Help with cos and sin opreation
Hello everyone, I am a beigneer to the Arduino world.
I am trying to find the tilt angle with this code below using MPU 6050.
My problem start at when I try to multiply the cos(pitch)*cos(roll), for the assigned variable ""sqrt1""
Here is the code :
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
float CD,m,t,p,v,A_i,A,g,D,yaw,pitch,roll,t_angle,sqrt1,sqrt2,sqrt3,sqrt12;
// packet structure for InvenSense teapot demo
uint8_t teapotPacket[14] = { '
And here is the error I got :
'cos(((double)pitch))' cannot be used as a member pointer, since it is of type 'double'
[/code]
Any help would be really appreciated, 0x02, 0,0, 0,0, 0,0, 0,0, 0x00, 0x00, '\r', '\n' };
// track FIFO count here in case there is > 1 packet available
       // (this lets us immediately read more without waiting for an interrupt)
       fifoCount -= packetSize;
#ifdef OUTPUT_READABLE_QUATERNION
           // display quaternion values in easy matrix form: w x y z
           mpu.dmpGetQuaternion(&q, fifoBuffer);
           Serial.print("quat\t");
           Serial.print(q.w);
           Serial.print("\t");
           Serial.print(q.x);
           Serial.print("\t");
           Serial.print(q.y);
           Serial.print("\t");
           Serial.println(q.z);
       #endif
#ifdef OUTPUT_READABLE_EULER
           // display Euler angles in degrees
           mpu.dmpGetEuler(euler, &q);
           Serial.print("euler\t");
           Serial.print(euler[0] * 180/M_PI);
           Serial.print("\t");
           Serial.print(euler[1] * 180/M_PI);
           Serial.print("\t");
           Serial.println(euler[2] * 180/M_PI);
       #endif
#ifdef OUTPUT_READABLE_YAWPITCHROLL
           mpu.dmpGetGravity(&gravity, &q);
           mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
           Serial.print("ypr\t");
           Serial.print(ypr[0] * 180/M_PI);  // x - z
           Serial.print("\t");
           Serial.print(ypr[1] * 180/M_PI); // y - y
           Serial.print("\t");
           Serial.println(ypr[2] * 180/M_PI); // z - x
 CD=0.9;
 p=1.225;
 m=2;
 g=9.81;
 A_i=0.0244958;
 yaw=ypr[0] ;
 pitch=ypr[1];
 roll=ypr[2];
sqrt1=(cos(roll).*cos(pitch));
sqrt2=(cos(roll).*sin(pitch));
sqrt3=(cos(pitch).*sin(roll));
t_angle= double 180-acos(((ypr[2]).*cos(pitch))./sqrt((pow(sqrt1,2))+(pow(sqrt2,2))+(pow(sqrt3,2))));
Serial.print("tilt angle \t");
Serial.print(t_angle * 180/M_PI);
//Serial.println("t angle =");
  //Serial.println(v);
 //D=mgtan(t);
 //v=sqrt((2D)/(pA*CD));
 //Serial.print("wind speed =");
       #endif
#ifdef OUTPUT_READABLE_REALACCEL
           // display real acceleration, adjusted to remove gravity
           mpu.dmpGetAccel(&aa, fifoBuffer);
           mpu.dmpGetLinearAccel(&aaReal, &aa, &gravity);
           Serial.print("areal\t");
           Serial.print(aaReal.x);
           Serial.print("\t");
           Serial.print(aaReal.y);
           Serial.print("\t");
           Serial.println(aaReal.z);
       #endif
#ifdef OUTPUT_READABLE_WORLDACCEL
           // display initial world-frame acceleration, adjusted to remove gravity
           // and rotated based on known orientation from quaternion
           mpu.dmpGetLinearAccelInWorld(&aaWorld, &aaReal, &q);
           Serial.print("aworld\t");
           Serial.print(aaWorld.x);
           Serial.print("\t");
           Serial.print(aaWorld.y);
           Serial.print("\t");
           Serial.println(aaWorld.z);
       #endif
       #ifdef OUTPUT_TEAPOT
           // display quaternion values in InvenSense Teapot demo format:
           teapotPacket[2] = fifoBuffer[0];
           teapotPacket[3] = fifoBuffer[1];
           teapotPacket[4] = fifoBuffer[4];
           teapotPacket[5] = fifoBuffer[5];
           teapotPacket[6] = fifoBuffer[8];
           teapotPacket[7] = fifoBuffer[9];
           teapotPacket[8] = fifoBuffer[12];
           teapotPacket[9] = fifoBuffer[13];
           Serial.write(teapotPacket, 14);
           teapotPacket[11]++; // packetCount, loops at 0xFF on purpose
       #endif
// blink LED to indicate activity
       blinkState = !blinkState;
       digitalWrite(LED_PIN, blinkState);
[/code]
What is the period "." doing in the following statement, among others?
This is a very complicated program for a beginner. We recommend that you start with the basic examples, in order to learn the programming language and the special features of the Arduino.
There’s two more errant dot operators here…
I hope Mr Remington was trying to make a joke. It’s obviously not an attempt at class pointer manipulation, just a few extra dots where they should not be.
The noble "." is not a joking matter. Period.
:slight_smile:
