Help with ESP32 and Fauxmo
I already have some experience with arduino but this is my first time with ESP32. I've been working on a Smart Home project using the fauxmo library, an esp32 and some relays but i keep getting an error in the compiling.Can anyone help me?
(deleted)
The screenshot seems to indicate that something is missing, but why someone would post a picture (causing free helpers more work) instead of using code tags and copying and pasting is beyond me.
Similar to many others, I use a mobile device that causes me to prefer proper posts. No lecture, just explaining the facts.
#include <Arduino.h>
#ifdef ESP32
 #include <WiFi.h>
  #define RELAY_PIN_1 5
  #define RELAY_PIN_2 18
#else
  #include <ESP8266WiFi.h>
  #define RELAY_PIN_1 19
  #define RELAY_PIN_2 21
#endif
#include "fauxmoESP.h"
#include <RCSwitch.h>
#define SERIAL_BAUDRATE 115200
#define WIFI_SSID "XXX"
#define WIFI_PASS "XXXXXXXXXX"
#define Relay_1 "lamp one"
#define Relay_2 "lamp two"
fauxmoESP fauxmo;
void wifiSetup() {
  // Set WIFI module to STA mode
  WiFi.mode(WIFI_STA);
  // Connect
  Serial.printf("[WIFI] Connecting to %s ", WIFI_SSID);
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  // Wait
    Serial.print(".");
    delay(100);
  // Connected!
  Serial.printf("[WIFI] STATION Mode, SSID: %s, IP address: %s\n", WiFi.SSID().c_str(), WiFi.localIP().toString().c_str());
  Serial.begin (9600);
  wifiSetup();
pinMode (Relay1,OUTPUT);
pinMode (Relay2,OUTPUT);
pinMode (Relay3,OUTPUT);
pinMode (Relay4,OUTPUT);
fauxmo.createServer(true);
fauxmo.setport(80);
fauxmo.enable(true);
fauxmo.addDevice (LIGHTS_1);
fauxmo.addDevice (LIGHTS_2);
fauxmo.addDevice (LIGHTS_3);
fauxmo.addDevice (LIGHTS_4);
sorry
As i said first time :slight_smile:
and the error code is
In file included from C:\Users\jonat\Desktop\SmartHome\SmartHome_Board1\SmartHome_Board1.ino:11:0:
C:\Users\jonat\Documents\Arduino\libraries\FauxmoESP\src/fauxmoESP.h:82:25: fatal error: ESPAsyncTCP.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board ESP32 Dev Module.
Hello
FauxmoESP library resides:
https://bitbucket.org/xoseperez/fauxmoesp/src/master/
According the README.md of the library:
"Dependencies
Besides the libraries already included with the Arduino Core for ESP8266 or ESP32, these libraries are also required to use fauxmoESP:
ESP8266:
This library uses ESPAsyncTCP library by me-no-dev
ESP32:
This library uses AsyncTCP library by me-no-dev"
You need to download and install those libraries as README.md suggests.
Somehow ESPAsyncTCP.h is missing even if it is needed by ESP8266 and not by ESP32!!!
