Help with coding...
Hi everyone I'm stuck on keypad, because I want 3 products like 111 beats per minute. So if I press 1 once then it saves it as a variable of 1, if i press it again it saves it in a another variable as 1, etc... Then calculates. The code supplied is what I have so far and kind of explains what is happening, thanks for the help to those who have contributed.
[u]Code V0.0:[/u]
#include "Arduino.h"
#include "Keypad.h"
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
              {'1','2','3'},
              {'4','5','6'},
              {'7','8','9'},
              {'*','0','#'}
byte rowPins[ROWS] = {12, 11, 10, 9}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {8, 7, 6}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int VARone = 0;
int VARtwo = 0 ;
int VARthree = 0;
int One1 = 0;
int Two2 = 0;
int Three3 = 0;
int convert = 0;
int total = 0;
int RUN = 0;
int x = 0;
int input = 0;
int varin = 0;
int count = 0;
int vardp = 0;
int varcalc = 1;
  pinMode(2,INPUT);
  pinMode(5,OUTPUT);
  pinMode(4,OUTPUT);
  char key = keypad.getKey();
  if (digitalRead(2))
    if( ( RUN ) == ( 0 ) )
      varcalc = 0;
      VARone = 0;
      VARtwo = 0;
      VARthree = 0;
      One1 = 0;
      Two2 = 0;
      Three3 = 0;
      convert = 0;
      total = 0;
      RUN = 1;
      if( ((VARone) == (0)) && ((VARtwo)==(0)) && ((VARthree)==(0)) )
        if(key)
          switch (key)
            case '0':
            One1 = 0;
            varcalc = 0;
            VARone = 1;
            case '1':
            One1 = 1;
            varcalc = 0;
            VARone = 1;
            case '2':
            One1 = 2;
            varcalc = 0;
            VARone = 1;
            case '3':
            One1 = 3;
            varcalc = 0;
            VARone = 1;
            case '4':
            One1 = 4;
            varcalc = 0;
            VARone = 1;
            case '5':
            One1 = 5;
            varcalc = 0;
            VARone = 1;
            case '6':
            One1 = 6;
            varcalc = 0;
            VARone = 1;
            case '7':
            One1 = 7;
            varcalc = 0;
            VARone = 1;
            case '8':
            One1 = 8;
            varcalc = 0;
            VARone = 1;
            case '9':
            One1 = 9;
            varcalc = 0;
            VARone = 1;
          if( ((VARone) == (1)) && ((VARtwo)==(0)) && ((VARthree)==(0)) )
            if(key)
            switch (key)
              case '0':
              Two2 = 0;
              varcalc = 0;
              VARtwo = 1;
              case '1':
              Two2 = 1;
              varcalc = 0;
              VARtwo = 1;
              case '2':
              Two2 = 2;
              varcalc = 0;
              VARtwo = 1;
              case '3':
              Two2 = 3;
              varcalc = 0;
              VARtwo = 1;
              case '4':
              Two2 = 4;
              varcalc = 0;
              VARtwo = 1;
              case '5':
              Two2 = 5;
              varcalc = 0;
              VARtwo = 1;
              case '6':
              Two2 = 6;
              varcalc = 0;
              VARtwo = 1;
              case '7':
              Two2 = 7;
              varcalc = 0;
              VARtwo = 1;
              delay(11);
              case '8':
              Two2 = 8;
              varcalc = 0;
              VARtwo = 1;
              case '9':
              Two2 = 9;
              varcalc = 0;
              VARtwo = 1;
          if( ((VARone) == (1)) && ((VARtwo)==(1)) && ((VARthree)==(0)) )
            if(key)
              switch (key)
                case '0':
                Three3 = 0;
                varcalc = 0;
                VARthree = 1;
                case '1':
