Hi ive been stuck on this for two days, its a small web server that drives a motor when I press a physical or web button. im stuck with getting my html button to do anything. when I press it it turns gray and that's it. I thought it should call handleSpray_button() but ive put a serial print in but nothing shows? any help would be appreciated.
thanks
#include <ESP8266WiFi.h>
#include <WiFiManager.h>
#include <ESP8266WebServer.h>
#include "LittleFS.h"
#include <LOLIN_I2C_MOTOR.h>
//webserver
ESP8266WebServer server(80);
// Pins
const int Manuak_PB_Pin = 14; // the number of the pushbutton pin
bool web_buttonPressed = false;
bool man_buttonState = false;
// Define variables for motor control
int FWD = 350; // time to run motor forward
int PAUSE = 500; // time to pause after motor runs forward
int BCK = 200; // time to run motor backward
// Motor
LOLIN_I2C_MOTOR motor;//(0x30);
void FireSpray() {
// myservo.write(posStart); // make sure at starting position
Serial.println("MOTOR_SEQUENCE_START");
Serial.println("FWD: = " + String(FWD));
Serial.println("PAUSE: = " + String(PAUSE));
Serial.println("BCK: = " + String(BCK));
pinMode(LED_BUILTIN, HIGH); // just for LED output
motor.changeDuty(MOTOR_CH_BOTH, 300);
motor.changeStatus(MOTOR_CH_A, MOTOR_STATUS_STOP);
//Serial.println("MOTOR_STATUS_CW");
motor.changeStatus(MOTOR_CH_A, MOTOR_STATUS_CCW);
delay(350);
//Serial.println("MOTOR_STATUS_STANDBY");
//Serial.println("MOTOR_STATUS_CCW");
motor.changeStatus(MOTOR_CH_A, MOTOR_STATUS_CW);
delay(200);
//delay(500);
pinMode(LED_BUILTIN, LOW); // just for LED output
Serial.println("MOTOR_SEQUENCE_STOP");
// Functions
void handleRoot() {
String html = "<html><head><meta name='viewport' content='width=device-width, initial-scale=1, maximum-scale=1, user-scalable=0'></head><body style='text-align:center;'>";
html += "<div style='margin: auto;'>";
html += "<h1 style='font-size: 300%;'>ESP8266 Glade Web Server</h1>";
html += "<form method=\"POST\" action=\"/spray_button\">";
html += "<button type=\"submit\" id=\"spray-button\" style='background-color:blue;color:white;padding:32px;border:none;border-radius:5px; font-size: 300%;'>Spray</button>";
html += "</form>";
html += "<form method=\"POST\" action=\"/wifisettings\">";
html += "<button type=\"submit\" style='background-color:gray;color:white;padding:16px;border:none;border-radius:5px; font-size: 150%;'>WiFi Settings</button>";
html += "</form>";
html += "<br><br><div style='text-align:left;display:inline-block;width:33%;'>";
html += "<label for='downtime'>Down Time:</label><br>";
html += "<input type='text' id='downtime' name='downtime' maxlength='5' value='" + String(FWD) + "'><br><br>";
html += "<label for='pausetime'>Pause Time:</label><br>";
html += "<input type='text' id='pausetime' name='pausetime' maxlength='5' value='" + String(PAUSE) + "'><br><br>";
html += "<label for='uptime'>Up Time:</label><br>";
html += "<input type='text' id='uptime' name='uptime' maxlength='5' value='" + String(BCK) + "'><br><br>";
html += "</div></div>";
html += "<script>";
html += "document.getElementById('spray-button').addEventListener('click', function() {";
html += "this.style.backgroundColor = 'gray';";
html += "this.disabled = true;";
html += "document.getElementById('wifi-settings-button').disabled = true;";
html += "document.getElementById('downtime').disabled = true;";
html += "document.getElementById('pausetime').disabled = true;";
html += "document.getElementById('uptime').disabled = true;";
html += "setTimeout(function() {";
html += "document.getElementById('spray-button').style.backgroundColor = 'blue';";
html += "document.getElementById('spray-button').disabled = false;";
html += "document.getElementById('wifi-settings-button').disabled = false;";
html += "document.getElementById('downtime').disabled = false;";
html += "document.getElementById('pausetime').disabled = false;";
html += "document.getElementById('uptime').disabled = false;";
html += "}, 5000);";
html += "});";
html += "</script>";
html += "</body></html>";
server.send(200, "text/html", html);
//void handleSpray_button() {
// if (!web_buttonPressed) {
// web_buttonPressed = true;
// Serial.println("Web Button pressed!");
// // Do something when button is pressed
// FireSpray();
// server.send(200, "text/plain", "Button Pressed");
Serial.println("Spray button clicked!");
pinMode(Manuak_PB_Pin, INPUT_PULLUP);
while (motor.PRODUCT_ID != PRODUCT_ID_I2C_MOTOR) //wait motor shield ready.
motor.getInfo();
// Connect to WiFi or start AP mode
Serial.println("Starting Wifimanager");
WiFiManager wifiManager;
wifiManager.autoConnect("WiFi Settings");
// If connected to WiFi, start the server
if (WiFi.status() == WL_CONNECTED) {
server.on("/", handleRoot);
server.on("spray_button",HTTP_POST, handleSpray_button);
server.begin();
Serial.println("Connected to WiFi");
Serial.print("IP address: ");
// If not connected to WiFi, redirect to WiFi settings page
else {
server.on("/", HTTP_GET, [](){
server.sendHeader("Location", "/wifi");
server.send(302, "text/plain", "");
server.on("/wifi", [&](){
if(server.method() == HTTP_POST){
String ssid = server.arg("ssid");
String password = server.arg("password");
if(ssid != "" && password != ""){
wifiManager.setConfigPortalTimeout(10);
LittleFS.begin();
File configFile = LittleFS.open("/config.json", "w");
if(!configFile){
Serial.println("Failed to open config file for writing");
else {
configFile.println("{\"ssid\":\"" + ssid + "\",\"password\":\"" + password + "\"}");
configFile.close();
server.send(200, "text/html", "<html><body><p>WiFi credentials saved.</p><p>You can now close this page and reboot the device.</p></body></html>");
return;
String html = "<html><body style='text-align:center'>";
html += "<h1>WiFi Settings</h1>";
html += "<form method=\"POST\">";
html += "<label>SSID:</label><br>";
html += "<input type=\"text\" name=\"ssid\"><br>";
html += "<label>Password:</label><br>";
html += "<input type=\"password\" name=\"password\"><br>";
html += "<input type=\"submit\" value=\"Connect\">";
html += "</form>";
server.begin();
Serial.println("Started access point");
Serial.println(WiFi.softAPIP());
server.handleClient();
// read the state of the pushbutton value:
man_buttonState = digitalRead(Manuak_PB_Pin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (man_buttonState == LOW) {
Serial.println("Manual Button Pressed" + man_buttonState);
Serial.print("Man button state: ");
Serial.println(web_buttonPressed);
delay(50);
//snprintf(msg, 75, "Manual Button Pressed");
//Serial.print("Publish message: ");
//Serial.println(msg);
//client.publish(outTopic, msg);
FireSpray();
