Help with debugging my code!
Hello i'm trying to build an arduino with a7 gsm gps geolocator that find coordinates and sending them with sms if i send it an sms first and i encountered some errors while compiling.
here is my code: (check update below first please).
#include <TinyGPS++.h>//include the library code
#include <SoftwareSerial.h>//include the library code
#include <GSM.h>// include the GSM library
//#include <AltSoftSerial.h>
void SendMsg();
void RecvMsg();
void displayInfo();
#define PINNUMBER ""// PIN Number for the SIM
TinyGPSPlus gps;// The TinyGPS++ object
GSM gsmAccess;// initialize the library instances
GSM_SMS sms;
SoftwareSerial ss(3, 4);// The serial connection to the GPS device
//AltSoftSerial sms(5, 6);// The serial connection to the GPS device
int sec,min,hour,day,month,year;
float lat,lng;
char PhoneNumber[20]="+306943444650";
boolean notConnected = true;
boolean waitingSMS = true;
//char c;
  ss.begin(115200);
  delay(200);
  ss.println("AT+IPR=9600");
  delay(800);
  ss.begin(9600);
  delay(200);
  Serial.println("Welcome to my Arduino project");
  delay(200);
  ss.println("AT+GPS=1");
  Serial.println("Initializing");
  Serial.println(".");
  ss.println("AT+GPSRD=1");
  Serial.println(".\n");
  if (millis() > 10000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS detected: check wiring."));
    while(true);
  Serial.println("Operation started SUCCESSFULLY\n");
  Serial.println("GSM initialized");
  while (lat == 0 && lng == 0)
    displayInfo();
  delay(200);
  Serial.println("Waiting for messages");
  // This sketch displays information every time a new sentence is correctly encoded.
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
  RecvMsg;
  waitingSMS = true;
  return(0);
void RecvMsg()
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  while(waitingSMS)
    if (sms.available())// If there are any SMSs available()
      Serial.println("Message received from:");
      sms.remoteNumber(PhoneNumber, 20);// Get remote number
      Serial.println(PhoneNumber);
      if (sms.peek() == "Location")// Any message with the keyword Location should extract coordinates
        Serial.println("Valid code");
        Serial.println("Extracting Coordinates");
        displayInfo();
        SendMsg;
        waitingSMS = false;
        Serial.println("Discarded SMS");
        sms.flush();//Message disposal
      /* // Read message bytes and print them
      while (c = sms.read())
        Serial.print(c);
      Serial.println("\nEND OF MESSAGE");
      // Delete message from modem memory
      sms.flush();
      Serial.println("MESSAGE DELETED");
void SendMsg()
  ss.println("AT+CMGF=1");    //Sets the GSM Module in TEXT Mode
  delay(1000);  // Delay of 1 second
  ss.println("AT+CMGS=\"+306943444650\"\r"); // Mobile number you want to text to
  //ss.println(displayInfo());
  ss.println("Location");
  ss.println(lat,6);
  ss.println(",");
  ss.println(lng,6);
  ss.println("/n");
  ss.println(" Date");
  ss.println(day);
  ss.println("/");
  ss.println(month);
  ss.println("/");
  ss.println(year);
  ss.println("\n");
  ss.println("Time ");
  ss.println(hour+2);
  ss.println(":");
  ss.println(min);
  ss.println(":");
  ss.println(sec);
  delay(100);
  ss.println((char)26);// ASCII code of CTRL+Z for saying the end of sms to  the module
  ss.println("AT+CMGF=0");    //Sets the GSM Module in Text Mode
void displayInfo()
  ss.println("AT+CMGF=0");    //Sets the GSM Module in GPS Mode
  Serial.print(F("Location: "));
  if (gps.location.isValid())
    Serial.print(gps.location.lat(), 6);
    lat = (gps.location.lat());
    Serial.print(F(","));
    Serial.print(gps.location.lng(), 6);
