Help with delay between compiling and upload
Hello,
Currently I have a constant current driver being powered by an external source (not the arduino board), that has a 0-5V control input pin which is powered by the arduino. It all works fine, except that for a split second between the program compiling and being uploaded the arduino turns off, causing the LED to be at full brightness, until the arduino turns on again. How can I fix this?
Show us the sketch.
analogWrite(10,255);
double percent=10;
for(int i=1;i<6;i++)
Serial.print(6-i);
analogWrite(10,(double)255*(1-percent/100));
The Arduino pin 10 will go to Hi Z when downloading or Reset.
Would you give a link to this?
The driver: 700mA DC BuckPuck Driver Externally Dimmable - With Leads
What does Hi Z mean?
And now when I do analogWrite(10,255) it only gives me about 3.3V. Hm.
JRules:
An external pull-down or pull-up resistor will help getting the signal from floating when the pin goes into High-Z mode. (up or down depends on what the module needs to be "off".) Resistor probably on the order of 10k, maybe 100k. You can play with the value to see what works.
JRules:
High Impedance (Z). Means the pin switches to INPUT, effectively looking like an open (which isn't really possible, so it is very high impedance.)
JRules:
Generally means the load that the pin is connected to, draws more than 40mA. What pin on the current driver are you connecting the arduino to?
[quote author=James C4S link=topic=178813.msg1325440#msg1325440 date=1374523674]
An external pull-down or pull-up resistor will help getting the signal from floating when the pin goes into High-Z mode. (up or down depends on what the module needs to be "off".) Resistor probably on the order of 10k, maybe 100k. You can play with the value to see what works. [/quote]
Ok I need the Arduino to be giving 5V for the LED to be off. Which would I need?
The arduino connects to the Control pin on the driver.
JRules:
Ok I need the Arduino to be giving 5V for the LED to be off. Which would I need?[/quote]
Pull-Up
What board are you using?
I'm using an Arduino Uno.
UPDATE: Nevermind about the 3.3V problem, I switched to pin 3 and it works fine now.
