Help with ESPwifi using arduino IDE
Hey guys,I know this is ESP related and not arduino but since they both use the IDE i thought i would ask here in hopes some ESP gurus can help, so i have my code written up but I want a web server to change some varibles ( led brightness, timer length etc) but while Im still very new and i got some code working, ive been watching countless youtube videos and just cannot get my head around the webserver stuff, Would anyone be able to help me please - It would be highly appreciated!
Thanks
Craig
craig-robbo:
Thanks
Craig
clear as mud
This kind of post is not going to get the help you want.
Be more specific.
ieee488:
clear as mud
Be more specific.
Im not sure what else to add, i want to change some varibles in my current code via a web page?
Im still fairly new to this so I would appreciate help or even help in knowing what information you want from me.
They'll want to know what code you got working.
The bit I underlined and put in bold are the values i would like to be editable via web interface
#include <ESP8266WiFi.h>
// ------- pin assignments -----------
const byte Amber1 = 14;   // Amber output switch
const byte Amber2 = 12;
const byte Amber3 = 13;
const byte Amber4 = 15;
const byte Reds = 4;      // Red Output switch (group of 3 LED sets)
const byte Reds2 = 16;    // Red Output switch (single output cluster)
const byte Indicator = 5;  // Indicator input pin
// ------------ Change to re-configure the boards characteristics -----------
const boolean IndicatorOn = LOW;   // state of the indicator input when ON
const boolean RelayOn = HIGH; // active level state for switching output ON
[u][b]
// Indicator setup
const unsigned int amberIndicatorInterval = 200;  // mS to get amber full running
const int amberBrightnessIncreaseStepsCount = 1; // Steps for indicator fade
const int amberTopBrightness = 100; //Indicator brightness
const int amberIndicatorOffInterval = 150;
// ED
//const unsigned int IndicatorInterval = 70;  // mS to get fade full running
//Running light setup
const int RampMaxValue = 100;   //Running light brightness
unsigned int RedsInterval = 2000;   // mS delay before RED leds are switched back on after indicator released[/b]
const unsigned int RampIncrement = 1;    // determines the Fade ramp up speed of Reds when ON - [b][/b][/u]decrease to slow down the rampconst boolean RelayOff = !RelayOn;
// ----------------------  Program variables and flags -----------------------
const boolean IndicatorOff = !IndicatorOn;
unsigned int IndicatorRunningTimer;
unsigned int RedsRunningTimer;
boolean IndicatorStatus;
boolean RedsDelay;
byte AmberPointer;
boolean PreviousIndicatorState;
boolean FirstPass;
boolean RedRamp;
unsigned int RampValue;
  pinMode(Indicator,INPUT_PULLUP);
  PreviousIndicatorState = digitalRead(Indicator);
  if(PreviousIndicatorState == IndicatorOff)
  {   // indicator is OFF at start up so switch Reds on
    RedRamp = true;
    RampValue = 0;
    FirstPass = false;
    pinMode(Reds,OUTPUT);
    pinMode(Reds2,OUTPUT);
    FirstPass = true; // indicator is on at start up so enable an Indicator sequence
    RedRamp = false;
  WiFi.disconnect();        // turn off WiFi radio section (reduce current consumption)
  WiFi.mode(WIFI_OFF);      // turn off WiFi radio section (reduce current consumption)
  WiFi.forceSleepBegin();   // turn off WiFi radio section (reduce current consumption)
  Serial.begin(115200);     // Serial port for debugging
  Serial.println("");
  Serial.println("Sequencer 3V0");
  Serial.println("");
  pinMode(Indicator,FUNCTION_3);    // reassign RX pin to be a normal GPIO
  AmberPointer = 0;         // reset Amber sequencer to amber 1 LED
  RedsDelay = false;        // disable Reds delay timer
  IndicatorStatus = false;
  IndicatorRunningTimer = millis();
