I am using the attached code to send & receive SMS messages between my phone and the SIM7600 unit. I am currently running into a problem where the unit says "+SMS FULL" in the serial monitor when it receives a text from me. I have tried moving around the deleteSMS command but can not find a spot that provides correct results. Any help would be greatly appreciated.
#include <OneWire.h> // These Libraries allow concise interpretation of the
#include <DallasTemperature.h> // measurements from the Dallas temperature sensor
#include <SoftwareSerial.h>
#include "Adafruit_FONA.h"
#define tempData 2 // Temperature data is read through digital pin 2
#define GSM_TX 3
#define GSM_RX 4
#define GSM_PWR 5
#define GSM_RST 20 // Random number?
#define GSM_BAUD 9600
SoftwareSerial SIM7600SS = SoftwareSerial(GSM_TX, GSM_RX);
SoftwareSerial *SIM7600Serial = &SIM7600SS;
OneWire myWire(tempData); // OneWire object creation named "myWire"
DallasTemperature sensors(&myWire); // Pass our oneWire reference to Dallas Temperature sensor
Adafruit_FONA SIM7600 = Adafruit_FONA(GSM_RST);
char handlerNumber[32] = "**********";
char SIM7600InBuffer[64]; // For incoming SMS
char SMSbuffer[32]; // Store the SMS content in here
uint16_t SMSLength;
String SMSString = "";
static int inOut = 0;
int Updates = 10;
int Upper = 85;
int Lower = 30;
int x = 0;
int y = 0;
int z = 0;
pinMode(GSM_PWR, OUTPUT);
pinMode(GSM_PWR, INPUT_PULLUP);
Serial.println("Interfacing SIM7600 GSM Module with Arduino UNO");
Serial.println("Initializing... (May take a minute)");
SIM7600Serial->begin(GSM_BAUD); // 9600 Baud, slow so we can follow
if (!SIM7600.begin(*SIM7600Serial)) {
Serial.println("Couldn't find SIM7600");
while (1);
Serial.println(F("SIM7600 is OK")); // Uses flash-based memory
Serial.println("GSM is ready!");
SIM7600.sendSMS(handlerNumber, "Hello, welcome to the K9 Environmental Monitor Unit.\n\nIs your dog located inside or outside?");
sensors.begin(); // Initialize the DS18B20 temperature sensor
char* bufPtr = SIM7600InBuffer; // Create a pointer to the location of the incoming text
if (SIM7600.available()) { // If there is data incoming
int slot = 0; // This will be the slot number of the SMS
int charCount = 0;
if (z == 0){
for(int x = 0; x < 4; x = x + 1) {
boolean deleteSMSDone = SIM7600.deleteSMS(slot);
if (deleteSMSDone == true) {
Serial.println("OK!");
z = 1;
do {
*bufPtr = SIM7600.read(); // Store the read incoming SMS
Serial.write(*bufPtr); // Write it to the serial monitor (non-ASCII)
delay(1);
// While not at the end of the string, there is more available, and we have room to store it
} while ((*bufPtr++ != '\n') && (SIM7600.available()) && (++charCount < (sizeof(SIM7600InBuffer) - 1)));
*bufPtr = 0; // Add a terminal NULL
if (1 == sscanf(SIM7600InBuffer, "+CMTI: \"SM\",%d", &slot)) { // Scan string for an SMS recieved notification
Serial.print("slot: "); // If there was an SMS, get slot #
Serial.println(slot);
if (!SIM7600.getSMSSender(slot, handlerNumber, 31)) { // Get sender phone number
Serial.println("Didn't find SMS message in slot!");
Serial.print("FROM: ");
if (!SIM7600.readSMS(slot, SMSbuffer, 250, &SMSLength)) { // Pass in buffer and max length
Serial.println("Failed!");
else {
SMSString = String(SMSbuffer);
Serial.print("SMS: ");
Serial.println(SMSString);
if (x = 1){
Updates = SMSString.toInt();
Serial.println(Updates);
x = 0;
if (x = 2){
Upper = SMSString.toInt();
Serial.println(Upper);
x = 0;
if (x = 3){
Lower = SMSString.toInt();
Serial.println(Lower);
x = 0;
// Begin to compare strings
// Is the dog located inside or outside
if (SMSString == "Inside"){
inOut = 0;
SIM7600.sendSMS(handlerNumber, "Default Settings:\n\n-Update every 10 minutes\n-Upper temperature limit: 85\n-Lower temperature limit: 30\n\nWould you like to change these settings? (Yes/No)");
else if (SMSString == "Outside"){
inOut = 1;
// Would you like to update the settings
if (SMSString == "Yes"){
SIM7600.sendSMS(handlerNumber, "Ok, which parameter?\n\nEnter Updates, Upper or Lower.");
else if (SMSString == "No"){
SIM7600.sendSMS(handlerNumber, "Ok, default settings it is!\n\nRespond with Settings at any time to view the current parameters");
// What would you like to update
if (SMSString == "Updates"){
x = 1;
SIM7600.sendSMS(handlerNumber, "How often would you like sensor updates? (In minutes)");
else if (SMSString == "Upper"){
x = 2;
SIM7600.sendSMS(handlerNumber, "What would you like the upper temperature limit to be?");
else if (SMSString == "Lower"){
x = 3;
SIM7600.sendSMS(handlerNumber, "What would you like the lower temperature limit to be?");
// THIS IS THE DELETE FUNCTION
while(1) {
Serial.println("YO BITCH IM RIGHT HERE");
static int tempReading;
sensors.requestTemperatures(); // Send request to get temperature readings
tempReading = sensors.getTempFByIndex(0);
// Serial.print(tempReading); // "ByIndex(0) refers to the first temp sensor in
// Serial.print(" - Fahrenheit temperature: "); // a circuit. Many temp sensors can be strung together.
// Serial.println(sensors.getTempFByIndex(0));
if ((tempReading >= Upper) && (y = 0)){
SIM7600.sendSMS(handlerNumber, "Warning - Upper Temperature Limit Reached!");
Serial.println(tempReading);
y = 1;
