Help with elevator programming
I was compiling a program to control an elevator. The program is not finished yet. I came across errors saying:
In function ‘void loop()’;
error: expected ‘)’ before ‘;’ token
error: expected ‘;’ before ‘)’ token
What is causing these errors?
int RequestedFloor = 1;
int CurrentFloor = 1;
int PowerU = 2; //pin number
int PowerD = 3; //pin number
int Sensor1 = 4; //pin number
int Sensor2 = 5; //pin number
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
pinMode (PowerU, OUTPUT);
digitalWrite (PowerU, LOW);
pinMode (PowerD, OUTPUT);
digitalWrite (PowerD, LOW);
if (Serial.available() > 0)
RequestedFloor = Serial.read();
if (RequestedFloor <= 0)
Serial.print (“This floor does not exist”);
else{
if (RequestedFloor != CurrentFloor)
if (RequestedFloor > CurrentFloor)
digitalWrite (PowerU; HIGH);
That'll be the problem. A semicolon (;) is used to show the compiler you have moved on to a new piece of code. What you want is a comma in the middle, not a semicolon:
digitalWrite(PowerU[glow=yellow,2,300],[/glow] HIGH);
Onions.
Thanks. My eyes missed that.
