Help with converting Byte to Int
Ok so I have two arduino's setup with Xbees. One is sending to the other like this:
char buffer[128]
char buffer1[128]
char buffer2[128] //The function requires that they are char[]
if(Canbus.ecu_req(ENGINE_COOLANT_TEMP,buffer1) == 1)
if(Canbus.ecu_req(ENGINE_RPM,buffer2) == 1) //this stores the values in buffer1 and buffer2
sprintf(buffer,"%d%,d%,d%,%d;) // when i print
serial.println(buffer);
On my receiving arduino i figured out how to convert this into the integer value, however i can only manage to do this with the first number and then once it detects a comma it ignores the rest because of the atoi function:
int serReadInt()
 int i, serAva;                           // i is a counter, serAva hold number of serial available
 char inputBytes [7];                 // Array hold input bytes
 char * inputBytesPtr = &inputBytes[0];  // Pointer to the first element of the array
 if (Serial.available()>0)            // Check to see if there are any serial input
   delay(5);                              // Delay for terminal to finish transmitted
                                              // 5mS work great for 9600 baud (increase this number for slower baud)
   serAva = Serial.available();  // Read number of input bytes
   for (i=0; i<serAva; i++)       // Load input bytes into array
     inputBytes[i] = Serial.read();
   inputBytes[i] =  '\0';             // Put NULL character at the end
   return atoi(inputBytesPtr);    // Call atoi function and return result
   return -1;                           // Return -1 if there is no input
Is there any way that I can take the buffer string and take each number separated by comma out individually?
Moderator edit: [code] ... [/code] tags added. (Nick Gammon)
One simple idea when capturing from the serial port:
//zoomkat 3-5-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
// CR/LF could also be a delimiter
String readString;
  Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
  //expect a string like wer,qwe rty,123 456,hyre kjhg,
  //or like hello world,who are you?,bye!,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      //do stuff
      Serial.println(readString); //prints string to serial port out
      readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
