I don't understand, the function counter does work.
cattledog:
Yes, that the way the sketch works.
Oh, is there a way to assign paramx_pulses to their respective paramx_value on start up? It won't be feasible to toggle through the menu each time.
cattledog:
Add the assignments int setup as I have done below. I'm not sure what you want to do with the param2_index.
You may want to pull the restore = 1 command out of the cases, as you will have done that in setup. The value of restore is actually managed when you access the cases with the function control. You are the one who knows what you want to change with the encoder counts, and what you want to restore from saved settings.
#include <Arduino.h>
#include <pins_arduino.h>
#include <Wire.h>
#include "AidaDSP.h"
#include <LiquidCrystal.h>
#include <EEPROM.h>
LiquidCrystal lcd(12, 11, 10, 9, 8, 7); //RS, E, D4, D5, D6, D7
const int SAVE = 14;
#define EVER (;;)
// DEFINES I/O
#define PIN_LED 13
// DEFINES USER INTERFACE
#define MAX 20.00
#define MIN -40.00
#define ON 1
#define OFF 0
// FUNCTION PROTOTYPES
void spettacolino(void);
void clearAndHome(void);
// GLOBAL VARIABLES
// UI
uint8_t bypass = OFF;
uint8_t oldbypass = OFF;
uint8_t func_counter = 0;
uint8_t old_func_counter = 0;
uint8_t push_e_count = 0;
uint8_t push_e_function = 0;
uint8_t restore = 0;
uint16_t param2_index = 1;
int32_t param1_pulses = 0;
int32_t param2_pulses = 0;
int32_t param3_pulses = 0;
int32_t param4_pulses = 0;
uint32_t timec=0, prevtimec=0;
float param1_value = 0.00;
float param3_value = 0.00;
float param4_value = 0.00;
int eeAddress = 0;
EEPROM.get(0, param1_pulses);
EEPROM.get(4, param2_pulses);
EEPROM.get(8, param3_pulses);
EEPROM.get(12, param4_pulses);
param1_value = processencoder(MIN, MAX, param1_pulses);
// Do something, call Aida DSP API
param2_index = selectorwithencoder(param2_pulses, 2);
switch(param2_index)
case 1:
case 2:
case 3:
case 4:
param3_value = processencoder(MIN, MAX, param3_pulses);
param4_value = processencoder(MIN, MAX, param4_pulses);
// I/O
pinMode(PIN_LED, OUTPUT);
pinMode (SAVE, INPUT);
pinMode(6, OUTPUT);
digitalWrite(6,HIGH);
// open the USBSerial port
clearAndHome();
Serial.println(F("Aida DSP control with ARDUINO")); // Welcome message
Serial.println(F("0x00")); // Print DSP I2C address
InitAida(); // Initialize DSP board
// ... download of program ... (see other examples to know what to do here)
spettacolino();
if(digitalRead(SAVE)==LOW)
digitalWrite(PIN_LED, HIGH);
delay(50); // debounce
// EEPROM.put(0, param1_pulses);
//EEPROM.put(4, param2_pulses);
//EEPROM.put(8, param3_pulses);
//EEPROM.put(12, param4_pulses);
//lcd.clear();
/*delay(100);
lcd.begin(8, 2);
lcd.setCursor(0, 0);
lcd.print(param1_pulses);
lcd.setCursor(0,1);
lcd.print(param2_pulses);
if(digitalRead(ENC_PUSH)==LOW)
push_e_count++;
if(push_e_count>0 && push_e_count<10)
push_e_function = 1;
else if(push_e_count>10 && push_e_count<30)
push_e_function = 2;
push_e_function = 0; // No function triggered on switch
push_e_count = 0;
digitalWrite(PIN_LED, LOW);
if(push_e_function==1)
func_counter--;
if(func_counter==255)
func_counter=3;
else if(push_e_function==2)
bypass ^=1;
timec = millis();
if(timec-prevtimec >= 1000) // Here we manage control interface every second
clearAndHome(); // !!!Warning use with real terminal emulation program
Serial.println(F("********************************"));
Serial.println(F("* User control interface *"));
Serial.println(F("* AIDA Template2 Sketch *"));
Serial.println(F(""));
Serial.print(F(" Encoder pulses: "));
Serial.println(getPulses(), DEC);
