You will have to find out from the author why interval is set to 92. interval provides the timing and is close to 100ms which would give the 0.1 second accuracy.
So basically every 100ms getTime() is called which increments the time in 0.1 seconds (variable s) and adjusts the other time variables (seconds, 10 seconds, minutes and 10 minutes).
To get more digits (I'm not sure if it will give a higher accuracy), you will need to divide interval by 10 so getTime() is called evevry 10 milliseconds, add a variable to hold the 0.0x seconds and modify getTime() to use that variable. You probably will also have to get rid of the delay(10).
I'm not sure if you want to see it. But here it is
#include <EEPROM.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH1106.h>
#include <Fonts/nunitoTiny.h>
#include <Fonts/makoSmall.h>
#define OLED_CLK 2
#define OLED_MOSI 3
#define OLED_RESET 4
#define OLED_DC 5
#define OLED_CS 6
Adafruit_SH1106 tft(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
RF24 radio(7, 8);
const byte addr[6] = "00001";
int up, down, select;
int pressed = -1;
int app = 0;
int mode = 0;
int menu = 0;
int m1 = 0; int m2 = 0; int s1 = 0; int s2 = 0; int s = 0;
int mm1 = 0; int mm2 = 0; int ss1 = 0; int ss2 = 0; int ss = 0;
boolean tme = false;
boolean done = false;
int times = 0;
int amt = 0;
unsigned long curr;
unsigned long prev;
int interval = 92;
int last;
// ----- BITMAPS ----- //
const unsigned char sprint[] PROGMEM = {
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x7f, 0xfe,
0x00, 0x00,
0x01, 0x40,
0x02, 0xc0,
0x00, 0x00,
0x7f, 0xfe,
0x00, 0x00,
0x3c, 0x00,
0x20, 0x00,
0x00, 0x00,
0x7f, 0xfe,
0x00, 0x00,
0x00, 0x00
const unsigned char lap[] PROGMEM = {
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x0f, 0xf0,
0x3f, 0xfc,
0x38, 0x1c,
0x70, 0x0e,
0x60, 0x06,
0x60, 0x06,
0x70, 0x0e,
0x38, 0x1c,
0x3f, 0xfc,
0x0f, 0xf0,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00
const unsigned char count[] PROGMEM = {
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x7f, 0xfe,
0x6f, 0xb6,
0x55, 0x2a,
0x57, 0xba,
0x55, 0xb6,
0x6f, 0xa2,
0x7f, 0xfe,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00
static const unsigned char PROGMEM settings[] = {
0x00, 0x00,
0x01, 0x80,
0x01, 0x80,
0x19, 0x98,
0x1d, 0xb8,
0x0f, 0xf0,
0x07, 0xe0,
0x7e, 0x7e,
0x7e, 0x7e,
0x07, 0xe0,
0x0f, 0xf0,
0x1d, 0xb8,
0x19, 0x98,
0x01, 0x80,
0x01, 0x80,
0x00, 0x00
static const unsigned char PROGMEM autos[] = {
0x00, 0x00,
0x03, 0xc0,
0x01, 0x80,
0x03, 0xc0,
0x0d, 0x30,
0x10, 0x28,
0x10, 0x48,
0x20, 0x44,
0x21, 0x8c,
0x31, 0x84,
0x20, 0x04,
0x10, 0x08,
0x10, 0x08,
0x0c, 0xb0,
0x03, 0xc0,
0x00, 0x00
static const unsigned char PROGMEM manual[] = {
0x00, 0x00,
0x00, 0x00,
0x03, 0xc0,
0x0c, 0x30,
0x10, 0x08,
0x10, 0x08,
0x26, 0x64,
0x28, 0x94,
0x2a, 0x94,
0x26, 0x64,
0x10, 0x08,
0x10, 0x08,
0x0c, 0x30,
0x03, 0xc0,
0x00, 0x00,
0x00, 0x00
static const unsigned char PROGMEM back[] = {
0x00, 0x00,
0x00, 0x00,
0x08, 0x00,
0x18, 0x00,
0x3f, 0xe0,
0x3f, 0xf8,
0x18, 0x38,
0x08, 0x1c,
0x00, 0x1c,
0x00, 0x38,
0x0f, 0xf8,
0x0f, 0xe0,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00
static const unsigned char PROGMEM dist[] = {
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x7f, 0xfe,
0x7f, 0xfe,
0x6f, 0xbe,
