help with error" no matching function for call to 'MPU9250_<TwoWire>::MPU9250_(T
Hello, I’m having a problem with error of:
"no matching function for call to ‘MPU9250_::MPU9250_(TwoWire&, int)’
MPU9250 IMU(Wire,0x68);"
I’m having this problem in Arduino program. I’m new to Arduino.
Basic_I2C.ino
Brian R Taylor
brian.taylor@bolderflight.com
Copyright (c) 2017 Bolder Flight Systems
Permission is hereby granted, free of charge, to any person obtaining a copy of this software
and associated documentation files (the “Software”), to deal in the Software without restriction,
including without limitation the rights to use, copy, modify, merge, publish, distribute,
sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or
substantial portions of the Software.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING
BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM,
DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#include “MPU9250.h”
// an MPU9250 object with the MPU-9250 sensor on I2C bus 0 with address 0x68
int status;
// serial to display data
while(!Serial) {}
// start communication with IMU
status = IMU.begin();
if (status < 0) {
Serial.println(“IMU initialization unsuccessful”);
Serial.println(“Check IMU wiring or try cycling power”);
Serial.print("Status: ");
Serial.println(status);
while(1) {}
// read the sensor
IMU.readSensor();
// display the data
Serial.print(IMU.getAccelX_mss(),6);
Serial.print("\t");
Serial.print(IMU.getAccelY_mss(),6);
Serial.print("\t");
Serial.print(IMU.getAccelZ_mss(),6);
Serial.print("\t");
Serial.print(IMU.getGyroX_rads(),6);
Serial.print("\t");
Serial.print(IMU.getGyroY_rads(),6);
Serial.print("\t");
Serial.print(IMU.getGyroZ_rads(),6);
Serial.print("\t");
Serial.print(IMU.getMagX_uT(),6);
Serial.print("\t");
Serial.print(IMU.getMagY_uT(),6);
Serial.print("\t");
Serial.print(IMU.getMagZ_uT(),6);
Serial.print("\t");
Serial.println(IMU.getTemperature_C(),6);
delay(100);
What MPU9250 library are you trying to use? There are several of them and they are different.
Obviously, the library you are using does not support this
It appears that you got your example from here
https://github.com/bolderflight/MPU9250/blob/master/examples/Basic_I2C/Basic_I2C.ino
This is an example provided specifically for this MPU9250 library
while you are trying to use a completely different, incompatible MPU9250 library with this example.
