Help with code
I'm almost there, I have tested the code under individual, but when I put them together I don't get what I expect.
When I test the code for the LED, they turn on and off from my C# program. I send the command "<->" and "<+>".
When I test the analog code, I get what I want out on the port 0-5 Volts by sending the value between 0 and 5000 with the <> included "<0-5000>".
I guess there is something wrong with my IF statement, since when I send "<+>" or "<->" I only get the "Serial.print("Motor RPM =");" executed.
Any suggestions?
const byte NumChars = 32;
char ReceivedChars[NumChars];
boolean NewData = false;
    Serial.println( "Your connected);
    RecWithStartEndMarkers();
    SendNewData();
void RecWithStartEndMarkers()
    static boolean RecInProgress = false;
    static byte ndx = 0;
    char StartMarker = '<';
    char EndMarker = '>';
    char rc;
  if (Serial.available() > 0)
    while (Serial.available() > 0 && NewData == false)
        rc = Serial.read();
        if (RecInProgress == true)
            if (rc != EndMarker)
                ReceivedChars[ndx] = rc;
                ndx++;
                if (ndx >= NumChars)
                    ndx = NumChars - 1;
            else {
                ReceivedChars[ndx] = '\0';
                ndx = 0;
                NewData = true;
        else if (rc == StartMarker)
            RecInProgress = true;
void SendNewData()
    if (NewData == true)
        int Test = atoi(ReceivedChars);
        if (Test == '+')
          digitalWrite(9, HIGH);
          Serial.println( "LED ON");
          else if (Test == '-')
          digitalWrite(9, LOW);
          Serial.println( "LED OFF");
        int MotorRPM = atoi(ReceivedChars);
        Serial.println(MotorRPM);
        MotorRPM = map(MotorRPM, 0, 5000, 0, 255);
        analogWrite(3, MotorRPM);
        NewData = false;
Please post your actual code
Put in a piece of test code to print the data that has been received before you try to use it - just to be sure you are getting what you expect.
I have never tried atoi() on a '+' character and I don't know what it does - are you sure it returns the ascii value for a + symbol?
...R
AWOL:
This is the whole code.
fsoender:
It can't be. It won't compile.
Robin2:
...R
I think your on to something, I change it to "0" and "1" from C#, now I get "Motor RPM = 0" and "Motor RPM = 1" when I press the C# buttons, when I use the slide I get the correct value.
Why is the "Motor RPM =" interfering with "LED on" or "LED off"?
Does SendNewData() ever get called to help with switching NewData back & forth between true & false?
Or just not implemented yet?
aarg:
Sorry, change the "Serial.println( "Your connected);" to Serial.println( "Your connected");
CrossRoads:
Not more than in the code I have, you think that's were the fault is?
And fix the spelling (grammer?):
"You're connected" or "You are connected"
CrossRoads:
He he, ok :slight_smile:
Fixed it with a CASE statement :slight_smile:
fsoender:
You mean a switch statement?
yes
fsoender:
I don't think you are thinking.
The "Motor RPM" is not interfering with anything. It is doing what you have told it to do. The LEDs only operate if + or - is detected and the code in your Original Post can't detect + or -
You need different code (not atoi() ) if you want to detect + and -. Alternatively you could treat the values 0 and 1 as special cases to be dealt with before the MotorRPM part.
...R