0x6d, 0xb6,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00
static const unsigned char PROGMEM sound[] = {
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x20,
0x02, 0x10,
0x06, 0x88,
0x1e, 0x48,
0x1e, 0x48,
0x06, 0x88,
0x02, 0x10,
0x00, 0x20,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00
static const unsigned char PROGMEM nosound[] = {
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x80,
0x01, 0x80,
0x07, 0x80,
0x07, 0x80,
0x01, 0x80,
0x00, 0x80,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00
static const unsigned char PROGMEM racecal[] = {
0x00, 0x00,
0x00, 0x00,
0x00, 0x00,
0x7f, 0xfe,
0x00, 0x00,
0x51, 0xc0,
0x2a, 0x20,
0x50, 0x40,
0x28, 0x80,
0x50, 0x00,
0x28, 0x80,
0x00, 0x00,
0x7f, 0xfe,
0x00, 0x00,
0x00, 0x00,
0x00, 0x00
pinMode(14, INPUT);
pinMode(15, INPUT);
pinMode(16, INPUT);
pinMode(9, INPUT);
tft.begin(SH1106_SWITCHCAPVCC);
radio.begin();
radio.openReadingPipe(0, addr);
radio.setPALevel(RF24_PA_MIN);
radio.startListening();
radio.flush_rx();
tft.clearDisplay();
tft.setTextColor(WHITE);
int x, y;
int16_t x1, y1;
uint16_t w, h;
tft.setFont(&nunitoTiny);
tft.getTextBounds("Welcome", x, y, &x1, &y1, &w, &h);
tft.setCursor(63 - (w / 2), 37);
tft.print("Welcome");
tft.display();
int bar = 0;
while(bar < 128) {
tft.fillRect(0, 61, bar, 4, WHITE);
bar = bar + random(1, 6);
delay(random(4, 8));
tft.display();
tft.fillRect(0, 61, 128, 4, BLACK);
tft.display();
if(EEPROM.read(0) > 2) {
EEPROM.write(0, 0);
if(EEPROM.read(1) > 10) {
EEPROM.write(1, 5);
if(EEPROM.read(0) == 0) {
tone(9, 440, 100);
delay(100);
tone(9, 659, 100);
delay(100);
noTone(9);
delay(800);
app = 0;
menu = 0;
drawApp(app);
drawMenu(app, menu);
void drawApp(int appl) {
tft.clearDisplay();
if(appl == 0) {
tme = false;
tft.setFont(&makoSmall);
tft.setCursor(46, 18);
tft.print("Sprint");
tft.setCursor(46, 29);
tft.print("Lap");
tft.setCursor(46, 40);
tft.print("Counter");
tft.setCursor(46, 51);
tft.print("Settings");
} else if(appl == 1) {
tft.setCursor(46, 20);
tft.print("Automatic");
tft.setCursor(46, 36);
tft.print("Manual");
tft.setCursor(46, 52);
tft.print("Back");
} else if(appl == 2) {
tft.setCursor(3, 8);
tft.drawLine(3, 49, 123, 49, WHITE);
tft.drawLine(88, 54, 91, 57, WHITE);
tft.drawLine(91, 57, 88, 60, WHITE);
tft.setCursor(100, 60);
tft.print("Back");
tft.setCursor(3, 28);
m1 = 0; m2 = 0; s1 = 0; s2 = 0; s = 0;
tft.print(String(m1) + String(m2) + ":" + String(s1) + String(s2) + "." + String(s));
tft.display();
tme = true;
delay(100);
tone(9, 523, 150);
delay(random(1800, 3500));
tone(9, 523, 150);
delay(random(2300, 4100));
tone(9, 1047, 300);
} else if(appl == 3) {
tft.setCursor(15, 60);
tft.print("Start");
tft.print("Back");
} else if(appl == 4) {
tft.print("Lap");
tft.drawLine(74, 3, 74, 46, WHITE);
tft.print("Back");
tft.display();
tme = true;
times = 0;
delay(100);
tone(9, 523, 150);
tone(9, 523, 150);
tone(9, 1047, 300);
} else if(appl == 5) {
tft.print("Lap");
tft.print("Back");
tft.setCursor(3, 36);
tft.print("Sel to Start");
tft.display();
tme = false;
done = false;
times = 0;
} else if(appl == 6) {
tft.print("Current");
tft.setCursor(3, 40);
tft.print("Last");
int x, y;
int16_t x1, y1;
uint16_t w, h;
tft.getTextBounds("Lane", x, y, &x1, &y1, &w, &h);
tft.setCursor(124 - w, 8);
