Help with code
Can someone advise what does this do?
 #define write8inline(d) {                          \
   PORTD = (PORTD & B00000000) | ((d) & B11111111); \
   PORTB = (PORTB & B11111111) | ((d) & B00000000); \
I am trying to modify a library that originally used two ports (B 0...1) (D 2...7) (6+2) to transfer data to an LCD, but which I changed to use only PORTD by sacrificing the serial port. Currently PORTB is not used at all, but I cant remove the last line. Just want to check with someone with more experience if those two lines are doing something that could further be simplified.
Regards
You have our permission.