  RedsRunningTimer = millis();
}  // end of void Setup()
    if(digitalRead(Indicator) == IndicatorOn && (PreviousIndicatorState == IndicatorOff || FirstPass == true))
    {  // Indicator just switched on
      Serial.println("Indicator >> On");
      FirstPass = false;
      PreviousIndicatorState = IndicatorOn;
      IndicatorStatus = true;  // enable Indicator sequence
      RedsDelay = false;
      digitalWrite(Reds,RelayOff);
      digitalWrite(Reds2,RelayOff);
      Serial.println("Reds >> Off");
      AmberPointer = 0;
    else if(digitalRead(Indicator) == IndicatorOff && PreviousIndicatorState == IndicatorOn)
    {  // Indicator just Switched off
      PreviousIndicatorState = IndicatorOff;
      digitalWrite(Amber1, RelayOff);
      digitalWrite(Amber2, RelayOff);
      digitalWrite(Amber3, RelayOff);
      digitalWrite(Amber4, RelayOff);
      Serial.println("Indicator >> Off");
      RedsDelay = true;  // enable Red delay timer
      RedRamp = false;
    // ED Please don't use delays unless you really need it. Delays are generally bad
    // practice which will lead to wasting process time and hurting time-sensitive functions
    //delay(10);
    // ED
delay(10);
    if(IndicatorStatus == true)  // if indicator has been switched on
      AmberSequencer();
    }   // end of if(IndicatorStatus == true)
    if(RedsDelay == true)
      unsigned int RedsTimer = millis() - RedsRunningTimer;
      if (RedsTimer > RedsInterval)  // timer overflow
          RedsDelay = false;
          //digitalWrite(Reds, RelayOn);
          RedRamp = true; // enable red to be able to ramped
          RampValue = 0;
          Serial.println("Reds ON");
    }  // end of if(RedDelay == true)
    // ------- Ramp Red value brightness if enabled ----------------
    if(RedRamp == true)
      analogWrite(Reds,RampValue);
      analogWrite(Reds2,RampValue);
      //Serial.println(RampValue);
      RampValue = RampValue + RampIncrement;   // increment brigntness value
      if(RampValue >= RampMaxValue){ RedRamp = false; } // if brightness > 100%, stop ramp
}  // end of void loop()
void AmberSequencer()
  int channelsTotalCount = 4;
  int brightnessLevelTiming  = 0;
  int singleCHannelTimeFrame = 0;
  unsigned int IndicatorDelta = millis() - IndicatorRunningTimer;
  unsigned int channelDelta = 0;
  int runningBrightness = 0;
  int isFadeIn = 1;
  int channelsMap[4] = {
    Amber1, Amber2, Amber3, Amber4
  // here we will define limit for channels settings loop
  int IndicatorDeltaCounts = IndicatorDelta / (amberIndicatorInterval / channelsTotalCount);
  if(IndicatorDeltaCounts > 3) {
    IndicatorDeltaCounts = 3;
  // iterating through channels
  for(int currentChannel = 0; currentChannel <= IndicatorDeltaCounts; currentChannel++) {
    isFadeIn = 1;
    // calculating how many brightmess channel must have
    channelDelta = IndicatorDelta - currentChannel * (amberIndicatorInterval / channelsTotalCount);
    if(channelDelta > amberIndicatorInterval + amberIndicatorOffInterval) {
        channelDelta = channelDelta - (amberIndicatorInterval + amberIndicatorOffInterval);
        isFadeIn = 0;
    brightnessLevelTiming  = channelDelta / ((amberIndicatorInterval / channelsTotalCount) / amberBrightnessIncreaseStepsCount);
    runningBrightness = amberTopBrightness / amberBrightnessIncreaseStepsCount * brightnessLevelTiming;
    if(isFadeIn == 1) {
        runningBrightness = amberTopBrightness - (amberTopBrightness / amberBrightnessIncreaseStepsCount * brightnessLevelTiming);
    if(runningBrightness > amberTopBrightness) {
        runningBrightness = amberTopBrightness;
    if(runningBrightness < 0) {
    analogWrite(channelsMap[currentChannel], runningBrightness);
// end of void AmberSequencer()
(Next time, useCode tags, not Quote tags please. It’s the </> button on the menu.
