Peter_n:
Is your Wizfi210 not officially supported by Arduino ? Which library do you use for it ? Many Etherent/wifi libraries have UDP implemented.
Yes it is, and it supports the Wifi.h library.
I tried with this code for the Ethernet one:
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
byte remoteIP[]={192, 168, 1, 101};
unsigned int remotePort=8888;
char rxChar;
int val, val2;
const int potpin=0;
const int potpin2=1;
unsigned int localPort = 8888; // local port to listen on
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
// start the Ethernet and UDP:
Ethernet.begin(mac);
Udp.begin(localPort);
val = analogRead(potpin);
val2= analogRead(potpin2);
Serial.println("val1=");
Serial.println(val);
Serial.println("val2=");
Serial.println(val2);
if(val>650)
if(val2>650)
rxChar='I';
Serial.println('I');
else if(val2<350)
rxChar='D';
Serial.println('D');
rxChar='F';
Serial.println('F');
else if (val<350)
if(val2>650)
rxChar='J';
Serial.println('J');
else if(val2<350)
rxChar='K';
Serial.println('K');
rxChar='B';
Serial.println('B');
else if(val2>650)
if(val>650)
rxChar='I';
else if(val<350)
rxChar='J';
rxChar='L';
Serial.println('L');
else if (val2<350)
if(val>650)
rxChar='D';
else if(val<350)
rxChar='K';
rxChar='R';
Serial.println('R');
rxChar='S';
Serial.println('S');
Udp.beginPacket(remoteIP,remotePort);
Udp.write(rxChar);
Udp.endPacket();
And this in the Wifi:
#include <SPI.h>
#include <WiFiUdp.h>
#include<WiFi.h>
byte remoteIP[]={192, 168, 1, 102};
char rxChar;
const int motorPin = 2;
const int motorPin2 = 3;
const int motorPin3 = 4;
const int motorPin4 = 5;
const int ledrojo = 1;
const int ledsadelante= 12;
const int ledsatras= 13;
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
WiFiUDP Udp;
pinMode(motorPin, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
pinMode(ledrojo, OUTPUT);
pinMode(ledsadelante, OUTPUT);
pinMode(ledsatras, OUTPUT);
char ssid[] = "pp123"; // your network SSID (name)
char pass[] = "asdf1234"; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
int packetSize = Udp.parsePacket();
if(packetSize)
rxChar=Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
switch (rxChar)
case 'F':
digitalWrite(motorPin,HIGH);
digitalWrite(ledrojo, LOW);
digitalWrite(ledsadelante, HIGH);
digitalWrite(ledsatras, LOW);
case 'L':
digitalWrite(motorPin3,HIGH);
digitalWrite(ledsadelante, LOW);
case 'R':
digitalWrite(motorPin4,HIGH);
case 'B':
digitalWrite(motorPin2,HIGH);
digitalWrite(ledsatras, HIGH);
case 'I':
case 'D':
case 'J':
case 'K':
default:
digitalWrite(motorPin,LOW);
digitalWrite(motorPin2,LOW);
digitalWrite(motorPin3,LOW);
digitalWrite(motorPin4,LOW);
digitalWrite(ledrojo,HIGH);
What I am doing wrong? because it doesn't work... I think the Ethernet's is fine, but I'm in doubt with the Wifi's. The Ethernet's IP is 192.168.1.102 and the Wifi's Ip 192.168.1.101, that's why the Remote Ip are the opposite in each sketch.
Thanks
