Hello Guys,
Sorry, my English don't is very well. But I try.
I'm have issues to do torn ON and OFF two LEDs.
When I turn ON ledPin 4 and I want turn ON ledPin 5, the ledPin 4 turn OFF.
I know that my code have some error.
Does they to help me?
The code whith ONE LED(It Works):
#include <String.h>
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = {
192, 168, 1, 243 }; // Endereco IP
byte gateway[] = {
192, 168, 1, 10 }; // IP roteador
byte subnet[] = {
255, 255, 255, 0 }; //Mascara
Server server(80); //Porta
byte sampledata=50; //some sample data - outputs 2 (ascii = 50 DEC)
int ledPin = 4; // Pino do Led utilizado
//char link[]="http://192.168.1.243/"; //link data
String readString = String(30); //string for fetching data from address
boolean LEDON = false; //LED status flag
void setup(){
//iniciar Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
//Set pin 4 to output
pinMode(ledPin, OUTPUT);
//enable serial datada print
void loop(){
// Cria uma conexao cliente
Client client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 30)
//store characters to string
readString += c;
//output chars to serial port
Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
//lets check if LED should be lighted
if(readString.indexOf("L=1") >=0)
//led has to be turned OFF
digitalWrite(ledPin, LOW); // set the LED off
LEDON = true;
else{
//led has to be turned ON
digitalWrite(ledPin, HIGH); // set the LED on
LEDON = false;
// now output HTML data starting with standart header
client.println("Content-Type: text/html");
client.println();
//set background to yellow
client.print("");
//send first heading
client.println("");
client.println("
Casa Inteligente
");//output some sample data to browser
//client.println("Sample data: ");
//client.print(sampledata);//lets output some data
//drawing simple table
//client.println("Simple table: ");
//printing some link
client.println("");
client.println("");
client.println("
| "); client.println(""); client.println(" Luz do Quintal");//controlling led via checkbox //address will look like http://192.168.1.243/?L=1 when submited client.println("LUZ "); client.println(" (1=ON / 0=OFF) "); //printing LED status client.print("Status: "); if (LEDON) client.println("ON"); else client.println("OFF"); client.println(""); client.println(" |
client.println("");
//clearing string for next read
readString="";
//stopping client
client.stop();
And the code whith problem(usin two leds(led and fan in my code):
#include <String.h>
#include <SPI.h>
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
int ledPin = 4;
int fanPin = 5; // Pino do Led utilizado
boolean LEDON = false;//LED status flag
boolean FANON = false;
void setup(){
//iniciar Ethernet
pinMode(fanPin, OUTPUT);
void loop(){
if (client) {
readString += c;
Serial.print(c);
if (c == '\n') {
LEDON = true;
else{
LEDON = false;
if (c == '\n') {
if(readString.indexOf("F=1") >=0)
digitalWrite(fanPin, LOW); // set the LED off
FANON = true;
else{
digitalWrite(fanPin, HIGH); // set the LED on
FANON = false;
client.println();
client.print("");
client.println("");
client.println("
Casa Inteligente
client.println("");
client.println("");
client.println("");
client.println("
"); client.println(""); client.println(" Ar do Quarto");client.println("Ar-Condionado "); client.println(" (1=ON / 0=OFF) "); client.print("Status: "); if (FANON) client.println("ON"); else client.println("OFF"); client.println(" |
client.println("");
readString="";
//stopping client
client.stop();
Please, help me... ![]()
