help with compiling errors [solved]
Hi there,
I'm new to this forum and arduino so be gentle. I'm trying to turn on and off 2 motors at certain times of the day and I'm using the time.h and timealarm.h libraries in my sketch, but when i try to compile it I get "Error compiling." message. even if I try to compile the example included in the library i get the errors. The errors are:
c:\Program Files\arduino-1.0.1\libraries\TimeAlarms\TimeAlarms.cpp: In member function 'void TimeAlarmClass::delay(long unsigned int)':
c:\Program Files\arduino-1.0.1\libraries\TimeAlarms\TimeAlarms.cpp:167: error: 'millis' was not declared in this scope
c:\Program Files\arduino-1.0.1\libraries\TimeAlarms\TimeAlarms.cpp: At global scope:
c:\Program Files\arduino-1.0.1\libraries\TimeAlarms\TimeAlarms.cpp:223: error: 'boolean' has not been declared
c:\Program Files\arduino-1.0.1\libraries\TimeAlarms\TimeAlarms.cpp:223: error: prototype for 'AlarmID_t TimeAlarmClass::create(time_t, voide () (), int, int, int)' does not match any class 'TimeAlarmClass'
c:\Program Files\arduino-1.0.1\libraries\TimeAlarms\TimeAlarms/TimeAlarm.h:49: error: candidate is AlarmID_t TimeAlarmClass::create(time_t, void (
)(), unit8_t, unit8_t, unit8_t)
thanks for any help you can provide
Did you read point 2 of "Read this before posting a programming question ..."?
thanks
I'll try that.
Thanks again WizenedEE that did the trick.
