I am working with a nice display SCD 55104A, data sheet here: http://www.mouser.com/ds/2/311/0.145%20%20%20%20%2010-Character%205x5%20Dot%20Matrix%20Serial%20Input-335490.pdf)
I found a good 5x5 font to use, but I can only write up to the letter ‘T’ with the approach I cam using.
Here is my code:
// standard ascii 5x5 font
static unsigned char Font5x5[] = {
0x00, 0x20, 0x40, 0x60, 0x80,
0x04, 0x24, 0x44, 0x60, 0x84,
0x0A, 0x2A, 0x40, 0x60, 0x80,
0x0A, 0x3F, 0x4A, 0x7F, 0x8A,
The idea is to get the five hex codes from the array and send them out to the display.
When I get to the part in this code where I expect to write ‘X’, I get a messy blob of a character on the display.
I expect the serial output to be
11
2A
44
6A
91
instead I get:
9E
19
3A
44
6B
I’ve probably left out crucial details, or made a silly mistake here. If anyone can help, I really appreciate it.
Thanks.
0x0F, 0x34, 0x4E, 0x65, 0x9E,
0x19, 0x3A, 0x44, 0x6B, 0x93,
0x08, 0x34, 0x4D, 0x72, 0x8D,
0x04, 0x24, 0x40, 0x60, 0x80,
0x02, 0x24, 0x44, 0x64, 0x82,
0x08, 0x24, 0x44, 0x64, 0x88,
0x15, 0x2E, 0x5F, 0x6E, 0x95,
0x04, 0x24, 0x5F, 0x64, 0x84,
0x00, 0x20, 0x40, 0x64, 0x84,
0x00, 0x20, 0x4E, 0x60, 0x80,
0x00, 0x20, 0x40, 0x60, 0x84,
0x01, 0x22, 0x44, 0x68, 0x90,
// ’ 0 ':
0x0E, 0x33, 0x55, 0x79, 0x8E,
// ’ 1 ':
0x04, 0x2C, 0x44, 0x64, 0x8E,
// ’ 2 ':
0x1E, 0x21, 0x46, 0x68, 0x9F,
// ’ 3 ':
0x1E, 0x21, 0x4E, 0x61, 0x9E,
// ’ 4 ':
0x06, 0x2A, 0x5F, 0x62, 0x82,
// ’ 5 ':
0x1F, 0x30, 0x5E, 0x61, 0x9E,
// ’ 6 ':
0x06, 0x28, 0x5E, 0x71, 0x8E,
// ’ 7 ':
0x1F, 0x22, 0x44, 0x68, 0x88,
// ’ 8 ':
0x0E, 0x31, 0x4E, 0x71, 0x8E,
// ’ 9 ':
0x0E, 0x31, 0x4F, 0x62, 0x8C,
0x00, 0x24, 0x40, 0x64, 0x80,
0x00, 0x24, 0x40, 0x6C, 0x80,
0x02, 0x24, 0x48, 0x64, 0x82,
0x00, 0x3F, 0x40, 0x7F, 0x80,
0x08, 0x24, 0x42, 0x64, 0x88,
0x0E, 0x31, 0x42, 0x64, 0x84,
0x0E, 0x35, 0x57, 0x70, 0x8E,
// ‘A’:
0x04, 0x2A, 0x5F, 0x71, 0x91,
// ‘B’:
0x1E, 0x29, 0x4E, 0x69, 0x9E,
// ‘C’:
0x0F, 0x30, 0x50, 0x70, 0x8F,
// ‘D’:
0x1E, 0x29, 0x49, 0x69, 0x9E,
// ‘E’:
0x1F, 0x30, 0x5E, 0x70, 0x9F,
// ‘F’:
0x1F, 0x30, 0x5E, 0x70, 0x90,
// ‘G’:
0x0F, 0x30, 0x53, 0x71, 0x8F,
// ‘H’:
0x11, 0x31, 0x5F, 0x71, 0x91,
// ‘I’:
0x0E, 0x24, 0x44, 0x64, 0x8E,
// ‘J’:
0x01, 0x21, 0x41, 0x71, 0x8E,
// ‘K’:
0x13, 0x34, 0x58, 0x74, 0x93,
// ‘L’:
0x10, 0x30, 0x50, 0x70, 0x9F,
// ‘M’:
0x11, 0x3B, 0x55, 0x71, 0x91,
// ‘N’:
0x11, 0x39, 0x55, 0x73, 0x91,
// ‘O’:
0x0E, 0x31, 0x51, 0x71, 0x8E,
// ‘P’:
0x1E, 0x31, 0x5E, 0x70, 0x90,
// ‘Q’:
0x0C, 0x32, 0x56, 0x72, 0x8D,
// ‘R’:
0x1E, 0x31, 0x5E, 0x74, 0x92,
// ‘S’:
0x0F, 0x30, 0x4E, 0x61, 0x9E,
// ‘T’:
0x1F, 0x24, 0x44, 0x64, 0x84,
// ‘U’:
0x11, 0x31, 0x51, 0x71, 0x8E,
// ‘V’:
0x11, 0x31, 0x51, 0x6A, 0x84,
// ‘W’:
0x11, 0x31, 0x55, 0x7B, 0x91,
// ‘X’:
0x11, 0x2A, 0x44, 0x6A, 0x91,
// ‘Y’:
0x11, 0x2A, 0x44, 0x64, 0x84,
// ‘Z’:
0x1F, 0x22, 0x44, 0x68, 0x9F,
0x07, 0x24, 0x44, 0x64, 0x87,
0x10, 0x28, 0x44, 0x62, 0x81,