Thanks, Moderator)
Thanks for link. I've spent all morning studying it and honestly I think I'm in over my head.
I appreciate the help but just a bit too complicated for me.
Tha ks all the same
So i tried implement the example you gave me, and I can get it to show the page, but i cannot get it to change the values i require
What am I doing wrong?
Code here:
#include <Arduino.h>
  #include <ESPAsyncTCP.h>
#include <ESPAsyncWebServer.h>
AsyncWebServer server(80);
// REPLACE WITH YOUR NETWORK CREDENTIALS
const char* ssid = "SKYC1BB3";
const char* password = "DSPWXTFDBC";
const char* PARAM_INPUT_1 = "input1";
const char* PARAM_INPUT_2 = "input2";
const char* PARAM_INPUT_3 = "input3";
// HTML web page to handle 3 input fields (Indicator, input2, input3)
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html><head>
  <title>ESP Input Form</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  </head><body>
  <form action="RampMaxValue">
    input1: <input type="text" name="input1">
    <input type="submit" value="Submit">
  </form>
  <form action="amberTopBrightness">
    input2: <input type="text" name="input2">
  </form>
  <form action="RampIncrement">
    input3: <input type="text" name="input3">
    <input type="submit" value="Apply">
  </form>
</body></html>)rawliteral";
void notFound(AsyncWebServerRequest *request) {
  request->send(404, "text/plain", "Not found");
//these values in this area in web server//
// Indicator setup
const unsigned int amberIndicatorInterval = 200;  // Indicator on animation (mS)
const int amberBrightnessIncreaseStepsCount = 1; // Indicator inter-segment Fade
const int amberIndicatorOffInterval = 150; // Indicator off animation  (mS)
const int RampMaxValue = 100;   // Running light brightness
unsigned int RedsInterval = 2000;   // Running light Delay (mS)
const unsigned int RampIncrement = 1;    // Running light Fade speed
//end of web server area//
boolean RedsDelay;
byte AmberPointer;
boolean FirstPass;
boolean RedRamp;
    RedRamp = true;
    RampValue = 0;
    FirstPass = false;
    RedRamp = false;
  Serial.println("");
  Serial.println("");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  if (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("WiFi Failed!");
    return;
  Serial.print("IP Address: ");
  // Send web page with input fields to client
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html);
  // Send a GET request to <ESP_IP>/get?Indicator=<inputMessage>
  server.on("/get", HTTP_GET, [] (AsyncWebServerRequest *request) {
    String inputMessage;
    String inputParam;
    // GET Indicator value on <ESP_IP>/get?Indicator=<inputMessage>
    if (request->hasParam(PARAM_INPUT_1)) {
      inputMessage = request->getParam(PARAM_INPUT_1)->value();
      inputParam = PARAM_INPUT_1;
    // GET input2 value on <ESP_IP>/get?input2=<inputMessage>
    else if (request->hasParam(PARAM_INPUT_2)) {
      inputMessage = request->getParam(PARAM_INPUT_2)->value();
      inputParam = PARAM_INPUT_2;
    // GET input3 value on <ESP_IP>/get?input3=<inputMessage>
    else if (request->hasParam(PARAM_INPUT_3)) {
      inputMessage = request->getParam(PARAM_INPUT_3)->value();
      inputParam = PARAM_INPUT_3;
    else {
      inputMessage = "No message sent";
      inputParam = "none";
    Serial.println(inputMessage);
    request->send(200, "text/html", "HTTP GET request sent to your ESP on input field ("
                                     + inputParam + ") with value: " + inputMessage +
<a href=\"/\">Return to Home Page</a>");
  server.onNotFound(notFound);
  server.begin();
      FirstPass = false;
      RedsDelay = false;
      AmberPointer = 0;
      RedRamp = false;
delay(10);
      AmberSequencer();
I had to cut the code short due to char limit, However I have cut the bit off that wasnt part of the web server stuff
You need to contact the person who wrote the tutorial.
another tutorial in 10 parts ESP8266 and the Arduino IDE | Martyn Currey
