Thank you for the prompt Guidance. Below is the full error message, the main .ino code and I've attached the libraries referenced (.cpp and .h files)
Here is the full error message string.
Arduino: 1.8.12 (Windows Store 1.8.33.0) (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Cameron\OneDrive\Documents\Arduino\BreweryTemp_v2\BreweryTemp_v2.ino:25:18: warning: character constant too long for its type
Serial.println('Clock: ' + time_str.text);
sketch\Led.cpp:16:48: warning: default argument given for parameter 1 of 'void Led::blink(byte, int)' [-fpermissive]
void Led::blink(byte number = 1, int time = 250) {
In file included from sketch\Led.cpp:1:0:
sketch\Led.h:12:10: note: previous specification in 'void Led::blink(byte, int)' here
void blink(byte number = 1, int time = 250);
sketch\Led.cpp:16:48: warning: default argument given for parameter 2 of 'void Led::blink(byte, int)' [-fpermissive]
sketch\Cooler.cpp:2:46: warning: default argument given for parameter 2 of 'Cooler::Cooler(byte, bool)' [-fpermissive]
Cooler::Cooler(byte pin, bool relay_NO = true) { // no is normally open, to specify the default behaviour of the relay
In file included from sketch\Cooler.cpp:1:0:
sketch\Cooler.h:9:5: note: previous specification in 'Cooler::Cooler(byte, bool)' here
Cooler(byte pin, bool relay_NO = true); // no is normally open, to specify the default behaviour of the relay
C:\Users\Cameron\OneDrive\Documents\Arduino\BreweryTemp_v2\BreweryTemp_v2.ino: In function 'void setup()':
C:\Users\Cameron\OneDrive\Documents\Arduino\BreweryTemp_v2\BreweryTemp_v2.ino:33:41: warning: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
TSensor shed_temp(DS_SHED, sensors, 20);
In file included from C:\Users\Cameron\OneDrive\Documents\Arduino\BreweryTemp_v2\BreweryTemp_v2.ino:3:0:
sketch\TSensor.h:10:5: note: initializing argument 1 of 'TSensor::TSensor(uint8_t*, DallasTemperature, float)'
TSensor(uint8_t device_address[8], DallasTemperature sensors, float start_temp = 18);
C:\Users\Cameron\OneDrive\Documents\Arduino\BreweryTemp_v2\BreweryTemp_v2.ino:34:47: warning: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
TSensor outside_temp(DS_OUTSIDE, sensors, 20);
C:\Users\Cameron\OneDrive\Documents\Arduino\BreweryTemp_v2\BreweryTemp_v2.ino: In function 'void loop()':
BreweryTemp_v2:44:13: error: request for member 'getTemp' in 'shed_temp', which is of non-class type 'TSensor()'
shed_temp.getTemp();
BreweryTemp_v2:45:16: error: request for member 'getTemp' in 'outside_temp', which is of non-class type 'TSensor()'
outside_temp.getTemp;
BreweryTemp_v2:55:26: error: request for member 'last_temp' in 'shed_temp', which is of non-class type 'TSensor()'
Serial.print(shed_temp.last_temp);
BreweryTemp_v2:59:29: error: request for member 'last_temp' in 'outside_temp', which is of non-class type 'TSensor()'
Serial.print(outside_temp.last_temp);
BreweryTemp_v2:62:17: error: request for member 'last_temp' in 'shed_temp', which is of non-class type 'TSensor()'
if (shed_temp.last_temp > 14) {
BreweryTemp_v2:63:19: error: request for member 'last_temp' in 'shed_temp', which is of non-class type 'TSensor()'
if (shed_temp.last_temp > outside_temp.last_temp) {
BreweryTemp_v2:63:44: error: request for member 'last_temp' in 'outside_temp', which is of non-class type 'TSensor()'
BreweryTemp_v2:66:7: error: expected ';' before '}' token
sketch\TSensor.cpp:3:93: warning: default argument given for parameter 3 of 'TSensor::TSensor(uint8_t*, DallasTemperature, float)' [-fpermissive]
TSensor::TSensor(uint8_t device_address[8], DallasTemperature sensors, float start_temp = 18) {
In file included from sketch\TSensor.cpp:1:0:
sketch\TSensor.h:10:5: note: previous specification in 'TSensor::TSensor(uint8_t*, DallasTemperature, float)' here
sketch\Timelag.cpp: In member function 'void Timelag::init()':
sketch\Timelag.cpp:8:31: warning: integer overflow in expression [-Woverflow]
byte days = trunc(tmp/(24*60*60*1000));
sketch\Timelag.cpp:10:32: warning: integer overflow in expression [-Woverflow]
byte hours = trunc(tmp/(60*60*1000));
sketch\Timelag.cpp:12:28: warning: integer overflow in expression [-Woverflow]
byte mins = trunc(tmp/(60*1000));
sketch\TSensor.cpp: In member function 'void TSensor::getTemp()':
sketch\TSensor.cpp:36:21: warning: invalid conversion from 'const char*' to 'char' [-fpermissive]
last_result[8]= "OK";
exit status 1
option enabled in File -> Preferences.
Here is the main programme code (.ino)
#include "Led.h"
#include "Cooler.h"
#include "TSensor.h"
#include "Timelag.h"
#include <OneWire.h> // To access any one wire based sensors
#include <DallasTemperature.h> // For temperature functions and conversions on the DS18B20 specifically
bool ErrorLED = false;
Led green_led(8);
Led red_led(9);
Led error_led(12);
Cooler shed_fan(11);
OneWire oneWire(10); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
DallasTemperature sensors(&oneWire); // Pass our oneWire reference to Dallas Temperature.
TSensor shed_temp(void);
TSensor outside_temp(void);
// start serial port for output to console/terminal
Timelag time_str = Timelag(millis());
Serial.println("Welcome to OBSession Brewery!");
Serial.println("");
sensors.begin();
const uint8_t DS_SHED[8] = { 0x28, 0x13, 0x16, 0x94, 0x97, 0x10, 0x03, 0x4F };
const uint8_t DS_OUTSIDE[8] = { 0x28, 0x79, 0x4C, 0x94, 0x97, 0x09, 0x03, 0x35 };
// const uint8_t DS_BB[8] = { 0x28, 0x26, 0x3B, 0x22, 0x0B, 0x00, 0x00, 0x58 };
outside_temp.getTemp();
// Calculate the Temperatures
// Turn on the ErrorLED if in an error state
if (ErrorLED) { error_led.on(); }
else { error_led.off(); }
// Need to put checks in all the critical spaces to check for errors and update this flag
// CONTROL THE FAN
Serial.print(millis());
Serial.print(" | Shed(C): ");
//Serial.print(" | Target(C): ");
//Serial.print(TEMPSHEDTARGET);
Serial.print(" | Outside(C): ");
Serial.print(" | ");
shed_fan.on();
delay(300000)
else { shed_fan.off(); }
delay(60000); // Wait 1 Minute
Cooler.cpp (484 Bytes)
Cooler.h (290 Bytes)
Led.cpp (388 Bytes)
Led.h (208 Bytes)
Timelag.cpp (506 Bytes)
Timelag.h (232 Bytes)
TSensor.cpp (1.3 KB)
TSensor.h (387 Bytes)
