Hello everybody,
I am trying to figure out some code to do what I want.
Here's the scenario:
If I press a button once, it starts a 'routine(?)' that turns on and off an output (relay) every 5 seconds. When I press the button again, I want this to stop.
Here is the application:
I have a camera that I will put into the air by balloon, and when I press the 'start button' I want it to energize a relay every five seconds, which causes the camera to take a picture. When I get the camera back to the ground, I'll press the same button, which tells it to stop taking pictures.
I copied the bulk of the learning tutorial, where you press the button four times it turns an LED on. I've been playing around with different things for two days, but seeing as I'm just learning, I don't really know what to use yet.
Here is the current code I just tested, and doesn't work(obviously).
State change detection (edge detection)
Often, you don't need to know the state of a digital input all the time,
but you just need to know when the input changes from one state to another.
For example, you want to know when a button goes from OFF to ON. This is called
state change detection, or edge detection.
This example shows how to detect when a button or button changes from off to on
and on to off.
The circuit:
* pushbutton attached to pin 2 from +5V
* 10K resistor attached to pin 2 from ground
* LED attached from pin 13 to ground (or use the built-in LED on
most Arduino boards)
created 27 Sep 2005
modified 14 Oct 2010
by Tom Igoe
This example code is in the public domain.
http://arduino.cc/en/Tutorial/ButtonStateChange
// this constant won't change:
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int flashState = 0;
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter, DEC);
else {
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
// turns on the LED every four button pushes by
// checking the modulo of the button push counter.
// the modulo function gives you the remainder of
// the division of two numbers:
if (buttonPushCounter % 2 == 0) {
flashState = 1;
digitalWrite(ledPin, LOW);
while (flashState == 1) {
digitalWrite(ledPin, HIGH);
Any help will be greatly appreciated.
Thanks, Joshua
