I am working on a project that requires me to collect data from multiple IMUs (I am using the GY-521 Breakout board that utilizes the MPU6050).
So far, I have successfully daisy-chained up-to 7 MPU6050 to an Arduino Nano. I may need some help understanding the limits of I2C buses and accommodating up-to 10 sensors. The schematic is as follows: (for simplicity, I have shown only 3 sensors).
I am using the DMP library without interrupts, but the core concept is as follows:
Connect all the MPU6050 SDA/SCL (two wires) on the same buses to the Arduino. (As of now I have a 4.7kOhm pull-up resistor to 5V) -- Note: looking at the schematic of the GY-521 Breakout board, I am considering removing the 4.7kOhm pull-ups since they are already present on the breakout board (@see the image at the bottom).
Connect the AD0 pins from MPU6050 to Digital Pins on the Arduino Nano.
Initialize all the MPU6050's on the 0x68 address (AD0=LOW), then toggle (AD0=HIGH) each individual MPU6050, read data, untoggle (AD0=LOW).
All of this is fine, but the moment I add the 8th MPU6050 on the daisy chain, the entire system stops working -- MPU6050's get stuck on initialization and get stuck in a loop after the first iteration. I don't know if you need to see the code, as I don't think it is a software issue (but I can provide it if need be).
Some more information:
- I am using the I2C buses clocked at 400kHz (somehow this gives me a more consistent DMP output rate compared to 100kHz)
- I tried using an I2C Extender ( Adafruit LTC4311 I2C Extender / Active Terminator) to no avail.
- I am not using an I2C level shifter, as the GY-521 breakout board has an on-board LDO.
Edit:
- I have removed the pull-ups from 5V and shifted them to 3.3V on the Arduino Nano
- I will be adding a bi-directional Level Shifter for the SDA/SCL Pins. The HV will be connected to the 5V (effectively ~4.6 when powered by USB) on the Arduino Nano, and the LV to 3.3V on the Arduino Nano
As requested, I am posting the code below:
#include "I2Cdev.h" /// I2C Library
#include "MPU6050_6Axis_MotionApps612.h" /// 6 Axis Motion Apps Library
/** ==========[ VARIABLES ]========== **/
/// Sensor Details
const int MPU_ADDR = 0x68; /// I2C address of the MPU-6050; AD0(HIGH) -> 0x69 | AD0(LOW) -> 0x68
const int num_sens = 7; /// Number of sensors used
/// MPU Data Variables
MPU6050 MPU[num_sens]; /// Array of MPU6050 Objects
VectorInt16 accel[num_sens], gyro[num_sens]; /// Accelerometer & Gyroscope Data
Quaternion quat[num_sens]; /// Quaternion
VectorFloat gravity[num_sens]; /// Gravity
float rpy[num_sens][3]; /// Roll-Pitch-Yaw Data
unsigned long time_stamp[num_sens]; /// Time Stamp (ms)
/// DMP Variables
uint16_t packet_size[num_sens]; /// DMP Packet Size
uint16_t fifo_count[num_sens]; /// FIFO Count
uint8_t fifo_buffer[num_sens][64]; /// FIFO Buffer
/// Interrupt Variables
bool mpu_interrupt[num_sens]; /// MPU Interrupt
uint16_t fifo_alive[num_sens]; /// FIFO Alive
/** ==========[ SETUP ]========== **
* Initial Setup for Arduino & MPU6050
/// Initialize Serial
while (!Serial)
; /// Wait for Serial to be ready
/// Initialize I2C
Wire.begin();
Wire.setClock(400000); // 400kHz I2C clock.
/// Configure AD0 Pins for All MPUs
for (int pin = PinSelector(0); pin <= PinSelector(num_sens - 1); pin++) {
pinMode(pin, OUTPUT); /// Configure AD0 Pins as Output
digitalWrite(pin, HIGH); /// Set AD0 Pins to HIGH
/// Initialize All MPU6050 and Enable DMP
for (int imu = 0; imu < num_sens; imu++) {
Serial.print("[INFO] {IMU #"); Serial.print(imu); Serial.print("} Initializing MPU...");
ToggleMPU(imu); /// Toggle MPU
MPU[imu].initialize(); /// Initialize MPU6050
MPU[imu].setFullScaleGyroRange(MPU6050_GYRO_FS_1000); /// Set Gyro Range to 1000dps
MPU[imu].setFullScaleAccelRange(MPU6050_ACCEL_FS_4); /// Set Accel Range to 4g
MPU[imu].CalibrateGyro(3); /// Calibrate Gyro
MPU[imu].CalibrateAccel(3); /// Calibrate Accel
MPU[imu].dmpInitialize(); /// Initialize DMP
MPU[imu].setDMPEnabled(true); /// Enable DMP
packet_size[imu] = MPU[imu].dmpGetFIFOPacketSize(); /// Get DMP Packet Size
fifo_count[imu] = MPU[imu].getFIFOCount(); /// Get FIFO Count