0x1C, 0x24, 0x44, 0x64, 0x9C,
0x04, 0x2A, 0x51, 0x60, 0x80,
// ‘_’:
0x00, 0x20, 0x40, 0x60, 0x9F,
// ‘a’:
0x00, 0x2E, 0x52, 0x72, 0x8D,
// ‘b’:
0x10, 0x30, 0x5E, 0x71, 0x9E,
// ‘c’:
0x00, 0x2F, 0x50, 0x70, 0x8F,
// ‘d’:
0x01, 0x21, 0x4F, 0x71, 0x8F,
// ‘e’:
0x00, 0x2E, 0x5F, 0x70, 0x8E,
// ‘f’:
0x04, 0x2A, 0x48, 0x7C, 0x88,
// ‘g’:
0x00, 0x2F, 0x50, 0x73, 0x8F,
// ‘h’:
0x10, 0x30, 0x56, 0x79, 0x91,
// ‘i’:
0x04, 0x20, 0x4C, 0x64, 0x8E,
// ‘j’:
0x00, 0x26, 0x42, 0x72, 0x8C,
// ‘k’:
0x10, 0x30, 0x56, 0x78, 0x96,
// ‘l’:
0x0C, 0x24, 0x44, 0x64, 0x8E,
// ‘m’:
0x00, 0x2A, 0x55, 0x71, 0x91,
// ‘n’:
0x00, 0x36, 0x59, 0x71, 0x91,
// ‘o’:
0x00, 0x2E, 0x51, 0x71, 0x8E,
// ‘p’:
0x00, 0x3E, 0x51, 0x7E, 0x90,
// ‘q’:
0x00, 0x2F, 0x51, 0x6F, 0x81,
// ‘r’:
0x00, 0x33, 0x54, 0x78, 0x90,
// ‘s’:
0x00, 0x23, 0x44, 0x62, 0x8C,
// ‘t’:
0x08, 0x3C, 0x48, 0x6A, 0x84,
// ‘u’:
0x00, 0x32, 0x52, 0x72, 0x8D,
// ‘v’:
0x00, 0x31, 0x51, 0x6A, 0x84,
// ‘w’:
0x00, 0x31, 0x55, 0x7B, 0x91,
// ‘x’:
0x00, 0x32, 0x4C, 0x6C, 0x92,
// ‘y’:
0x00, 0x31, 0x4A, 0x64, 0x98,
// ‘z’:
0x00, 0x3E, 0x44, 0x68, 0x9E,
0x06, 0x24, 0x48, 0x64, 0x86,
0x04, 0x24, 0x44, 0x64, 0x84,
0x0C, 0x24, 0x42, 0x64, 0x8C,
0x00, 0x27, 0x5C, 0x60, 0x80,
// Pin connections to display
const int loadPin = 7;
const int sdataPin = 8;
const int sdclkPin = 9;
void setup(){
//pull RST and CLKSEL HIGH
pinMode(3, OUTPUT);
digitalWrite(3, HIGH);
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
void writeByte(const char a) {
digitalWrite(loadPin, LOW);
for (int b = 0; b <= 7; b++) {
digitalWrite(sdataPin, bitRead(a, b));
digitalWrite(sdclkPin, HIGH);
digitalWrite(sdclkPin, LOW);
digitalWrite(loadPin, HIGH);
void writeChar(byte c){
byte d = (c - 0x20) *5;
for (int i = 0; i < 5; i++) {
writeByte(Font5x5[d + i]);
Serial.println(Font5x5[d + i], HEX);
void displayChar(const char myChar, int myPos){
switch(myPos){
case 0:
writeByte(0xB0);
case 1:
writeByte(0xB1);
case 2:
writeByte(0xB2);
case 3:
writeByte(0xB3);
case 4:
writeByte(0xB4);
case 5:
writeByte(0xB5);
case 6:
writeByte(0xB6);
case 7:
writeByte(0xB7);
case 8:
writeByte(0xB8);
case 9:
writeByte(0xB9);
writeChar(myChar);
void displayBegin()
pinMode(loadPin, OUTPUT);
pinMode(sdataPin, OUTPUT);
pinMode(sdclkPin, OUTPUT);
//reset the display
writeByte(0xC0);
void loop(){
displayBegin();
displayChar(‘A’, 0);
displayChar(‘B’, 1);
//THIS DOESN’T WORK
displayChar(‘X’, 2);
displayChar(‘1’, 3);
displayChar(‘S’, 4);
displayChar(‘T’, 5);
displayChar(‘M’, 6);
//move to digit 9
writeByte(0xB9);
//and write a “Z”
writeByte(0x1F);
writeByte(0x22);
writeByte(0x44);
writeByte(0x68);
writeByte(0x9F);
delay(10000);
When I get to the part in this code where I expect to write 'X', I get a messy blob of a character on the display.
11
2A
44
6A
91
instead I get:
9E
19
3A
44
6B
I've probably left out crucial details, or made a silly mistake here. If anyone can help, I really appreciate it.
Thanks.
