Help with Error Code(arduino uno/adafruit datalogger)
I am trying to work the SD logging for a Arduino Uno and Ultimate gps datalogger by using SD Logging | Adafruit Ultimate GPS Logger Shield | Adafruit Learning System
while following the directions I get to the point where I upload the Adafruit_GPS->shield_sdlog sketch
#include <SPI.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include <avr/sleep.h>
// Ladyada's logger modified by Bill Greiman to use the SdFat library
// This code shows how to listen to the GPS module in an interrupt
// which allows the program to have more 'freedom' - just parse
// when a new NMEA sentence is available! Then access data when
// desired.
// Tested and works great with the Adafruit Ultimate GPS Shield
// using MTK33x9 chipset
//    ------> http://www.adafruit.com/products/
// Pick one up today at the Adafruit electronics shop
// and help support open source hardware & software! -ada
// Fllybob added 10 sec logging option
SoftwareSerial mySerial(8, 7);
Adafruit_GPS GPS(&mySerial);
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences
#define GPSECHO  true
/* set to true to only log to SD when GPS has a fix, for debugging, keep it false */
#define LOG_FIXONLY false
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
// Set the pins used
#define chipSelect 10
#define ledPin 13
File logfile;
// read a Hex value and return the decimal equivalent
uint8_t parseHex(char c) {
  if (c < '0')
    return 0;
  if (c <= '9')
    return c - '0';
  if (c < 'A')
    return 0;
  if (c <= 'F')
    return (c - 'A')+10;
// blink out an error code
void error(uint8_t errno) {
  if (SD.errorCode()) {
   putstring("SD error: ");
   Serial.print(card.errorCode(), HEX);
   Serial.print(',');
   Serial.println(card.errorData(), HEX);
  while(1) {
    uint8_t i;
    for (i=0; i<errno; i++) {
      digitalWrite(ledPin, HIGH);
      delay(100);
      digitalWrite(ledPin, LOW);
      delay(100);
    for (i=errno; i<10; i++) {
      delay(200);
  // for Leonardos, if you want to debug SD issues, uncomment this line
  // to see serial output
  //while (!Serial);
  // connect at 115200 so we can read the GPS fast enough and echo without dropping chars
  // also spit it out
  Serial.println("\r\nUltimate GPSlogger Shield");
  pinMode(ledPin, OUTPUT);
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect, 11, 12, 13)) {
    //if (!SD.begin(chipSelect)) {      // if you're using an UNO, you can use this line instead
    Serial.println("Card init. failed!");
    error(2);
  char filename[15];
  strcpy(filename, "GPSLOG00.TXT");
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = '0' + i/10;
    filename[7] = '0' + i%10;
    // create if does not exist, do not open existing, write, sync after write
    if (! SD.exists(filename)) {
  logfile = SD.open(filename, FILE_WRITE);
  if( ! logfile ) {
    Serial.print("Couldnt create ");
    Serial.println(filename);
    error(3);
  Serial.print("Writing to ");
  // connect to the GPS at the desired rate
  GPS.begin(9600);
  // uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
  // uncomment this line to turn on only the "minimum recommended" data
  //GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
  // For logging data, we don't suggest using anything but either RMC only or RMC+GGA
  // to keep the log files at a reasonable size
  // Set the update rate
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);   // 100 millihertz (once every 10 seconds), 1Hz or 5Hz update rate
  // Turn off updates on antenna status, if the firmware permits it
  GPS.sendCommand(PGCMD_NOANTENNA);
  // the nice thing about this code is you can have a timer0 interrupt go off
  // every 1 millisecond, and read data from the GPS for you. that makes the
  // loop code a heck of a lot easier!
  useInterrupt(true);
  Serial.println("Ready!");
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
  char c = GPS.read();
  // if you want to debug, this is a good time to do it!
  #ifdef UDR0
      if (GPSECHO)
        if (c) UDR0 = c;
      // writing direct to UDR0 is much much faster than Serial.print
      // but only one character can be written at a time.
  #endif
void useInterrupt(boolean v) {
  if (v) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
    usingInterrupt = true;
  else {
    // do not call the interrupt function COMPA anymore
    TIMSK0 &= ~_BV(OCIE0A);
  if (! usingInterrupt) {
    // read data from the GPS in the 'main loop'
    if (GPSECHO)
      if (c) Serial.print(c);
  // if a sentence is received, we can check the checksum, parse it...
  if (GPS.newNMEAreceived()) {
    // a tricky thing here is if we print the NMEA sentence, or data
    // we end up not listening and catching other sentences!
