Hello I am a student and my college senior project is to build an electric bike. I wanted to use an arduino to make my project even better to add a speedometer and blinkers and while my program works it wont do both at the same time.
I found a program that uses a reed sensor on the fork and a magnet on the wheel and allows me to calculate the speed which. Depending on the speed one LED lights up for each mph up to 5 mph. (Ill add more later)
I also wrote a program so when a pushbutton is pressed an led will blink until the pushbutton is pressed again. I have two sets of one button and one led for two blinkers.
I am a mechanical engineering student so this isnt my strong suit by any means. That being said I realize I need to implement debounce and my code isnt beautiful, but I need a bit of help.
Why if both sections work correctly is it that when I run the program the speedometer takes over the blinker stops. I assume it is for the same reason that I cant turn on both blinkers at the same time even though I didnt intentionally program this to be a feature.
I have attached my code below and any help would be greatly appreciated
Thank you!
Ethan
const int reed = A0; // pin that the sensor is attached to
const int ledPin13 = 13; // pin that the LED13 is attached to
const int ledPin12 = 12;
const int ledPin11 = 11;
const int ledPin10 = 10;
const int ledPin9 = 9;
const int ledPin8 = 8;
const int ledPin7 = 7;
const int button1Pin = 6;
const int button2Pin = 5;
int reedVal;
long timer;// time between one full rotation (in ms)
float mph;
float radius = 8.5;// tire radius (in inches)
float circumference;
int state1 = HIGH;
int reading1;
int previous1 = LOW;
int state2 = HIGH;
int reading2;
int previous2 = LOW;
int maxReedCounter = 100;//min time (in ms) of one rotation (for debouncing)
int reedCounter;
pinMode(button1Pin, INPUT);
pinMode(button2Pin, INPUT);
reedCounter = maxReedCounter;
circumference = 2*3.14*radius;
pinMode(reed, INPUT);
pinMode(ledPin13, OUTPUT);
pinMode(ledPin12, OUTPUT);
pinMode(ledPin11, OUTPUT);
pinMode(ledPin10, OUTPUT);
pinMode(ledPin9, OUTPUT);
// TIMER SETUP- the timer interrupt allows precise timed measurements of the reed switch
//for more info about configuration of arduino timers see http://arduino.cc/playground/Code/Timer1
cli();//stop interrupts
//set timer1 interrupt at 1kHz
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;
// set timer count for 1khz increments
OCR1A = 1999;// = (1/1000) / ((1/(16*10^6))*8) - 1
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS11 bit for 8 prescaler
TCCR1B |= (1 << CS11);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
sei();//allow interrupts
//END TIMER SETUP
ISR(TIMER1_COMPA_vect) {//Interrupt at freq of 1kHz to measure reed switch
reedVal = digitalRead(reed);//get val of A0
if (reedVal){//if reed switch is closed
if (reedCounter == 0){//min time between pulses has passed
mph = (56.8*float(circumference))/float(timer);//calculate miles per hour
timer = 0;//reset timer
reedCounter = maxReedCounter;//reset reedCounter
else{
if (reedCounter > 0){//don't let reedCounter go negative
reedCounter -= 1;//decrement reedCounter
else{//if reed switch is open
if (timer > 2000){
mph = 0;//if no new pulses from reed switch- tire is still, set mph to 0
else{
timer += 1;//increment timer
void displayMPH(){
Serial.println(mph);
void loop() { // the loop routine runs over and over again forever:
reading1 = digitalRead(button1Pin);
// if the input just went from LOW and HIGH and we've waited long enough
// to ignore any noise on the circuit, toggle the output pin and remember
// the time
if (reading1 == HIGH && previous1 == LOW) {
if (state1 == HIGH)
state1 = LOW;
state1 = HIGH;
if (state1 == HIGH){
digitalWrite(ledPin8, HIGH);
delay(200);
digitalWrite(ledPin8, LOW);
delay(200);
else if (state1 == LOW) {
previous1 = reading1;
reading2 = digitalRead(button2Pin);
// the time
if (reading2 == HIGH && previous2 == LOW) {
if (state2 == HIGH)
state2 = LOW;
state2 = HIGH;
if (state2 == HIGH){
digitalWrite(ledPin7, HIGH);
delay(200);
digitalWrite(ledPin7, LOW);
delay(200);
else if (state2 == LOW) {
previous2 = reading2;
//print mph once a second
displayMPH();
if(mph > 1) {
digitalWrite(ledPin9, HIGH);
else {
digitalWrite(ledPin9, LOW);
if(mph > 2) {
digitalWrite(ledPin10, HIGH);
else {
digitalWrite(ledPin10, LOW);
if(mph > 3) {
digitalWrite(ledPin11, HIGH);
else {
digitalWrite(ledPin11, LOW);
if(mph > 4) {
digitalWrite(ledPin12, HIGH);
else {
digitalWrite(ledPin12, LOW);
if(mph > 5) {
digitalWrite(ledPin13, HIGH);
else {
digitalWrite(ledPin13, LOW);
