Hello all, new to the arduino world, but have been using for about two months now and I am learning a lot. I came across this problem when uploading a new sketch. I am using LCD Screen with an I2c attachment. I have used the program many times for other projects and this is the first time that this has happened. Not sure what to do.
OS Windows 10 Home 64 bit
Arduino UNO
#include <Wire.h>
// I2C Scanner
// Written by Nick Gammon
// Date: 20th April 2011
#include <Wire.h>
Serial.begin (9600);
// Leonardo: wait for serial port to connect
while (!Serial)
Serial.println ();
Serial.println ("I2C scanner. Scanning ...");
byte count = 0;
Wire.begin();
for (byte i = 8; i < 120; i++)
Wire.beginTransmission (i);
if (Wire.endTransmission () == 0)
Serial.print ("Found address: ");
Serial.print (i, DEC);
Serial.print (" (0x");
Serial.print (i, HEX);
Serial.println (")");
count++;
delay (1); // maybe unneeded?
} // end of good response
} // end of for loop
Serial.println ("Done.");
Serial.print ("Found ");
Serial.print (count, DEC);
Serial.println (" device(s).");
} // end of setup
void loop() {}Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 3530 bytes (10%) of program storage space. Maximum is 32256 bytes.
Global variables use 472 bytes (23%) of dynamic memory, leaving 1576 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x74
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
