jremington:
Be sure that the OLED display is working properly, before implementing sleep functions.
It is working now! It was drawing 7ma awake, and now it is down to 3ma - I still have the power led which I suspect draws 2ma or so.
However, a new problem has appeared: When I have the arduino in sleep mode, I push the button once and it wakes up, and I have to push it again to register a push according to the loop. I would like to modify it so that if it is asleep, I push it once and it wakes it up and registers it as a push, both with just one push of button. How could I modify my code?
This is the final code that worked:
//Library for sleeping
#include <avr/sleep.h>
//Library for Display - Can skip it if you want!
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH 16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
B00000001, B11000000,
B00000011, B11100000,
B11110011, B11100000,
B11111110, B11111000,
B01111110, B11111111,
B00110011, B10011111,
B00011111, B11111100,
B00001101, B01110000,
B00011011, B10100000,
B00111111, B11100000,
B00111111, B11110000,
B01111100, B11110000,
B01110000, B01110000,
B00000000, B00110000 };
#if (SSD1306_LCDHEIGHT != 32)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
String activity1 = "Work";
//Variable setup fot Debounce
int debounceCounter111 = 0;
int buttonState;
int lastButtonState = HIGH;
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50;
//ISR to call when button is pressed and wants to interrupt.
void wake ()
sleep_disable();
detachInterrupt (0);
//Function to send it to sleep.
void sleep()
// disable ADC
ADCSRA = 0;
set_sleep_mode (SLEEP_MODE_PWR_DOWN);
sleep_enable();
// Do not interrupt before we go to sleep, or the
// ISR will detach interrupts and we won't wake.
noInterrupts ();
// will be called when pin D2 goes low
attachInterrupt (0, wake, FALLING);
EIFR = bit (INTF0); // clear flag for interrupt 0
// turn off brown-out enable in software
// BODS must be set to one and BODSE must be set to zero within four clock cycles
MCUCR = bit (BODS) | bit (BODSE);
// The BODS bit is automatically cleared after three clock cycles
MCUCR = bit (BODS);
// We are guaranteed that the sleep_cpu call will be done
// as the processor executes the next instruction after
// interrupts are turned on.
interrupts (); // one cycle
sleep_cpu (); // one cycle
//Display text on screen fucntion - You can skip.
void displayText(String activityName)
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(10,0);
display.clearDisplay();
display.println(activityName);
display.display();
delay(1100);
display.display();
//Button Varibale int
int buttonTwo = 2;
///////++++++++++++++++++++SETUP++++++++++++++++++++++///
void setup ()
//digitalWrite (2, HIGH); // enable pull-up
pinMode(buttonTwo, INPUT_PULLUP);
//DISPLAY SETUP - You can skip
// by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3D (for the 128x64)
// init done
// Show image buffer on the display hardware.
// Since the buffer is intialized with an Adafruit splashscreen
// internally, this will display the splashscreen.
display.display();
delay(2000);
// Clear the buffer.
display.display();
//+++++++++++++++++++++++++++++LOOP+++++++++++++++++++++++++++//
int reading = digitalRead(buttonTwo);
if (reading != lastButtonState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
buttonState = reading;
if (buttonState == LOW) {
++debounceCounter111;
if (debounceCounter111 > 3){
debounceCounter111 = 1;
displayText("Activity 1");
sleep();
if (debounceCounter111 == 1){
// Code to display something on OLEd
displayText(activity1);
sleep();
if (debounceCounter111 == 2){
sleep();
if (debounceCounter111 == 3){
sleep();
lastButtonState = reading;
Jiggy-Ninja:
What troubleshooting have you done for the individual parts of the code?
- Is the button wired properly?
- Have you verified that the OLED can display something with a simple sketch (just print text to it an nothing else)?
- Does the sketch work without the sleep functions?
Thanks for your suggestions; I managed to make it work btu have a new problem! See above