                Three3 = 1;
                varcalc = 0;
                VARthree = 1;
                case '2':
                Three3 = 2;
                varcalc = 0;
                VARthree = 1;
                case '3':
                Three3 = 3;
                varcalc = 0;
                VARthree = 1;
                delay(11);
                case '4':
                Three3 = 4;
                varcalc = 0;
                VARthree = 1;
                case '5':
                Three3 = 5;
                varcalc = 0;
                VARthree = 1;
                case '6':
                Three3 = 6;
                varcalc = 0;
                VARthree = 1;
                delay(11);
                case '7':
                Three3 = 7;
                varcalc = 0;
                VARthree = 1;
                case '8':
                Three3 = 8;
                varcalc = 0;
                VARthree = 1;
                case '9':
                Three3 = 9;
                varcalc = 0;
                VARthree = 1;
                delay(11);
    if( ( varcalc ) == ( 0 ) )
            convert = ((60000)/(One1));
            varcalc = 1;
          total =  ( ( (One1) * (10) ) + ( (Two2)  ) ) ;
          convert = ( ( 60000 )/ ( total ) );
          varcalc = 1;
          if( ((VARone) == (1)) && ((VARtwo)==(1)) && ((VARthree)==(1)) )
            total = ( ( ( (One1) * (1000) ) + ( (Two2) * (100) ) ) +  ( Three3 ) );
            varcalc = 1;
            varcalc = 1;
      RUN = 0 ;
      digitalWrite(4,HIGH);
      analogWrite(5,255);
      delay( 11 );
      analogWrite(5,0);
      digitalWrite(4,LOW);
      delay( convert );
It's hard to tell what's going on and what's supposed to happen, but I can tell you that all the delays between a "break" and the next "case" will never get executed, so they may as well not be there. Something that isn't there but should be, is a pair of code tags.
(Why) do (you) have (so) many (unnecessary) parentheses?
Hi everyone I updated the post to an extent that if you choose a number i.e. 111 and follow the code it would make sense and special thanks to AWOL for the help and look forward this project working.
…and now you’ve edited the original post, so my earlier comments don’t make any sense, and you’ve still not got any code tags.
Good luck.
Code-shortening hint
if(key >= '0' && key <= '9')
  One1 = key - '0';
  varcalc = 0;
  VARone = 1;
etc.
New Update evryone
R10_JR: New Update evryone
That's the second time you've posted that, but I see no update.
Edit: {light dawns} You've edited the original post (still no code tags), so nothing makes sense.
Do you want a forum timeout?
Hi, Welcome to the forum.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code. It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom... :)
Update: Form and Code. 06/08/2016
Hi, PLEASE DO NOT KEEP GOING BACK AND UPDATING/EDITING YOUR FIRST POST. You are not helping others to help you by changing the initial code you had problems with.
Each time you update YOUR CODE please post a NEW message with your updated code, NOT a message that says
New Update evryone
This forum is to help all users, so anyone who had a similar problem to you, SHOULD be able to follow how you solved your problem, by changing the initial post you are removing any hope of this thread being used to help other users.
SO PLEASE NEW MESSAGES EACH TIME, INCLUDING CODE UPDATES.
Thanks.. Tom... :)
Hi, How does the code know if you are putting in a 1 or 2 or 3 digit number? Would it be better to store each key press and look for a # press to be the equivalent of ENTER/CALCULATE?
You wouldn't need all these IF statements to check for number of digits and do the calculation? And you would be able to input any number of digits.
