Help with custom characters and AD5110
Right first things first Hi! I am long time lurker who finally has a question that has bewildered me.
const byte Sad[8] PROGMEM = {
  B00000,
  B01010,
  B01010,
  B00000,
  B00100,
  B00000,
  B01110,
  B10001
const byte Happy[8] PROGMEM = {
  B00000,
  B01010,
  B01010,
  B00000,
  B00100,
  B10001,
  B01110,
  B00000
  lcd.createChar_P(0, Sad);
  lcd.createChar_P(1, Happy);
 //loads of other stuff
lcd.clear(); // Clear lcd.
  lcdLine1 = "Power LED on?"; // Store last message sent to lcd
  lcd.setCursor(justify(lcdLine1), 0); // set cursor to the center of the screen.
  lcd.print(lcdLine1); // Write to lcd.
  digitalWrite(AuxEn, HIGH); // Turn on aux pcb.
  buttonPress(); // Call function
  // What was pressed.
  switch (Pressed) {
    case Yes:
      lcd.backlight(); // Turn backlight on.
      lcd.setCursor(justify("Great!"), 0); // set cursor to the center of the screen.
      lcd.print("Great!"); // Write to lcd.
      lcd.setCursor(7, 1); // Set to center
      lcd.write(1); // print smiley
      passed[0] = true; // Store result in array.
      delay(1000); // Delay for 1s.
    case No:
      lcd.setCursor(justify("Oh no!"), 0); // set cursor to the center of the screen.
      lcd.print("Oh no!"); // Write to lcd.
      lcd.write(0); // print smiley
      passed[0] = false; // Store result in array.
int justify(String string) {
  int x;
  x = 8 - (string.length() / 2);
  return x;
// If timed out wait for action, turn off backlight and aux board.
void timedOut() {
  // If timed out ask to continue.
  while (1) {
    // Was yes button pressed and not input.
    debouncerYes.update();
    if (input == false && debouncerYes.fell()) {
      lcd.print(lcdLine1); // Reprint the last message sent to lcd.
      lcd.setCursor(justify(lcdLine2), 1); // set cursor to the center of the screen.
      lcd.print(lcdLine2); // Reprint the last message sent to lcd.
      startMillis = currentMillis; // Store previous trigger time.
      digitalWrite(AuxEn, HIGH); // Turn Aux board back on.
      return;
    if (input == true && debouncerYes.fell()) {
      inputFailed = true;
      startMillis = millis(); // Account for current time
      return;
    // Was no button pressed.
    debouncerNo.update();
    if (input == false && debouncerNo.fell()) {
      asm volatile ("  jmp 0"); // Reset.
      return;
    if (input == true && debouncerNo.fell()) {
      inputFailed = false;
      return;
// Wait for button input, polling both buttons will time out in milliseconds (1000 = 1s).
void buttonPress() {
  // Loop until returned.
  while (1) {
    currentMillis = millis(); // Current up time.
    if (currentMillis - startMillis >= timeOut && input == false) {
      lcd.noBacklight(); // Turn backlight off.
      lcd.setCursor(justify("Yes to continue"), 0); // set cursor to the center of the screen.
      lcd.print("Yes to continue"); // Write to lcd.
      lcd.setCursor(justify("No to restart"), 1); // set cursor to the center of the screen.
      lcd.print("No to restart"); // Write to lcd.
      digitalWrite(AuxEn, LOW); // Turn of power to DUT.
      timedOut(); // Call timedOut
    if (currentMillis - startMillis >= timeOut && input == true) {
      lcd.setCursor(justify("Did to attempt?"), 0); // set cursor to the center of the screen.
      lcd.print("Did to attempt?"); // Write to lcd.
    // Was yes button pressed.
      Pressed = Yes; // Return yes enum.
      return;
      Pressed = No; // Return no enum.
      return;
    // Was touch triggered.
    debouncerTouch.update();
    if (input == true && debouncerTouch.fell()) {
      Pressed = Pad; // Return touched enum.
      return;
    // Was hall1 triggered.
    debouncerHall1.update();
    if (input == true && debouncerHall1.fell()) {
      Pressed = Pos1; // Return Pos1 enum.
      return;
    debouncerHall2.update();
    if (input == true && debouncerHall2.fell()) {
      Pressed = Pos2; // Return Pos2 enum.
      return;
    // Did input fail.
    if (input == true && inputFailed == true) {
      Pressed = Failed; // Return failed enum.
      return;
My first question is regardless of whether i write 0 or 1 i always get a smiley face, why?
Second question anyone got a library for the AD5110 or can help me figure out how to talk to it?
Full code here.
I don't see where you defined "Yes" or "No". This can't be the whole sketch.
on the pastebin link
// define ButtonPressed enum
enum ButtonPressed {
  Yes,
  No,
  Pad,
  Pos1,
  Pos2,
  Failed
} Pressed; // <-- create instance called Pressed
