Thanks Robin2,
i have moved the stepper.run and read through the post you linked to and this tutorial
Below is the altered code, no when i power it up i get no response from the stepper when the pir is triggered.
#include <AccelStepper.h>
AccelStepper stepper (1, 3, 2); // name of stepper motor (1 = driver, pin 3 = step, pin 2 = direction)
int pirPin = 4;
int calibrationTime = 30;
long unsigned int lowIn;
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int PIRValue = 0;
long previousMillis = 0;
long interval = 1000;
stepper.setMaxSpeed(1000);
stepper.setAcceleration(200);
pinMode(pirPin, INPUT);
PIRSensor();
stepper.run();
void PIRSensor()
if (digitalRead(pirPin) == HIGH)
if (lockLow)
stepper.moveTo(100);
stepper.moveTo(-100);
PIRValue = 1;
lockLow = false;
Serial.println("Motion detected.");
unsigned long currentMillis = millis();
if (currentMillis - previousMillis > interval)
previousMillis = currentMillis;
takeLowTime = true;
if (digitalRead(pirPin) == LOW)
if (takeLowTime) {
lowIn = millis();
takeLowTime = false;
if (!lockLow && millis() - lowIn > pause)
PIRValue = 0;
lockLow = true;
Serial.println("Motion ended.");
