Hi everyone, I am trying to make a project with 4 servos and WS2812 Led strips. I managed to get the Led strips to work, though when I add the servo code, the servos tend to jitter like crazy. When I have the servo code alone, they work just fine. I did some research and it seems like it's something with the timing of WS2812 chips. Though, as I am just starting out with programming, I have no idea what I should do to fix this. Any help would be appreciated.
#include "ServoCos.h"
#include "FastLED.h"
#define LED_PIN 5
#define COLOR_ORDER GRB
#define CHIPSET WS2812
#define NUM_LEDS 37
#define BRIGHTNESS 200
#define FRAMES_PER_SECOND 60
bool gReverseDirection = false;
CRGB leds[NUM_LEDS];
CRGBPalette16 gPal;
ServoCos HeadServo;
ServoCos HeadServo2;
int SweepDirection=1;
delay(3000); // sanity delay
FastLED.addLeds<CHIPSET, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( BRIGHTNESS );
// This first palette is the basic 'black body radiation' colors,
// which run from black to red to bright yellow to white.
//gPal = HeatColors_p;
// These are other ways to set up the color palette for the 'fire'.
// First, a gradient from black to red to yellow to white -- similar to HeatColors_p
// gPal = CRGBPalette16( CRGB::Black, CRGB::Red, CRGB::Yellow, CRGB::White);
// Second, this palette is like the heat colors, but blue/aqua instead of red/yellow
gPal = CRGBPalette16( CRGB::Black, CRGB::Blue, CRGB::Aqua, CRGB::White);
// Third, here's a simpler, three-step gradient, from black to red to white
// gPal = CRGBPalette16( CRGB::Black, CRGB::Red, CRGB::White);
HeadServo.attach(9);
HeadServo2.attach(10);
HeadServo2.attach(11);
HeadServo2.attach(12);
servo1();
// servo2();
fire();
void servo1() {
if(HeadServo.hasStopped()){// there is also .isMoving()
if(SweepDirection==1){
SweepDirection=-1;
HeadServo.setupEase(160,1500);
SweepDirection=1;
HeadServo.setupEase(0,1500);
HeadServo.updatePosition();
Second Tab
void fire()
// Add entropy to random number generator; we use a lot of it.
random16_add_entropy( random());
// run simulation frame, using palette colors
Fire2012WithPalette();
FastLED.show(); // display this frame
FastLED.delay(1000 / FRAMES_PER_SECOND);
// Fire2012 by Mark Kriegsman, July 2012
// as part of "Five Elements" shown here: http://youtu.be/knWiGsmgycY
// Default 55, suggested range 20-100
#define COOLING 55
// SPARKING: What chance (out of 255) is there that a new spark will be lit?
// Higher chance = more roaring fire. Lower chance = more flickery fire.
// Default 120, suggested range 50-200.
#define SPARKING 120
void Fire2012WithPalette()
// Array of temperature readings at each simulation cell
static byte heat[NUM_LEDS];
// Step 1. Cool down every cell a little
for( int i = 0; i < NUM_LEDS; i++) {
heat[i] = qsub8( heat[i], random8(0, ((COOLING * 10) / NUM_LEDS) + 2));
// Step 2. Heat from each cell drifts 'up' and diffuses a little
for( int k= NUM_LEDS - 1; k >= 2; k--) {
heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2] ) / 3;
// Step 3. Randomly ignite new 'sparks' of heat near the bottom
if( random8() < SPARKING ) {
int y = random8(7);
heat[y] = qadd8( heat[y], random8(160,255) );
// Step 4. Map from heat cells to LED colors
for( int j = 0; j < NUM_LEDS; j++) {
// Scale the heat value from 0-255 down to 0-240
// for best results with color palettes.
byte colorindex = scale8( heat[j], 240);
CRGB color = ColorFromPalette( gPal, colorindex);
int pixelnumber;
if( gReverseDirection ) {
pixelnumber = (NUM_LEDS-1) - j;
pixelnumber = j;
leds[pixelnumber] = color;