    // so be very wary if using OUTPUT_ALLDATA and trying to print out data
    // Don't call lastNMEA more than once between parse calls!  Calling lastNMEA
    // will clear the received flag and can cause very subtle race conditions if
    // new data comes in before parse is called again.
    char *stringptr = GPS.lastNMEA();
    if (!GPS.parse(stringptr))   // this also sets the newNMEAreceived() flag to false
      return;  // we can fail to parse a sentence in which case we should just wait for another
    // Sentence parsed!
    Serial.println("OK");
    if (LOG_FIXONLY && !GPS.fix) {
      Serial.print("No Fix");
      return;
    // Rad. lets log it!
    Serial.println("Log");
    uint8_t stringsize = strlen(stringptr);
    if (stringsize != logfile.write((uint8_t *)stringptr, stringsize))    //write the string to the SD file
        error(4);
    if (strstr(stringptr, "RMC") || strstr(stringptr, "GGA"))   logfile.flush();
/* End code */
I cant figure out how to fix this can some please help?
this is the error code it gives me
Arduino: 1.8.1 (Windows 8.1), Board: "Arduino/Genuino Uno"
E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\arduino-builder -dump-prefs -logger=machine -hardware E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware -tools E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\tools-builder -tools E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -built-in-libraries E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\libraries -libraries \\nas-host\students\studentfiles\013422\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10801 -build-path C:\Users\013422\AppData\Local\Temp\arduino_build_95787 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avrdude.path=E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -verbose \\nas-host\students\studentfiles\013422\Documents\Arduino\libraries\Adafruit_GPS-master\examples\shield_sdlog\shield_sdlog.ino
E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\arduino-builder -compile -logger=machine -hardware E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware -tools E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\tools-builder -tools E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -built-in-libraries E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\libraries -libraries \\nas-host\students\studentfiles\013422\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10801 -build-path C:\Users\013422\AppData\Local\Temp\arduino_build_95787 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avrdude.path=E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr -verbose \\nas-host\students\studentfiles\013422\Documents\Arduino\libraries\Adafruit_GPS-master\examples\shield_sdlog\shield_sdlog.ino
Using board 'uno' from platform in folder: E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr
Using core 'arduino' from platform in folder: E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr
Detecting libraries used...
"E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\cores\arduino" "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\variants\standard" "C:\Users\013422\AppData\Local\Temp\arduino_build_95787\sketch\shield_sdlog.ino.cpp" -o "nul"
"E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\cores\arduino" "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\variants\standard" "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\libraries\SPI\src" "C:\Users\013422\AppData\Local\Temp\arduino_build_95787\sketch\shield_sdlog.ino.cpp" -o "nul"
"E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\cores\arduino" "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\variants\standard" "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\libraries\SPI\src" "-I\\nas-host\students\studentfiles\013422\Documents\Arduino\libraries\Adafruit_GPS-master" "C:\Users\013422\AppData\Local\Temp\arduino_build_95787\sketch\shield_sdlog.ino.cpp" -o "nul"
"E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\cores\arduino" "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\variants\standard" "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\libraries\SPI\src" "-I\\nas-host\students\studentfiles\013422\Documents\Arduino\libraries\Adafruit_GPS-master" "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\013422\AppData\Local\Temp\arduino_build_95787\sketch\shield_sdlog.ino.cpp" -o "nul"
"E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\cores\arduino" "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\variants\standard" "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\libraries\SPI\src" "-I\\nas-host\students\studentfiles\013422\Documents\Arduino\libraries\Adafruit_GPS-master" "-IE:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\013422\AppData\Local\Temp\arduino_build_95787\sketch\shield_sdlog.ino.cpp" -o "C:\Users\013422\AppData\Local\Temp\arduino_build_95787\preproc\ctags_target_for_gcc_minus_e.cpp"
\\nas-host\students\studentfiles\013422\Documents\Arduino\libraries\Adafruit_GPS-master\examples\shield_sdlog\shield_sdlog.ino:4:16: fatal error: SD.h: No such file or directory
 #include <SD.h>
compilation terminated.
Using library SPI at version 1.0 in folder: E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\libraries\SPI
Using library Adafruit_GPS-master at version 1.0.2 in folder: \\nas-host\students\studentfiles\013422\Documents\Arduino\libraries\Adafruit_GPS-master
Using library SoftwareSerial at version 1.0 in folder: E:\Payload Coding\arduino-1.8.1-windows\arduino-1.8.1\hardware\arduino\avr\libraries\SoftwareSerial
exit status 1
Error compiling for board Arduino/Genuino Uno.
You need to comment out line 92 and uncomment line 93
Edit: Based on your second post it looks like you also might need to re-install the SD library?
Ok I did that and same results but I've tried re-installed it many times and no luck
