Help with Error Messages and/or Problem With Code
Here's the code:
boolean detected_push = false ; boolean state = false ; unsigned long time_pushed = 0L ; boolean previous_button_state = digitalRead (5) ;
void loop () { if (digitalRead (5) == LOW && previous_button_state == HIGH) // button pressed { if (!detected_push && millis () - time_pushed > 20) // debounce check { detected_push = true ; // prevent more toggling till button released again state = !state ; digitalWrite (8, HIGH) ; } else time_pushed = millis () ; } if (detected_push && digitalRead (5) == HIGH) detected_push = false ; }
Here's the Verbose Log:
Arduino: 1.6.1 (Windows 7), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\hooks.c.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\WInterrupts.c.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\wiring.c.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\wiring_analog.c.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\wiring_digital.c.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\wiring_pulse.c.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\wiring_shift.c.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\abi.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\CDC.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\HardwareSerial.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\HardwareSerial0.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\HardwareSerial1.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\HardwareSerial2.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\HardwareSerial3.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\HID.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\IPAddress.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\main.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\new.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\Print.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\Stream.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\Tone.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\USBCore.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\WMath.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-ar rcs C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\WString.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-gcc -w -Os -Wl,--gc-sections -mmcu=atmega328p -o C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/PowerDrawbar.cpp.elf C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp\PowerDrawbar.cpp.o C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a -LC:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp -lm
C:\Users\Luke\AppData\Local\Temp\build1341424974318593730.tmp/core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/main.cpp:40: undefined reference to `setup'
collect2.exe: error: ld returned 1 exit status
Error compiling.
You are missing a setup() section.
Please use code tags next time! </> in the menu.
Have you seen with what the IDE opens? That’s the bare minimum. So you need to have a function setup. Even if it’s empty. But here it should not be empty.
The read of the previous state should go there.
boolean previous_button_state;
void setup(){
void loop (){
     state = !state ;
Also some tips
  1. For buttons, just use a library. It’s way easier, all the work is already done for you. I can recommend Bounce2.
  2. It’s in C++ more common to use variable name like timePushed then it is to use a underscore.
  3. Give all you’re pins a name. Now you have 5 scattered across your sketch. Just use something like cont byte ButtonPin =5; and use that.