tft.print("Lane");
tft.getTextBounds("Num", x, y, &x1, &y1, &w, &h);
tft.setCursor(124 - w, 40);
tft.print("Num");
tft.setCursor(3, 26);
tft.setCursor(3, 58);
tft.print("No Data");
tft.setCursor(116, 26);
tft.print(EEPROM.read(1));
tft.getTextBounds("0", x, y, &x1, &y1, &w, &h);
tft.setCursor(124 - w, 58);
tft.print("0");
tft.display();
tme = false;
done = false;
amt = 0;
} else if(appl == 8) {
tme = false;
tft.print("Distance");
tft.print("Sound");
tft.print("Lane Calib");
tft.print("Back");
} else if(appl == 9) {
tme = false;
tft.setCursor(7, 25);
tft.print("Select Lane");
tft.print("Back");
tft.setCursor(7, 45);
tft.display();
void drawMenu(int app, int item) {
if(app == 0) {
tft.fillRect(0, 0, 43, 64, BLACK);
tft.drawLine(33, 0, 33, 63, WHITE);
if(item == 0) {
tft.drawLine(33, 12, 33, 18, BLACK);
tft.drawLine(33, 11, 37, 15, WHITE);
tft.drawLine(37, 15, 33, 19, WHITE);
tft.drawBitmap(8, 24, sprint, 16, 16, WHITE);
} else if(item == 1) {
tft.drawLine(33, 23, 33, 29, BLACK);
tft.drawLine(33, 22, 37, 26, WHITE);
tft.drawLine(37, 26, 33, 30, WHITE);
tft.drawBitmap(8, 24, lap, 16, 16, WHITE);
} else if(item == 2) {
tft.drawLine(33, 34, 33, 40, BLACK);
tft.drawLine(33, 33, 37, 37, WHITE);
tft.drawLine(37, 37, 33, 41, WHITE);
tft.drawBitmap(8, 24, count, 16, 16, WHITE);
} else if(item == 3) {
tft.drawLine(33, 45, 33, 51, BLACK);
tft.drawLine(33, 44, 37, 48, WHITE);
tft.drawLine(37, 48, 33, 52, WHITE);
tft.drawBitmap(8, 24, settings, 16, 16, WHITE);
} else if(app == 1) {
if(item == 0) {
tft.drawLine(33, 13, 33, 19, BLACK);
tft.drawLine(33, 12, 37, 16, WHITE);
tft.drawLine(37, 16, 33, 20, WHITE);
tft.drawBitmap(8, 24, autos, 16, 16, WHITE);
tft.drawLine(33, 29, 33, 35, BLACK);
tft.drawLine(33, 28, 37, 32, WHITE);
tft.drawLine(37, 32, 33, 36, WHITE);
tft.drawBitmap(8, 24, manual, 16, 16, WHITE);
tft.drawBitmap(8, 24, back, 16, 16, WHITE);
} else if(app == 3) {
if(item == 0) {
tft.fillRect(87, 53, 7, 10, BLACK);
tft.drawLine(3, 54, 6, 57, WHITE);
tft.drawLine(6, 57, 3, 60, WHITE);
tft.fillRect(0, 53, 7, 10, BLACK);
} else if(app == 5) {
if(item == 0) {
} else if(app == 7) {
if(item == 0) {
} else if(app == 8) {
if(item == 0) {
tft.drawBitmap(8, 24, dist, 16, 16, WHITE);
tft.drawBitmap(8, 24, sound, 16, 16, WHITE);
tft.drawBitmap(8, 24, nosound, 16, 16, WHITE);
tft.drawBitmap(8, 24, racecal, 16, 16, WHITE);
tft.display();
void events(int button) {
if(app == 0) {
if(button == 0) {
if(menu != 0) {
menu = menu - 1;
} else if(button == 1) {
if(menu != 3) {
menu++;
} else if(button == 2) {
if(menu == 0) {
app = 1;
mode = 0;
menu = 0;
drawApp(app);
} else if(menu == 1) {
app = 1;
mode = 1;
menu = 0;
drawApp(app);
} else if(menu == 2) {
app = 6;
drawApp(app);
} else if(menu == 3) {
app = 8;
menu = 0;
drawApp(app);
if(button == 0) {
if(menu != 0) {
menu = menu - 1;
if(menu != 2) {
menu++;
if(menu == 0) {
if(mode == 0) {
app = 2;
menu = 0;
radio.flush_rx();
drawApp(app);
} else if(mode == 1) {
app = 4;
menu = 0;
radio.flush_rx();
drawApp(app);
} else if(mode == 2) {
app = 6;
menu = 0;
radio.flush_rx();
drawApp(app);
if(mode == 0) {
app = 3;
menu = 0;
drawApp(app);
app = 5;
menu = 0;
drawApp(app);
app = 7;
menu = 0;
drawApp(app);
app = 0;
menu = 0;
drawApp(app);
} else if(app == 2) {
if(button == 2) {
app = 0;
menu = 0;