    lng = (gps.location.lng());
    Serial.print(F("INVALID"));
    lng = lat = 0;
  Serial.print(F("  Date/Time: "));
  if (gps.date.isValid())
    Serial.print(gps.date.day());
    day = (gps.date.day());
    Serial.print(F("/"));
    Serial.print(gps.date.month());
    month = (gps.date.month());
    Serial.print(gps.date.year());
    year = (gps.date.year());
    day = month = year = 0;
  Serial.print(F(" "));
  if (gps.time.isValid())
    if (gps.time.hour() < 10) Serial.print(F("0"));
    Serial.print(gps.time.hour()+2);
    hour = (gps.time.hour()+2);
    Serial.print(F(":"));
    if (gps.time.minute() < 10) Serial.print(F("0"));
    Serial.print(gps.time.minute());
    min = (gps.time.minute());
    if (gps.time.second() < 10) Serial.print(F("0"));
    Serial.print(gps.time.second());
    sec = (gps.time.second());
    hour = min = sec = 0;
  //Serial.print(lat,6);
  //Serial.print(",");
  //Serial.print(lng,6);
and here is the error message:
C:\Users\maxfi\AppData\Local\Temp\arduino_build_315871\libraries\GSM\GSM3SoftSerial.cpp.o (symbol from plugin): In function `GSM3SoftSerial::spaceAvailable()':
(.text+0x0): multiple definition of `__vector_3'
C:\Users\maxfi\AppData\Local\Temp\arduino_build_315871\libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `__vector_4'
(.text+0x0): multiple definition of `__vector_5'
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "GSM.h"
 Used: C:\Program
Multiple libraries were found for "TinyGPS++.h"
 Used: E:\Documents\Arduino\libraries\TinyGPSPlus-1.0.2b
Multiple libraries were found for "SoftwareSerial.h"
 Used: C:\Program
Using library TinyGPSPlus-1.0.2b at version 1.0.2 in folder: E:\Documents\Arduino\libraries\TinyGPSPlus-1.0.2b
Using library SoftwareSerial at version 1.0 in folder: C:\Program Files
Using library GSM at version 1.0.6 in folder: C:\Program Files
exit status 1
Error compiling for board Arduino/Genuino Uno.
ps: The error happened when i used gsm library and the void RecvMsg() .
I'm really noob so i need help.
UPDATE: Replacing the SoftwareSerial library with AltSoftSerial fix this error and the code compiles succssfully.
Does this happen because SoftwareSerial and Gsm use the same interrupt pins ?
They use the same vectors iow the saem timers, actually i suspect that the GSM library may be a modification/adaption of the SoftwareSerial library. Regardless of that there is quite a big chance of any SoftwareSerial interfering with each other (all rely heavily on interrupts and have interrupts disabled during their active phases) btw//AltSoftSerial sms(5, 6);// The serial connection to the GPS deviceyou know you can not specify the pins for AltSoftSerial ?
Trying to use 1 hw & 2sw Serial is going to get you in trouble, i suggest you use a board with multiple hwSerial connections.
I didn't know what is altsoftserial library it was just a test to get rid of the error.
Altsoftserial has transmit pin at 8 and receive pin at 9 by default right ?
The module U_RX pin is connected to Arduino pin 9
The module GPS_TX pin is connected to Arduino pin 8
The module VCC pin is connected to Arduino 5V pin*/
void SendMsg();
void RecvMsg();
void displayInfo();
GSM_SMS sms;
AltSoftSerial ss;// The serial connection to the GPS device
does it look okey now ? the pins and all.
thanks for your replay
that was a test as well dont mind that.
of the top of my head, yep, it says on github and in the .h & .cpp files i think.
yeah looks fine, does it compile ?
Yeah it compiles . It doesnt actually work though as i wish it would but i guess this is fixable. thanks for your replies :slight_smile:
that happens, so what doesn't it do that you want it to and does that you don't want it to ?