Tom... :)
Hi it saves like this for all three variables;
One1 = key - '0';//First variable
Two2 = key - '0';//Second variable
Three3 = key - '0';//Third variable
This is a new code version of V0.0 [u]Code V0.1:[/u]
#include "Keypad.h"
              {'1','2','3'},
              {'4','5','6'},
              {'7','8','9'},
              {'*','0','#'}
int VARone = 0;
int VARtwo = 0 ;
int VARthree = 0;
int One1 = 0;
int Two2 = 0;
int Three3 = 0;
int total = 0;
int RUN = 0;
int varcalc = 1;
  pinMode(2,INPUT);
  pinMode(5,OUTPUT);
  pinMode(4,OUTPUT);
    Serial.print(total);
    if (digitalRead(2))//Mode Loop
        varcalc = 0;
        VARone = 0;
        VARtwo = 0;
        VARthree = 0;
        One1 = 0;
        Two2 = 0;
        Three3 = 0;
        total = 0;
        //Keypad closed loop
        Serial.print(key);
        if((VARone)==(0))//Test if variable one is equal to 0
          //Get key from 0 - 9 and set it to variable one
          delay(11);
          if(key != NO_KEY)
            One1 = (key);
            varcalc = 0;
            VARone = 1;
          if(((VARone)==(1))&&((VARtwo)==(0)))//Test variable one is equal to 1, whilst variable two is equal to 0
            //Get key from 0 - 9 and set it to variable two
            delay(11);
            if(key != NO_KEY)
                Two2 = (key);
                varcalc = 0;
                VARtwo = 1;
            if(((VARone)==(1))&&((VARtwo)==(1))&&((VARthree)==(0)))//Test variable one and variable two is equal to 1, whilst variable three is equal to 0
                //Get key from 0 - 9 and set it to variable three
                delay(11);
                if(key != NO_KEY)
                    Three3 = (key);
                    varcalc = 0;
                    VARthree = 1;
        if((varcalc)==(0))//Calculation Loop
            if((VARone)==(1))//Runs calculation when there is only one variable
                total = (One1);//Takes one inputted number like; '5'
                varcalc = 1;
                if(((VARone) == (1)) && ((VARtwo)==(1)))//Runs calculation when there is only two variables
                    total =  (((One1)*(10))+((Two2)));//Takes two inputted numbers and calculates like; '60'
                    varcalc = 1;
                    if(((VARone)==(1))&&((VARtwo)==(1))&&((VARthree)==(1)))//Runs calculation when there is only three variables
                      total = ((((One1)*(100) )+((Two2)*(10)))+(Three3));//Takes three inputted numbers and calculates like; '111'
                      varcalc = 1;
                      varcalc = 1;
              else//loop
                  analogWrite(5,255);
                  delay(11);
                  analogWrite(5,0);
                  delay((60000)/(total));//makes a delay, e.g. 60000/111 = 540.540540541ms
((Why) (have you) (got so (many)) ((unnecessary)parentheses))?
This is a new code version of V0.1
Code V0.2:
#include <Keypad.h>
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'#','0','*'}
int VARone = 0;
int VARtwo = 0 ;
int VARthree = 0;
int One1 = 0;
int Two2 = 0;
int Three3 = 0;
int total = 0;
int RUN = 0;
int varcalc = 1;
  pinMode(2,INPUT);
  pinMode(5,OUTPUT);
  pinMode(4,OUTPUT);
		Serial.println(total);
		if (digitalRead(2))//Reset Loop
			varcalc = 1;
			VARone = 0;
			VARtwo = 0;
			VARthree = 0;
			One1 = 0;
			Two2 = 0;
			Three3 = 0;
