help with error message-tm Elements _t'was not declared in this scope- am the
error message trying to set the time on my ds1307 - Arduino uno project-am rank amateur- message -tmElements_t'was not declared in this scope- project stops- please help :confused: :confused: :confused:
It may be wise for you to change your username from you email address to prevent spammers from harvesting it :o
As for your error you may want to attach your code.
int foo = 1;
if(foo == 1){
  int bar = 2;
foo = bar;
foo is global and is available inside the if statement. bar is only available inside the if statement because of the { } curly braces and so trying to make foo = bar will cause the error you are asking about. Z
Google "C++ scope" for more info on what @zhomeslice is talking about.
If you have used this in your sketch
#include <Time.h>
change it to
#include <TimeLib.h>
Pete
