help with code
just got a prob with this line
cred = (count - maxCount);
What is the prob(lem)?
Sorry yes I should have said won't compile
I'm not in the mood for twenty questions. Where is the rest of your code and the error message that the compiler told you but that you won't post?
static int lastState = 0;
static int count = 0 ;   //number of pulses for each card
static int countb = 0 ;
static int cerd = 0 ;
int outputPin = 13;     //names pins
int inputPin =10;
int fullPin =8;
int breakPin =5;
int maxCount ;     //number of pulse's before this card shuts off
//int newcard = 0;
  Serial.begin(9600);     //just for now so i can see what's going on
  digitalWrite (fullPin, HIGH);
  pinMode(outputPin,OUTPUT);
  pinMode(inputPin, INPUT);     //make's pin 10 input pin
  pinMode(breakPin, INPUT);      //this is used to breakout of while loop
  digitalWrite (outputPin, LOW);
bailout: // this is for the goto statment ( sorry but i can not thing of any other way but goto )
  digitalWrite(outputPin, LOW);
  Serial.println("Place Card on Bar");
  while (Serial.available() == 0);     // this is going to be input from card
  int val = Serial.read();     //will be input from card reader
  Serial.println("do not remove until you have finished");
  if (val == '1')      //if this is the card number do the next stuff if not keep looking
Serial.println("card 1  ");
    while(!digitalRead(5))
      int maxCount =20;
      if (count > maxCount)     //when count gets to the set number sends 5v to pin 13
        Serial.println("NO CREDIT LEFT");
        digitalWrite(outputPin, LOW);   // power to relay to shut flow
        goto bailout;
      digitalWrite (outputPin, HIGH);
      int newState = digitalRead(inputPin);  //pulse from flow meter
      if (newState != lastState)     //detect change
        Serial.println(count);   //just for now so i can see what's going on
        count ++;    //adds one to count
      cred = (count - count);
        lastState = newState;
  // looks for next card number
Variables that are global do not need to be static. These are global...
static int cerd = 0 ; cred = (count - count);
count - count, for every value of count, will be 0. cerd and cred are not the same variable.
int inputPin =10;
int fullPin =8;
int breakPin =5;
//int newcard = 0;
      int maxCount =20;
        goto bailout;
sorry forgot i put the count - count to see if i could work out why it was not working
Thanks .....
