Hi im new to arduino Code, i am trying to learn it because no one can help me with making a code so i'am trying to learn, i have a project that needs the following task, its a blaster "Andor" i need a switch to turn on two led's simultaneously by each switch click from low bright to Medium and high and righ after the last click a motor turning 180 degrees, and again three clicks leds same functions but this time motor turning 180 degrees in reverse.
I hope i made sense, its not a visual complicated task but its very difficult for me on code, any help would be extremely apriciated...
I will come back here for future updates if i manage to break the code, meaning figure this out myself.
No, im basically a noob, just been seeing few tutorials to get the basics, i know with a litte push a can Jumpstart into it, im a quick learner just trying to get myself started.
Welcome! I would suggest you do a few tutorials on basic electronics as well as the Arduino. That will help a lot. Probably the best investment is to get a copy of the Arduino Cookbook, it has a lot of what you are trying to do.
Let us know how you are doing. We all started where you are so what you do not understand is shared by millions of others in the same boat.
