Help with code
Hello
I need some help with my code for car diagnostic.
I need to count led fleshes (button Presses) like this .
For example : the Code Error 35 is . ......*.
The time between fleshes of first number is 1 s and pause between first and second number is 2 s.
int inPin = 7;         // the number of the input pin
int reading;           // the current reading from the input pin
int previous = LOW;    // the previous reading from the input pin
int countA=0; //
int countB=0;
long time = 0;
long debounce = 200;
  pinMode(inPin, INPUT);
  reading = digitalRead(inPin);
  if (reading == HIGH && previous == LOW && millis() - time > debounce) {
    //increment count
    countB++;}
    else{
    countA++;
    time = millis();
  previous = reading;
  if (countA == 3 && countB ==5)
    //whatever you want to do over here
    countA=countB=0; //reset count
It would help if you used more random indenting in your code. A few more comments that are self-evident wouldn’t hurt, either.
After that, if you explained what the problem is, maybe we could help.
