Help with error in display code!!!
I am trying to load the "Basic Functions and Text" from http://www.sparkfun.com/tutorials/300 " for the Nokia display.
They said that I needed to "First, download the Arduino library created by Adafruit." Which I did.
But when I run it, I keep getting and error "expected class name before } token" inside the include files which I downloaded, which is highlighted in yellow bellow.
This is a library for our Monochrome Nokia 5110 LCD Displays
Pick one up today in the adafruit shop!
------> Nokia 5110/3310 monochrome LCD + extras : ID 338 : $10.00 : Adafruit Industries, Unique & fun DIY electronics and kits
These displays use SPI to communicate, 4 or 5 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, check license.txt for more information
All text above, and the splash screen must be included in any redistribution
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#define BLACK 1
#define WHITE 0
#define LCDWIDTH 84
#define LCDHEIGHT 48
#define PCD8544_POWERDOWN 0x04
#define PCD8544_ENTRYMODE 0x02
#define PCD8544_EXTENDEDINSTRUCTION 0x01
#define PCD8544_DISPLAYBLANK 0x0
#define PCD8544_DISPLAYNORMAL 0x4
#define PCD8544_DISPLAYALLON 0x1
#define PCD8544_DISPLAYINVERTED 0x5
// H = 0
#define PCD8544_FUNCTIONSET 0x20
#define PCD8544_DISPLAYCONTROL 0x08
#define PCD8544_SETYADDR 0x40
#define PCD8544_SETXADDR 0x80
// H = 1
#define PCD8544_SETTEMP 0x04
#define PCD8544_SETBIAS 0x10
#define PCD8544_SETVOP 0x80
class Adafruit_PCD8544 : public Adafruit_GFX {
public:
Adafruit_PCD8544(int8_t SCLK, int8_t DIN, int8_t DC, int8_t CS, int8_t RST);
Adafruit_PCD8544(int8_t SCLK, int8_t DIN, int8_t DC, int8_t RST);
void begin(uint8_t contrast = 40);
void command(uint8_t c);
void data(uint8_t c);
void setContrast(uint8_t val);
void clearDisplay(void);
void display();
void drawPixel(int16_t x, int16_t y, uint16_t color);
uint8_t getPixel(int8_t x, int8_t y);
private:
int8_t _din, _sclk, _dc, _rst, _cs;
volatile uint8_t *mosiport, *clkport, *csport, *dcport;
uint8_t mosipinmask, clkpinmask, cspinmask, dcpinmask;
void slowSPIwrite(uint8_t c);
void fastSPIwrite(uint8_t c);
I don't know what is wrong since I am new at programming the arduino, can anyone help?
Please don't cross post, your other post has been deleted.
Read this before posting a programming question
Look at point 6, in particular the use of code tags.
bump
code tags
Please edit your original post, and put the code into code tags. As described in the link I gave.
I can't even read that yellow text, it just shimmers in front of my eyes.
yea its impossible to read, and the first time I looked at it I just closed the tab
anjianwu:
bump
You ignored my suggestion to use code tags, and now you bump the post. If you want results, listen to what people are saying. And go easy on the bumps. I see that isn't the first time you did that.
