Hello all,
based on another example I am trying to program an ESP8266 with javascript interface.
I want to have a button to open or close an electronic locker. If locker is open then pushing button with close it and the opposite.
If locker is on for more than 3 seconds then will close automatically.
Javascript make GET requests to have anytime from any client the real state of locker.
But when I push the button only CLOSE commant seems to be sent and I don't know why.
Plz help.
Thanks in advance
nodemcu code
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include "index.h" //Our HTML webpage contents with javascripts
#define LED 2 //On board LED
//SSID and Password of your WiFi router
const char* ssid = "Panagiotis_MikroTik-35F62D";
const char* password = "panos0342!";
String DOOR_STATE = "";
unsigned long door_open_interval = 3000;
unsigned long door_open_momment = 0;
unsigned long door_open_past_interval = 0;
ESP8266WebServer server(80); //Server on port 80
// This routine is executed when you open its IP in browser
void handleRoot() {
String s = MAIN_page; //Read HTML contents
server.send(200, "text/html", s); //Send web page
void check_DOOR() {
int a = digitalRead(LED);// or any other pin
if ( a == LOW) {
DOOR_STATE = "OPEN";
door_open_momment = millis();
DOOR_STATE = "CLOSE";
server.send(200, "text/plane", DOOR_STATE); //Send Led State value only to client ajax request
void handleDOOR() {
String t_state = server.arg("DOOR_STATE"); //Refer xhttp.open("GET", "setDOOR?DOOR_STATE="+doorState, true);
Serial.println(t_state);
if (t_state == "OPEN")
digitalWrite(LED, LOW); //LED ON
DOOR_STATE = "OPEN"; //Feedback parameter
digitalWrite(LED, HIGH); //LED OFF
DOOR_STATE = "CLOSE"; //Feedback parameter
server.send(200, "text/plane", DOOR_STATE); //Send web page
// SETUP
void setup(void) {
WiFi.begin(ssid, password); //Connect to your WiFi router
WiFi.mode(WIFI_STA);
Serial.println("");
//Onboard LED port Direction output
pinMode(LED, OUTPUT);
digitalWrite(LED, HIGH); //LED OFF this only is for build in LED for other pin in HIGH
// Wait for connection
Serial.print(".");
//If connection successful show IP address in serial monitor
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); //IP address assigned to your ESP
server.on("/", handleRoot); //Which routine to handle at root location. This is display page
server.on("/setDOOR", handleDOOR);
server.on("/checkDOOR", check_DOOR);
server.begin(); //Start server
Serial.println("HTTP server started");
// LOOP
void loop(void) {
if ((DOOR_STATE = "OPEN") && ((millis() - door_open_momment) >= door_open_interval)) {
}// check for open door and if it is open for more that door_open_interval close it
server.handleClient(); //Handle client requests
javascript code
const char MAIN_page[] PROGMEM = R"=====(
<!DOCTYPE html>
<html>
<head>
<meta name='viewport' content='width=device-width, initial-scale=1.0'/>
<meta charset='utf-8'>
<style>
body {font-size:140%;}
#main {display: table; margin: auto; padding: 0 10px 0 10px; }
h2 {text-align:center; }
#DOOR_button { padding:10px 10px 10px 10px; width:100%; background-color: #50FF50; font-size: 120%;}
</style>
<script>
var doorState = "___"
function switchDOOR() {
var xhttp = new XMLHttpRequest();
if (doorState=="CLOSE"){
doorState="OPEN";
if (doorState == "OPEN"){
doorState = "CLOSE";
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("DOOR_button").value = "OPEN DOOR";
document.getElementById("DOOR_button").backgroundColor = "#FF0000";
doorState="OPEN";
if (doorState=="OPEN"){
document.getElementById("DOOR_button").value = "CLOSE DOOR";
document.getElementById("DOOR_button").backgroundColor = "#50FF50";
doorState="CLOSE";
document.getElementById("doorstate").innerHTML = doorState;
xhttp.send();
setInterval(function() {
// Call a function repetatively with 2 Second interval
getDoorState();
}, 500); //500mSeconds update rate
function getDoorState() {
doorState =this.responseText;
xhttp.open("GET", "checkDOOR", true);
xhttp.send();
</script>
<title>DOOR CONTROL</title>
<span id="doorstate">NA</span>
<span id="test1">NA</span>
<span id="test2">NA</span>
</head>
<body>
<div id='main'>
<h2>DOOR Control</h2>
<input type="button" id = "DOOR_button" onclick="switchDOOR()" value="doorState" />
</div>
</body>
</html>
