Help with error message
I am trying to compile a custom version of the Marlin 1.1.9 firmware for my Ender3 3D printer. I get the following error message and do not know how to fix the error. I'm running Ubuntu 19.04 Beta. I have the Sanguino board installled in the IDE and the U8glib liberary version 1.18 installed as well.
Arduino: 1.8.5 (Linux), Board: "Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
In file included from /tmp/arduino_build_928042/sketch/ultralcd_impl_DOGM.h:49:0,
from /tmp/arduino_build_928042/sketch/ultralcd.cpp:96:
/tmp/arduino_build_928042/sketch/dogm_bitmaps.h:136:29: fatal error: _Statusscreen.h: No such file or directory
compilation terminated.
Using library U8glib at version 1.18 in folder: /home/mark/snap/arduino-mhall119/5/Arduino/libraries/U8glib
exit status 1
Error compiling for board Sanguino.
Any help is greatly appreciated.
Mark
Please put the full Marlin firmware you're using, including any modifications you've made in a zip file and attach it to a reply here. If you click the "Reply" button here, you will see an "Attachments and other settings" link through which you'll be able to make the attachment.
I'll take a look and see if I can't figure out the cause of the error.
Anyone can look at the error message, without seeing any code or any zip files, and see what the problem is.
OP's code is trying to include some file that does not exist on his/her system.
