This would be my Joystick's code:
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
byte remoteIP[]={192, 168, 1, 101};
unsigned int remotePort=8888;
char rxChar;
int val, val2;
const int potpin=0;
const int potpin2=1;
unsigned int localPort = 8888; // local port to listen on
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
// start the Ethernet and UDP:
Ethernet.begin(mac);
Udp.begin(localPort);
val = analogRead(potpin);
val2= analogRead(potpin2);
Serial.println("val1=");
Serial.println(val);
Serial.println("val2=");
Serial.println(val2);
if(val>650)
if(val2>650)
rxChar='I';
Serial.println('I');
else if(val2<350)
rxChar='D';
Serial.println('D');
rxChar='F';
Serial.println('F');
else if (val<350)
if(val2>650)
rxChar='J';
Serial.println('J');
else if(val2<350)
rxChar='K';
Serial.println('K');
rxChar='B';
Serial.println('B');
else if(val2>650)
if(val>650)
rxChar='I';
else if(val<350)
rxChar='J';
rxChar='L';
Serial.println('L');
else if (val2<350)
if(val>650)
rxChar='D';
else if(val<350)
rxChar='K';
rxChar='R';
Serial.println('R');
rxChar='S';
Serial.println('S');
Udp.beginPacket(remoteIP,remotePort);
Udp.write(rxChar);
Udp.endPacket();
And this my WiFi's code:
#include <SPI.h>
#include <WiFiUdp.h>
#include<WiFi.h>
byte remoteIP[]={192, 168, 1, 102};
char rxChar;
const int motorPin = 2;
const int motorPin2 = 3;
const int motorPin3 = 4;
const int motorPin4 = 5;
const int ledrojo = 1;
const int ledsadelante= 12;
const int ledsatras= 13;
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
WiFiUDP Udp;
pinMode(motorPin, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
pinMode(ledrojo, OUTPUT);
pinMode(ledsadelante, OUTPUT);
pinMode(ledsatras, OUTPUT);
char ssid[] = "pp123"; // your network SSID (name)
char pass[] = "asdf1234"; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
int packetSize = Udp.parsePacket();
if(packetSize)
rxChar=Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
switch (rxChar)
case 'F':
digitalWrite(motorPin,HIGH);
digitalWrite(ledrojo, LOW);
digitalWrite(ledsadelante, HIGH);
digitalWrite(ledsatras, LOW);
case 'L':
digitalWrite(motorPin3,HIGH);
digitalWrite(ledsadelante, LOW);
case 'R':
digitalWrite(motorPin4,HIGH);
case 'B':
digitalWrite(motorPin2,HIGH);
digitalWrite(ledsatras, HIGH);
case 'I':
case 'D':
case 'J':
case 'K':
default:
digitalWrite(motorPin,LOW);
digitalWrite(motorPin2,LOW);
digitalWrite(motorPin3,LOW);
digitalWrite(motorPin4,LOW);
digitalWrite(ledrojo,HIGH);
It obviously doesn't work, but is how I Imagined
I think the Ethernet's one is fine, but i have my doubts about the Wifi one... Please help!
Thanks
