Help with coding a (simple) array
This is what I have now, the function of the potmeter has to be replaced by a piece of code to regulate the delay.
int brightness = 0; // how bright the LED is
int fadeAmount = 10; // how many points to fade the LED by
int sensorValue = 0;
int outputValue =0;
//const int analogInPin = A0; // make frequency controlled by potmeter
// declare pin 9 to be an output:
pinMode(9, OUTPUT);
//sensorValue = analogRead(analogInPin);
// map it to the range of the analog out:
//outputValue = map(sensorValue, 0, 1023, 200, 1600);
Serial.println("1");
while(brightness >= 0) {
// set the brightness of pin 9:
analogWrite(9, brightness);
//Serial.println("kjklo");
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness == 230) {
fadeAmount = -fadeAmount ;
// wait for 30 milliseconds to see the dimming effect
delay(1);
//delay(100);
brightness = 0;
fadeAmount = 10;
//Serial.println("dd");
if (brightness == 150) {
delay(5);
fadeAmount = 10;
brightness = 0;
delay(outputValue); //variable output from potmeter
Serial.println(outputValue);
