Quick background so you know what I'm doing:
I've created a tachometer output to an LCD screen to monitor the Hall sensor Output from a waterpump and do the calculation to convert the count to RPM.
I've added a failure alarm, well not really, more like a low rpm warning display.(which is my issue)
The best I've figured out at the moment is to add a couple lines stating that if RPM drops below a certain threshold, clear the screen, blink every half a second and display "Pump Failure!!!"
This work fine, except for the fact that if I outright unplug the pump from it's power, thus removing the signal to the #2 digital pin...the output just stop at whatever it was previously at and no alarm goes off.
For example, testing with a PC fan with the same RPM output wire...If i slow the fan down past 800rpm with my finger it works fine and the alarm triggers. HOWEVER, if I blatently kill power to the fan, or stop the fan blades completely and abruptly. Nothing happens. The lcd just sticks at whatever RPM it was just at before I killed power to the fan or stopped teh blades.
Is there a function that i can call that will throw this same type of alarm, but will throw it when it senses that pin2 is no longer receiving a signal?
Im VERY new to coding and havent done it in 6+ years, so bear with my lack of proper use of terminology:
Below is my coding:
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
volatile byte rpmcount;
unsigned int rpm;
unsigned int rpmrate;
unsigned long timeold;
lcd.begin(16, 2); // intialise the LCD
digitalWrite(2,HIGH);
attachInterrupt(0, rpm_fun, RISING);
rpmcount = 0;
rpm = 0;
timeold = 0;
if (rpmcount >= 20) {
//Update RPM every 20 counts, increase this for better RPM resolution,
//decrease for faster update
rpm = 30*1000/(millis() - timeold)*rpmcount;
timeold = millis();
rpmcount = 0;
Serial.println(rpm,DEC);
lcd.clear();
lcd.setCursor(4,0);
lcd.print(rpm);
lcd.setCursor(9,0);
lcd.print("RPM");
if (rpm <= 800)
lcd.clear();
lcd.setCursor(1,1);
lcd.print("PUMP FAILURE!!!");
lcd.noDisplay();
lcd.display();
void rpm_fun()
rpmcount++;
//Each rotation, this interrupt function is run twice
