Hi everyone,
I'm trying to build a solar tracking robot using an Arduino Uno. I have two servo motors that I want to use to control the movement of the robot in both horizontal and vertical directions. I also have four LDRs (Light Dependent Resistors) to detect the intensity of sunlight from different angles.
I want to use the RTC (Real Time Clock) module to keep track of time and make the robot move accordingly. I have found the SolarCalculator.h library, which I believe can help me calculate the position of the sun based on the current time and location.
However, I'm new to coding with Arduino and I'm not sure how to combine all these components to make the robot work as intended. Can anyone provide me with some guidance or sample code to get started?
Here are the things I have:
Arduino Uno
Two servo motors
Four LDRs
RTC module
Any help would be greatly appreciated. Thank you in advance!
The code is here below:
#include <Servo.h>
#include <Wire.h>
#include "RTClib.h"
#define LDR1 A0
#define LDR2 A1
#define LDR3 A2
#define LDR4 A3
RTC_DS1307 rtc;
Servo horizontalServo;
Servo verticalServo;
pinMode(LDR1, INPUT);
pinMode(LDR2, INPUT);
pinMode(LDR3, INPUT);
pinMode(LDR4, INPUT);
horizontalServo.attach(9);
verticalServo.attach(10);
Wire.begin();
rtc.begin();
int ldr1Value = analogRead(LDR1);
int ldr2Value = analogRead(LDR2);
int ldr3Value = analogRead(LDR3);
int ldr4Value = analogRead(LDR4);
