1.onPowerState(onPowerState1);
SinricPro.onConnected([]() { Serial.println("Connected to SinricPro"); });
SinricPro.onDisconnected([]() { Serial.println("Disconnected from SinricPro"); });
SinricPro.begin(APP_KEY, APP_SECRET);
Serial.begin(BAUD_RATE); Serial.println("\n\n");
setupWiFi();
setupSinricPro();
SinricPro.handle();
