Help with controlling PIR and Stepper
Not sure whats wrong with my code. Please help
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0;
#include <Servo.h>
Servo myservo;
int pos = 0;//variable for reading the pin status
int count = 1;
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
if (pirState == LOW) { // we have just turned on
Serial.println("Motion detected!"); // We only want to print on the output change, not state
pirState = HIGH;
if (count == 1) {
for (pos = 0; pos <= 90; pos += 1) { // goes from 0 degrees to 180 degrees
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15);
count == 2;
if (count == 2){
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
delay(15);
count ==5;// waits 15ms for the servo to reach the position
else {
digitalWrite(ledPin, LOW); // turn LED OFF
if (pirState == HIGH){
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
It does something. You need to tell us what it does.
You expect it to do something. You need to tell us what you expect.
By the way, you can't control a PIR sensor. They do what they want, despite your best efforts to control them.
YOLOLJJ:
          count == 2;
This line does nothing useful. It compares 'count' to 2 and ignores the result. That is why the servo always sweeps from 0 to 90. If you fix this (use "count = 2;") the servo will sweep from 0 to 90, jump from 90 to 180 and then sweep to 0. It will then only jump from 0 to 180 and then sweep to 0.
          count == 5;
This line does nothing useful. It compares 'count' to 5 and ignores the result. If you change it to "count = 5;" the servo will never move again. If you change it to "count = 1;" the servo will go back to sweeping from 0 to 90, jumping from 90 to 180 and then sweeping to 0.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
