Can someone please help me to get a Colorduino running? The IDE complains about a library file.
There are several libraries for the Colorduino but each one has failed me in one way or another. The most recent seems to be Colorduino_GFX at GitHub - DinoTools/Colorduino_GFX. This also requires the Adafruit_GFX library GitHub - adafruit/Adafruit-GFX-Library: Adafruit GFX graphics core Arduino library, this is the 'core' class that all our other graphics libraries derive from. The Colorduino is marked V2.0 geeetech.com but there is nothing on that website. I have it connected to FTDI adapter with the IDE set to Nano. The IDE talks to the Colorduino.
None of the examples work. The IDE returns this message:
In file included from sketch_sep30a.ino:4:0:
C:\Users\Karl\Box Sync\Arduino\libraries\Colorduino_GFX/Colorduino_GFX.h:37:12: warning: missing whitespace after the macro name [enabled by default]
#define RST* portOutputRegister(digitalPinToPort(A0))
C:\Users\Karl\Box Sync\Arduino\libraries\Colorduino_GFX/Colorduino_GFX.h:38:12: warning: missing whitespace after the macro name [enabled by default]
#define LAT* portOutputRegister(digitalPinToPort(A1))
C:\Users\Karl\Box Sync\Arduino\libraries\Colorduino_GFX/Colorduino_GFX.h:39:12: warning: missing whitespace after the macro name [enabled by default]
#define SLB* portOutputRegister(digitalPinToPort(A2))
C:\Users\Karl\Box Sync\Arduino\libraries\Colorduino_GFX/Colorduino_GFX.h:40:12: warning: missing whitespace after the macro name [enabled by default]
#define SCL* portOutputRegister(digitalPinToPort(6))
C:\Users\Karl\Box Sync\Arduino\libraries\Colorduino_GFX/Colorduino_GFX.h:41:12: warning: missing whitespace after the macro name [enabled by default]
#define SDA* portOutputRegister(digitalPinToPort(7))
In file included from C:\Users\Karl\Box Sync\Arduino\libraries\Colorduino_GFX\Colorduino_GFX.cpp:22:0:
C:\Users\Karl\Box Sync\Arduino\libraries\Colorduino_GFX\Colorduino_GFX.h:37:12: warning: missing whitespace after the macro name [enabled by default]
C:\Users\Karl\Box Sync\Arduino\libraries\Colorduino_GFX\Colorduino_GFX.h:38:12: warning: missing whitespace after the macro name [enabled by default]
C:\Users\Karl\Box Sync\Arduino\libraries\Colorduino_GFX\Colorduino_GFX.h:39:12: warning: missing whitespace after the macro name [enabled by default]
C:\Users\Karl\Box Sync\Arduino\libraries\Colorduino_GFX\Colorduino_GFX.h:40:12: warning: missing whitespace after the macro name [enabled by default]
C:\Users\Karl\Box Sync\Arduino\libraries\Colorduino_GFX\Colorduino_GFX.h:41:12: warning: missing whitespace after the macro name [enabled by default]
Sketch uses 6,768 bytes (22%) of program storage space. Maximum is 30,720 bytes.
Global variables use 112 bytes (5%) of dynamic memory, leaving 1,936 bytes for local variables. Maximum is 2,048 bytes.
Here is the sketch:
//Include all required libraries first.
#include <Adafruit_GFX.h>
#include <Colorduino_GFX.h>
//Create a new Colorduino instance.
ColorduinoPanel Colorduino;
//Initialize the Colorduino and set the white-balance in the setup() function.
Colorduino.init();
Colorduino.setWhiteBalance(36, 63, 63);
//Now the Colorduino is ready to use.
GFX_Color_t color = Colorduino.color(255, 0, 0);
Colorduino.drawLine(0, 0, 7, 7, color);
Colorduino.swapBuffers(true);