Serial.println("param1_pulses=");
Serial.println(param1_pulses);
Serial.println("param2_pulses=");
Serial.println(param2_pulses);
Serial.println("param3_pulses=");
Serial.println(param3_pulses);
Serial.println("param4_pulses=");
Serial.println(param4_pulses);
if(oldbypass != bypass)
if(bypass == ON)
oldbypass = bypass;
if(old_func_counter != func_counter)
restore = 1;
old_func_counter = func_counter;
switch(func_counter)
case 0: // PARAM1
restore=1;
if(restore)
restore = 0;
setPulses(param1_pulses);
param1_pulses = getPulses();
case 1: // PARAM2
restore=1;
if(restore)
restore = 0;
setPulses(param2_pulses);
param2_pulses = getPulses();
case 1:
case 2:
case 3:
case 4:
case 2: // PARAM3
restore=1;
if(restore)
restore = 0;
setPulses(param3_pulses);
param3_pulses = getPulses();
case 3: // Color
restore=1;
if(restore)
restore = 0;
setPulses(param4_pulses);
param4_pulses = getPulses();
} // End switch func_counter
// Display information for user
print_menu_putty();
prevtimec = timec;
} // End if 1000ms tick
} // End void loop
void spettacolino()
byte i;
byte status = 0x00;
for(i=0;i<6;i++)
status ^= 1;
digitalWrite(PIN_LED, status);
delay(250);
Serial.write(0x1b); // ESC
Serial.print(F("[2J")); // clear screen
Serial.print(F("[H")); // cursor to home
void print_menu_putty(void)
// Print menu
Serial.print(F(" Effect status: "));
if(bypass)
Serial.println(F("bypass"));
Serial.println(F("on"));
if(func_counter==0)
Serial.print(F(" "));
Serial.print(F(" Param 1: "));
Serial.print(param1_value, 1);
if(func_counter==1)
Serial.print(F(" Param 2: "));
if(param2_index==1)
Serial.println(F("one"));
if(param2_index==2)
Serial.println(F("two"));
if(param2_index==3)
Serial.println(F("three"));
if(param2_index==4)
Serial.println(F("four"));
if(func_counter==2)
Serial.print(F(" Param 3: "));
Serial.print(param3_value, 1);
if(func_counter==3)
Serial.print(F(" Param 4: "));
Serial.print(param4_value, 1);
Serial.print(F(" Active item: "));
Serial.println(func_counter, DEC);
That sort of works! I had to remove restore = 1 anyway as with it, it resets the pulse count on each loop, which makes it impossible to do anything!
However, without restore = 1 in switch case 0, param1_value is not restored. I can revert back to setPulses(EEPROM.get(0, param1_pulses)); in setup and this seems to make everything work, as far as I can tell. Do you think there's anything to be wary of in doing this? I'm thinking there must be a reason param1 doesn't restore and this might just be covering up another problem?
(I have another issue/question relating to this sketch that I'd like to ask (namely, how to stop counting pulses when it reaches a certain pulse count), care to help me here or should I start a new thread do you think?)
Many thanks for all your help, most unexpected.
There is a lot of code in the library AidaDSP.cpp dealing with pulse counts. Ther may be MAX MIN values but i have not studied it in detail. I think that you must be a musician rather than a C++ coder, but you might want to have a go at changing the library parameters to do what you want.
Without getting into the library you might try something simple in the loop like
if(getPulses() >= xxx);
setPulses(xxx);
It won't really stop counting, but you can manage the value.
If this doesn't get you where you want to be, I would start a new thread, as you are really beyond the eeprom problems of the original title.
You might try put it in the Audio section of the format as that might get some eyes on it that are familiar with AidaDSP.
Good Luck.
That works just fine. Thanks again, really appreciate it.