Serial.println(" Done! (");
UnToggleMPU(imu); /// Untoggle MPU
/** ==========[ LOOP ]========== **
* Main Loop for Arduino
/// Cycle through all MPUs and Set DMP Interrupts
SetDMPInterrupt(imu); /// Set DMP Interrupt for the IMU
/** ==========[ SET DMP INTERRUPT ]========== **
* Set DMP Interrupt for the IMU
* @param IMU_NUM IMU Number
void SetDMPInterrupt(int IMU_NUM)
static unsigned long _ETimer[num_sens];
if (millis() - _ETimer[IMU_NUM] >= (10)) { /// After 10ms, enable MPU Interrupt
_ETimer[IMU_NUM] += (10); /// Increment Timer by 10ms
mpu_interrupt[IMU_NUM] = true; /// Set MPU Interrupt to true
if (mpu_interrupt[IMU_NUM]) { /// If MPU Interrupt is true
GetDMP(IMU_NUM); /// Get DMP Data
/** ==========[ GET DMP ]========== **
* Get DMP Data from MPU6050
* If FIFO Count is 0 or not a multiple of packet size, reset FIFO
* Else, Proceed with Calculations
void GetDMP(int IMU_NUM)
/// Local Variables -- FIFO Count, Packet Size, Last Good Packet Time
static unsigned long LastGoodPacketTime[num_sens];
mpu_interrupt[IMU_NUM] = false;
fifo_alive[IMU_NUM] = 1;
fifo_count[IMU_NUM] = MPU[IMU_NUM].getFIFOCount();
/// If FIFO Count is 0 or not a multiple of packet size
if ((!fifo_count[IMU_NUM]) || (fifo_count[IMU_NUM] % packet_size[IMU_NUM])) {
MPU[IMU_NUM].resetFIFO(); /// Failed to fetch DMP, reset FIFO
while (fifo_count[IMU_NUM] >= packet_size[IMU_NUM]) { /// While FIFO Count is greater than packet size
MPU[IMU_NUM].getFIFOBytes(fifo_buffer[IMU_NUM], packet_size[IMU_NUM]); /// Get latest packet
fifo_count[IMU_NUM] -= packet_size[IMU_NUM]; /// Update FIFO Count
LastGoodPacketTime[IMU_NUM] = millis();
ComputeData(IMU_NUM); /// On Success, Calculate MPU Math
/** ========== [ MPU MATH ] ========== **
* Using DMP, Obtain Accel/Gyro Data
* Compute Yaw-Pitch-Roll
void ComputeData(int IMU_NUM)
/// Quaternion, Gravity, Yaw-Pitch-Roll
float ypr[3];
MPU[IMU_NUM].dmpGetQuaternion(&quat[IMU_NUM], fifo_buffer[IMU_NUM]);
MPU[IMU_NUM].dmpGetGravity(&gravity[IMU_NUM], &quat[IMU_NUM]);
MPU[IMU_NUM].dmpGetYawPitchRoll(ypr, &quat[IMU_NUM], &gravity[IMU_NUM]);
/// Acceleration, Gyro
MPU[IMU_NUM].dmpGetAccel(&accel[IMU_NUM], fifo_buffer[IMU_NUM]); /// Get Acceleration: x, y, z (gForces: m/s^2)
MPU[IMU_NUM].dmpGetGyro(&gyro[IMU_NUM], fifo_buffer[IMU_NUM]); /// Get Gyro: x, y, z (rad/s)
/// Update Yaw-Pitch-Roll (radians)
rpy[IMU_NUM][0] = ypr[2]; /// Roll
rpy[IMU_NUM][1] = ypr[1]; /// Pitch
rpy[IMU_NUM][2] = ypr[0]; /// Yaw
time_stamp[IMU_NUM] = millis();
PrintData(IMU_NUM);
/** ==========[ PRINT DATA ]========== **
* Prints the Data for the corresponding IMU
* format: "> ID: 0 | Tms: 0 | acc: 0.00, 0.00, 0.00 | gyro: 0.00, 0.00, 0.00 | rpy: 0.00, 0.00, 0.00"
void PrintData(int IMU_NUM)
Serial.print("$ ID: "); Serial.print(IMU_NUM); Serial.print(" | ");
Serial.print("Tms:\t"); Serial.print(time_stamp[IMU_NUM]); Serial.print(" | ");
Serial.print("acc:\t"); Serial.print(accel[IMU_NUM].x);
Serial.print(",\t"); Serial.print(accel[IMU_NUM].y);
Serial.print(",\t"); Serial.print(accel[IMU_NUM].z); Serial.print("\t| ");
Serial.print("rot:\t"); Serial.print(gyro[IMU_NUM].x);
Serial.print(",\t"); Serial.print(gyro[IMU_NUM].y);
Serial.print(",\t"); Serial.print(gyro[IMU_NUM].z); Serial.print("\t| ");
Serial.print("rpy:\t"); Serial.print(rpy[IMU_NUM][0]);
Serial.print(",\t"); Serial.print(rpy[IMU_NUM][1]);
Serial.print(",\t"); Serial.println(rpy[IMU_NUM][2]);
/** ==========[ TOGGLE MPU ]========== **
* Sets corresponding AD0 --> LOW
* Toggling the MPU | I2C Address --> 0x68
void ToggleMPU(int IMU_NUM)
int pin = PinSelector(IMU_NUM);
digitalWrite(pin, LOW);
/** ==========[ UNTOGGLE MPU ]========== **
* Sets corresponding AD0 --> HIGH
* Toggling the MPU | I2C Address --> 0x69
void UnToggleMPU(int IMU_NUM)
/** ==========[ PIN SELECTOR ]========== **
* Returns the Pin Number corresponding to the IMU
* @return GPIO Pin Number (AD0)
int PinSelector(int IMU_NUM)
switch(IMU_NUM) {
case 0: return 2;
case 1: return 3;
case 2: return 4;
case 3: return 5;
case 4: return 6;
case 5: return 7;
case 6: return 8;
case 7: return 9;
case 8: return 10;
case 9: return 11;
What am I doing wrong?
