Help with college project
Hello everyone , thanks for all the efforts you guys rock but i need help. i want to write a code where the dose will happen say every 10 secs or 15 secs or 20 secs. for that on the menu we need to add another sub menu of interval where we can increase the interval from 0 secs to 99 secs and the dose will happen according to the interval entered. many thanks its for a project in college
Sudhir87: Hello everyone , thanks for all the efforts you guys rock but i need help. i want to write a code where the dose will happen say every 10 secs or 15 secs or 20 secs. for that on the menu we need to add another sub menu of interval where we can increase the interval from 0 secs to 99 secs and the dose will happen according to the interval entered. many thanks its for a project in college
It would be an idea to start your own post and describe what your project is.
Your project would appear to have nothing to do with Copying code from a UNO, so dont be surprised if you get no-responses here.
thanks for ur prompt response. basically i wanna do dosage of set volumes say 10 ml. after it pumps out 10 ml it should repeat the process every 5 secs or 10 secs until i turn of the pump. this is basically my project.
the interval i want to set it via the encoder . so the interval range i want it from say 0 secs to 100 secs then i enter the interval say 15 secs. after this the the pump will discharge the set volume every 15 secs.
Sudhir87: thanks for ur prompt response. basically i wanna do dosage of set volumes say 10 ml. after it pumps out 10 ml it should repeat the process every 5 secs or 10 secs until i turn of the pump. this is basically my project.
Are you asking for permission, or are you hinting that someone should do your home work for you?
Paul