drawApp(app);
if(button == 0) {
if(menu == 0)
menu = 1;
menu = 0;
if(menu == 0)
menu = 1;
menu = 0;
if(menu == 0) {
delay(100);
tone(9, 1047, 300);
tme = true;
app = 0;
menu = 0;
drawApp(app);
} else if(app == 4) {
if(button == 2) {
app = 0;
menu = 0;
drawApp(app);
if(button == 0) {
if(done == false) {
app = 0;
menu = 0;
drawApp(app);
if(done == false) {
delay(100);
tone(9, 523, 150);
tone(9, 523, 150);
tone(9, 1047, 300);
tme = true;
app = 0;
menu = 0;
drawApp(app);
} else if(app == 6) {
if(button == 2) {
if(done == false) {
delay(100);
tone(9, 1047, 300);
tme = true;
done = true;
} else if(done == true) {
app = 0;
menu = 0;
drawApp(app);
if(button == 0) {
if(done == false) {
app = 0;
menu = 0;
drawApp(app);
if(done == false) {
delay(100);
tone(9, 523, 150);
tone(9, 523, 150);
tone(9, 1047, 300);
tme = true;
app = 0;
menu = 0;
drawApp(app);
if(button == 0) {
if(menu != 0) {
menu = menu - 1;
if(menu != 3) {
menu++;
if(menu == 0) {
app = 9;
drawApp(9);
EEPROM.write(0, 1);
tft.fillRect(8, 24, 16, 16, BLACK);
EEPROM.write(0, 0);
tft.display();
app = 0;
menu = 0;
drawApp(app);
} else if(app == 9) {
if(button == 0) {
if(EEPROM.read(1) != 8) {
EEPROM.write(1, EEPROM.read(1) + 1);
tft.fillRect(6, 32, 20, 20, BLACK);
tft.display();
if(EEPROM.read(1) != 1) {
EEPROM.write(1, EEPROM.read(1) - 1);
tft.display();
app = 8;
menu = 0;
drawApp(app);
void getTime() {
if(s == 9) {
s = 0;
s2++;
if(s2 > 9) {
s2 = 0;
s1++;
if(s1 > 5) {
s1 = 0;
m2++;
if(m2 > 9) {
m2 = 0;
m1++;
if(m1 > 9) {
m1 = 0;
s++;
boolean hasData() {
if(radio.available()) {
int distance;
radio.read(&distance, sizeof(distance));
if(distance < (EEPROM.read(1) * 100)) {
return true;
return false;
up = digitalRead(16);
down = digitalRead(15);
select = digitalRead(14);
if(up == HIGH && pressed == -1) {
pressed = 0;
events(0);
} else if(down == HIGH && pressed == -1) {
pressed = 1;
events(1);
} else if(select == HIGH && pressed == -1) {
pressed = 2;
events(2);
if(up == LOW) {
if(pressed == 0)
pressed = -1;
if(down == LOW) {
if(pressed == 1)
pressed = -1;
if(select == LOW) {
if(pressed == 2)
pressed = -1;
if(app == 2) {
if(hasData()) {
int text;
radio.read(&text, sizeof(text));
tme = false;
curr = millis();
if(curr - prev >= interval && tme == true) {
prev = curr;
getTime();
delay(10);
tft.fillRect(0, 16, 72, 13, BLACK);
tft.display();
if(hasData()) {
int text;
tme = false;
if(tme == true)
curr = millis();
prev = curr;
getTime();
delay(10);
tft.display();
if(hasData() && last > 10) {
int text;
if(times < 4) {
tft.setCursor(84, 12 + (times * 10));
mm1 = m1; mm2 = m2; ss1 = s1; ss2 = s2; ss = s;
times++;
last = 0;
curr = millis();
if(times == 4) {
tme = false;
} else if(hasData()) {
int text;
curr = millis();
curr = millis();
prev = curr;
getTime();
last++;
tft.display();
if(hasData() && last >= 5) {
int text;
tft.fillRect(0, 46, 128, 13, BLACK);
last = 0;
curr = millis();
amt++;
int x, y;
int16_t x1, y1;
uint16_t w, h;
tft.getTextBounds(String(amt), x, y, &x1, &y1, &w, &h);
tft.print(String(amt));
//Serial.println("Runner " + String(amt) + ": " + String(m1) + String(m2) + ":" + String(s1) + String(s2) + "." + String(s));
int text;
curr = millis();
curr = millis();
prev = curr;
getTime();
last++;
delay(10);
tft.fillRect(0, 14, 72, 13, BLACK);
tft.display();
