Help with DS3231 and LCD 20X4 Coding using serial I2C protocol
Hello,
Had an Arduino for a while and moved onto serial comms. I am working on a bigger project that on turning the box on, it will display GPS co-ordinates and also time and temperature.
Using Arduino 1.6.11
For the love of me, it won't compile. It pretty much says the file doesn't exist, but I think for whatever reason it's using the wrong path. I am not sure. I have spent 4 hours trying different things and getting no where. I downloaded the sodaq library as instructed and moved folder in examples folder. Any help would be much appreciated.
The error code is as follows:
C:\Program Files (x86)\Arduino\examples\Sodaq_DS3231-master\examples\adjust\adjust.pde:4:26: fatal error: Sodaq_DS3231.h: No such file or directory
#include "Sodaq_DS3231.h"
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
(deleted)
(deleted)
Thanks for the quick response. Will try this tomorrow or later in the week. Packed everything away for the night.
Once I get over this problem, which I am guessing is minor, I can then try and get the display to work.