			total = 0;
			if((varcalc)==(1))//Keypad Loop
					if(key != NO_KEY)
						One1 = key;
						varcalc = 0;
						VARone = 1;
						if(key != NO_KEY)
							Two2 = key;
							varcalc = 0;
							VARtwo = 1;
							if(key != NO_KEY)
								Three3 = key;
								varcalc = 0;
								VARthree = 1;
						varcalc = 1;
							varcalc = 1;
								varcalc = 1;
								varcalc = 1;
				else//loop
					analogWrite(5,255);
					delay(11);
					analogWrite(5,0);
can be
if(varcalc==1)//Keypad Loop
can be
if((VARone==1)&&(VARtwo==1)&&(VARthree==1))
Tom..... :)
Code V0.2:
#include <Keypad.h>
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'#','0','*'}
int VARone = 0;
int VARtwo = 0 ;
int VARthree = 0;
int One1 = 0;
int Two2 = 0;
int Three3 = 0;
int total = 0;
  pinMode(2,INPUT);
  pinMode(5,OUTPUT);
  pinMode(4,OUTPUT);
      VARone = (0);
      VARtwo = (0);
      VARthree = (0);
      One1 = (0);
      Two2 = (0);
      Three3 = (0);
      total = (0);
		if(digitalRead(3))//Calculation loop
			if(VARone == 1)//Runs calculation when there is only one variable
				if((VARone == 1)&&(VARtwo == 1))//Runs calculation when there is only two variables
					if((VARone == 1)&&(VARtwo == 1)&&(VARthree== 1))//Runs calculation when there is only three variables
						total = ((((One1)*(100))+((Two2)*(10)))+(Three3));//Takes three inputted numbers and calculates like; '111'
		else//keypad loop
			Serial.println(One1);
			delay(11);
				if(key != NO_KEY)
					One1==(key);
					VARone==1;
				delay(11);
					if(key != NO_KEY)
						Two2==(key);
						VARtwo==1;
					delay(11);
						if(key != NO_KEY)
							Three3==(key);
							VARthree==1;
					else//loop
						analogWrite(5,255);
						delay(11);
						analogWrite(5,0);
Hello Everyone I am very grateful for the help and I have the full working code for you guys for this is a silent metronome which vibrates to a BPM and will help other people will find this useful. Thanks for this everyone… :slight_smile:
CODE PT.1? V.F
#include <Keypad.h>
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
int VARdelay = 0;
int VARone = 0;
int VARtwo = 0;
int VARthree = 0;
int One1 = 0;
int Two2 = 0;
int VARtotal = 0;
  pinMode(2,INPUT);
  pinMode(5,OUTPUT);
  pinMode(4,OUTPUT);
 if((VARone)==(0))//Variable One: Calcuation and keypad setting from 0-9
 delay(11);
 Serial.println(VARdelay);
 if (key)
 switch(key)
 case '#':
 VARone = 1;
 VARtwo = 1;
 VARthree =1;
 case '0'://set variable one to this number
 One1 = 0;
 VARdelay = 60000;//set delay
 VARone = 1;
 case '1'://set variable one to this number
 One1 = 1;
 VARdelay = ((60000)/(1));//set delay
 VARone = 1;
 case '2'://set variable one to this number
 One1 = 2;
 VARdelay = ((60000)/(2));//set delay
 VARone = 1;
 case '3'://set variable one to this number
 One1 = 3;
 VARdelay = ((60000)/(3));//set delay
 VARone = 1;
 case '4'://set variable one to this number
 One1 = 4;
 VARdelay = ((60000)/(4));//set delay
 VARone = 1;
 case '5'://set variable one to this number
 One1 = 5;
 VARdelay = ((60000)/(5));//set delay
 VARone = 1;
 case '6'://set variable one to this number
 One1 = 6;
 VARdelay = ((60000)/(6));//set delay
 VARone = 1;
 case '7'://set variable one to this number
 One1 = 7;
 VARdelay = ((60000)/(7));//set delay
 VARone = 1;
 case '8'://set variable one to this number
 One1 = 8;
 VARdelay = ((60000)/(8));//set delay
