Hello, i have an icomsat v1.1 gsm shield. it is a wonderful shield but i lack understanding on it. i want to activate a relay via a particular SMS. for example, when i SMS "on" a Pin on arduino will be HIGH and vice versa.
i tried modifying a code, but the result is every time The GSM receives ANY SMS, the pin will be high. can someone assist on making the SMS more specific?
the Bold parts are the parts i added
/* GSM Shield example
created 2011
by Boris Landoni
This example code is in the public domain.
http://www.open-electronics.org
http://www.futurashop.it
[b]int led = 13;[/b]
#include <SoftwareSerial.h>
#include <GSM_Shield.h>
char number[]="+39123456789"; //Destination number
char text[]="hello world"; //SMS to send
byte type_sms=SMS_UNREAD; //Type of SMS
byte del_sms=0; //0: No deleting sms - 1: Deleting SMS
GSM gsm;
char sms_rx[122]; //Received text SMS
//int inByte=0; //Number of byte received on serial port
char number_incoming[20];
int call;
int error;
[b]pinMode(led, OUTPUT);[/b]
Serial.println("system startup");
gsm.TurnOn(9600); //module power on
gsm.InitParam(PARAM_SET_1);//configure the module
gsm.Echo(0); //enable AT echo
char inSerial[5];
int i=0;
delay(2000);
Check_Call(); //Check if there is an incoming call
Check_SMS(); //Check if there is SMS
//Check data serial com
if (Serial.available() > 0)
while (Serial.available() > 0) {
inSerial[i]=(Serial.read()); //read data
i++;
inSerial[i]='\0';
Check_Protocol(inSerial);
void Check_Protocol(String inStr)
Serial.print("Command: ");
Serial.println(inStr);
Serial.println("Check_Protocol");
switch (inStr[0])
case 'a' : //Answer
if (gsm.CallStatus()==CALL_INCOM_VOICE){
gsm.PickUp();
Serial.println("Answer");
Serial.println("No incoming call");
case 'c': // C //Call
if (inStr.length()<2) //To call variable 'number' comand c
Serial.print("Calling ");
Serial.println(number);
gsm.Call(number);
if (inStr.length()==2) //To call number in phone book position comand cx where x is the SIM position
error=gsm.GetPhoneNumber(inStr[1],number);
if (error!=0)
gsm.Call(number);
Serial.print("No number in pos ");
Serial.println(inStr[1]);
case 'h': //H //HangUp if there is an incoming call
if (gsm.CallStatus()!=CALL_NONE)
Serial.println("Hang");
gsm.HangUp();
case 's': //S //Send SMS
Serial.print("Send SMS to ");
error=gsm.SendSMS(number,text);
if (error==0) //Check status
Serial.println("SMS ERROR \n");
Serial.println("SMS OK \n");
case 'p': //Read-Write Phone Book
if (inStr.length()==3)
switch (inStr[1])
case 'd': //Delete number in specified position pd2
error=gsm.DelPhoneNumber(inStr[2]);
if (error!=0)
Serial.print("Phone number position ");
Serial.print(inStr[2]);
Serial.println(" deleted");
case 'g': //Read from Phone Book position pg2
error=gsm.GetPhoneNumber(inStr[2],number);
if (error!=0) //Find number in specified position
Serial.print("Phone Book position ");
Serial.print(": ");
else //Not find number in specified position
Serial.print("No Phone number in position ");
Serial.println(inStr[2]);
case 'w': //Write from Phone Book Position pw2
error=gsm.WritePhoneNumber(inStr[2],number);
if (error!=0)
Serial.print("Number ");
Serial.print(number);
Serial.print(" writed in Phone Book position ");
else Serial.println("Writing error");
delay(1500);
return;
void Check_Call() //Check status call if this is available
call=gsm.CallStatus();
switch (call)
case CALL_NONE:
Serial.println("no call");
case CALL_INCOM_VOICE:
gsm.CallStatusWithAuth(number_incoming,0,0);
Serial.print("incoming voice call from ");
Serial.println(number_incoming);
case CALL_ACTIVE_VOICE:
Serial.println("active voice call");
case CALL_NO_RESPONSE:
Serial.println("no response");
return;
void Check_SMS() //Check if there is an sms 'type_sms'
char pos_sms_rx; //Received SMS position
pos_sms_rx=gsm.IsSMSPresent(type_sms);
if (pos_sms_rx!=0)
[b] digitalWrite(led, HIGH);[/b]
//Read text/number/position of sms
gsm.GetSMS(pos_sms_rx,number_incoming,sms_rx,120);
Serial.print("Received SMS from ");
Serial.print(number_incoming);
Serial.print("(sim position: ");
Serial.print(word(pos_sms_rx));
Serial.println(")");
Serial.println(sms_rx);
if (del_sms==1) //If 'del_sms' is 1, i delete sms
error=gsm.DeleteSMS(pos_sms_rx);
if (error==1)Serial.println("SMS deleted");
else Serial.println("SMS not deleted");
return;
your help is much appreciated!
