help with coding for a stepper motor
I can't say I can follow the logic of your code but these two things come to mind
These two lines make no sense because the only one that will be recognized is the second one
      stepper.moveTo(100);
      stepper.moveTo(-100);
And this line
  if (digitalRead(pirPin) == LOW)
uses a completely different value from the pirPin to the value in the first IF statement. It is entirely possible that both IF statements could be true.
Try changing the line I have quoted to this
so that that part of the code is called if the first reading of pirPin is LOW
Can you explain the purpose of your different boolean variables?
...R