 VARone = 1;
 case '9'://set variable one to this number
 One1 = 9;
 VARdelay = ((60000)/(9));//set delay
 VARone = 1;
 if(((VARone)==(1))&&((VARtwo)==(0)))//Variable Two: Calculation and keypad setting from 0-9
 delay(11);
 if (key)
 switch (key)
 case '#':
 VARtwo = 1;
 VARthree =1;
 Two2 = 0;
 VARtotal = (((One1)*(10))+(0));//Caculation. If there is a previous calculation overwrite it
 VARdelay = ((60000)/(VARtotal));//Set delay. If there is a previous delay overwrite it
 VARtwo = 1;
 Two2 = 1;
 VARtotal = (((One1)*(10))+(1));//Caculation. If there is a previous calculation overwrite it
 VARtwo = 1;
 Two2 = 2;
 VARtotal = (((One1)*(10))+(2));//Caculation. If there is a previous calculation overwrite it
 VARtwo = 1;
 Two2 = 3;
 VARtotal = (((One1)*(10))+(3));//Caculation. If there is a previous calculation overwrite it
 VARtwo = 1;
 Two2 = 4;
 VARtotal = (((One1)*(10))+(4));//Caculation. If there is a previous calculation overwrite it
 VARtwo = 1;
 Two2 = 5;
 VARtotal = (((One1)*(10))+(5));//Caculation. If there is a previous calculation overwrite it
 VARtwo = 1;
 Two2 = 6;
 VARtotal = (((One1)*(10))+(6));//Caculation. If there is a previous calculation overwrite it
 VARtwo = 1;
 Two2 = 7;
 VARtotal = (((One1)*(10))+(7));//Caculation. If there is a previous calculation overwrite it
 VARtwo = 1;
 Two2 = 8;
 VARtotal = (((One1)*(10))+(8));//Caculation. If there is a previous calculation overwrite it
 VARtwo = 1;
 Two2 = 9;
 VARtotal = (((One1)*(10))+(9));//Caculation. If there is a previous calculation overwrite it
 VARtwo = 1;
 if(((VARone)==(1))&&((VARtwo)==(1))&&((VARthree)==(0)))//Variable Three: Calculation and keypad setting from 0-9
 delay(11);
 if (key)
 switch (key)
 case '#':
 VARthree = 1;
 VARtotal = (((One1)*(100))+((Two2)*(10))+(0));//Caculation. If there is a previous calculation overwrite it
 VARdelay =((60000)/(VARtotal));//Set delay. If there is a previous delay overwrite it
 VARthree = 1;
 VARtotal = (((One1)*(100))+((Two2)*(10))+(1));//Caculation. If there is a previous calculation overwrite it
 VARthree = 1;
 VARtotal = (((One1)*(100))+((Two2)*(10))+(2));//Caculation. If there is a previous calculation overwrite it
 VARthree = 1;
 VARtotal = (((One1)*(100))+((Two2)*(10))+(3));//Caculation. If there is a previous calculation overwrite it
 VARthree = 1;
 VARtotal = (((One1)*(100))+((Two2)*(10))+(4));//Caculation. If there is a previous calculation overwrite it
 VARthree = 1;
 VARtotal = (((One1)*(100))+((Two2)*(10))+(5));//Caculation. If there is a previous calculation overwrite it
 VARthree = 1;
 VARtotal = (((One1)*(100))+((Two2)*(10))+(6));//Caculation. If there is a previous calculation overwrite it
 VARthree = 1;
 VARtotal = (((One1)*(100))+((Two2)*(10))+(7));//Caculation. If there is a previous calculation overwrite it
 VARthree = 1;
 VARtotal = (((One1)*(100))+((Two2)*(10))+(8));//Caculation. If there is a previous calculation overwrite it
 VARthree = 1;
 VARtotal = (((One1)*(100))+((Two2)*(10))+(9));//Caculation. If there is a previous calculation overwrite it
 VARthree = 1;
 if(digitalRead(2))//Reset all int
 VARone = 0;
 VARtwo = 0;
 VARthree = 0;
 One1 = 0;
 Two2 = 0;
 VARtotal = 0;
 VARdelay = 0;
 Serial.println(1337);//LEET
 digitalWrite(5,HIGH);
 digitalWrite(4,255);
 delay(36);
 digitalWrite(4,0);
 digitalWrite(5,LOW);
 delay(VARdelay);
See reply #3.
