AT+RbBÖ†AùRcâüS‰Š#Ü@BÿËȤ�ÜÿÃH�
àààüüüübB׆AùRbâþSˆŠ")JBÿÊȤ�ÌÿÃH�
getting garbage value as return like this.
Had the clean output once but after i restarted the device it is creating the problem like this.
am using the foll code by allaboutee examole.
#include <SoftwareSerial.h>
#include <IRLib.h>
#include <IRLibMatch.h>
#include <IRLibRData.h>
#include <IRLibTimer.h>
#include <IRLib.h>
#define DEBUG true
IRsend My_Sender;
SoftwareSerial esp8266(4,5);
esp8266.begin(9600);
pinMode(11,OUTPUT);
digitalWrite(11,LOW);
pinMode(12,OUTPUT);
digitalWrite(12,LOW);
pinMode(13,OUTPUT);
digitalWrite(13,LOW);
pinMode(10,OUTPUT);
digitalWrite(10,LOW);
sendCommand("AT+RST\r\n",2000,DEBUG);
sendCommand("AT+CWMODE=1\r\n",1000,DEBUG);
sendCommand("AT+CWJAP="Docomo","minatonamikazeA1"\r\n",3000,DEBUG);
delay(10000);
sendCommand("AT+CIPMUX=1\r\n",1000,DEBUG);
sendCommand("AT+CIPSERVER=1,80\r\n",1000,DEBUG);
sendCommand("AT+CIFSR\r\n",1000,DEBUG);
Serial.println("Server Ready");
if(esp8266.available())
if(esp8266.find("+IPD,"))
int connectionId = esp8266.read()-48;
if(esp8266.find("pn=") )
int pinNumber = (esp8266.read()-48);
int secondNumber = (esp8266.read()-48);
if(secondNumber>=0 && secondNumber<=9)
pinNumber*=10;
pinNumber +=secondNumber;
digitalWrite(pinNumber, !digitalRead(pinNumber));
String content;
content = "Pin ";
content += pinNumber;
content += " is ";
if(digitalRead(pinNumber))
content += "ON";
content += "OFF";
sendHTTPResponse(connectionId,content);
String closeCommand = "AT+CIPCLOSE=";
closeCommand+=connectionId;
closeCommand+="\r\n";
sendCommand(closeCommand,1000,DEBUG);
else if(esp8266.find("IR="))
int irNumber = (esp8266.read()-48);
int ir2Number = (esp8266.read()-48);
if(ir2Number>=0 && ir2Number<=9)
irNumber*=10;
irNumber +=ir2Number;
if(irNumber==01){
My_Sender.send(NEC,0xb4b40cf3, 32);
sendHTTPResponse(connectionId,"Done!");
String sendData(String command, const int timeout, boolean debug)
String response = "";
int dataSize = command.length();
char data[dataSize];
command.toCharArray(data,dataSize);
esp8266.write(data,dataSize);
if(debug)
Serial.println("\r\n====== HTTP Response From Arduino ======");
Serial.write(data,dataSize);
Serial.println("\r\n========================================");
long int time = millis();
while( (time+timeout) > millis())
while(esp8266.available())
char c = esp8266.read(); // read the next character.
response+=c;
if(debug)
Serial.print(response);
return response;
void sendHTTPResponse(int connectionId, String content)
String httpResponse;
String httpHeader;
httpHeader = "HTTP/1.1 200 OK\r\nContent-Type: text/html; charset=UTF-8\r\n";
httpHeader += "Content-Length: ";
httpHeader += content.length();
httpHeader += "\r\n";
httpHeader +="Connection: close\r\n\r\n";
httpResponse = httpHeader + content + " ";
sendCIPData(connectionId,httpResponse);
void sendCIPData(int connectionId, String data)
String cipSend = "AT+CIPSEND=";
cipSend += connectionId;
cipSend += ",";
cipSend +=data.length();
cipSend +="\r\n";
sendCommand(cipSend,1000,DEBUG);
sendData(data,1000,DEBUG);
String sendCommand(String command, const int timeout, boolean debug)
esp8266.print(command);
response+=c;
if(debug)
return response;
